Old 09-10-2012, 06:13 PM #1
HedgehogOutdoors's Avatar
HedgehogOutdoors HedgehogOutdoors is offline
HedgehogOutdoors is on a distinguished road
Driver's side door unlock button doesn't work
Well I can't seem to find someone with the exact problem I have. I was looking in the Haynes book, and I thought I read the terminal diagram wrong, but I tested the passenger side door lock, it locks and unlocks no problem. I read the driver's side the same way, I jump 2 to 3 for unlock like the book says, and that locks. The book says jump 2 to 4 to lock, so I was thinking it was backwards. I looked, I can't jump 2 to 4 since there isn't a wire there.
I thought maybe the diagram is backwards? Can't try 2 to 3 by that method, since now 3 is missing. And 2 to 4 doesn't do anything. WHAT THE HELL. I will try to get up pictures or a video in a bit to help if anyone doesn't know what I'm talking about.
Now, the reason I am worried about this is I was on a fire call last night, parked, left the truck running because I knew it would be a quick one. Tried to get the hatch open, wasn't unlocked. Went back to the door, remembered driver's side door button doesn't work. So, I tried the key fob, but apparently that doesn't work when in the ignition, so I had to reach over to the passenger's side just to open my hatch to get my gear out, THEN gear up and help out. Very frustrating, especially in a fast paced situation like that.
HedgehogOutdoors is offline   Reply With QuoteReply With Quote
Old 09-11-2012, 08:04 AM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
Disasemble the whole switch, might need a good cleanin or the switch just went bad.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 09-11-2012, 03:09 PM #3
Well I was thinking that it might be the switch, which is why I was attempting to jump the harness, but that wire is missing, so I think that's part of the problem.
Old 09-11-2012, 04:26 PM #4
Video will be up in an hour or so. That is if I don't get a fire call before then.
Old 09-12-2012, 02:23 PM #5
Here's the video.
4runner Door Won't Unlock (Switch Fault) - YouTube
Old 09-18-2012, 06:02 PM #6
Xetabur's Avatar
Xetabur Xetabur is offline
Xetabur will become famous soon enough
Xetabur's Avatar
I started a thread awhile back about both front door switches will not lock/unlock but my keyfob will. Also the automatic locks work when I cut the truck on. The alarm system is all OEM (whatever its called RS something).
2015 Nautical Blue Trail Premium 4WD w/KDSS
2016 Magnetic Gray Limited 4WD
2000 Land Cruiser
Xetabur is offline   Reply With QuoteReply With Quote
Old 09-19-2012, 03:21 PM #7
I'm thinking the guys that had the system installed had to remove the wire I need for the button to work in order to make the key fob work. But, I found the wire I need from the passenger's side and am going to splice it over to the driver's side.
Switch Update #1 (9/14/12) - YouTube
Old 04-20-2016, 10:09 PM #8
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Hedgehog, I am having the exact same problem. Drivers side door unlock switch doesn't work but lock does. Also the passenger side door unlock/lock switch works fine.
Did you ever figure out what it was?
thegipper is offline   Reply With QuoteReply With Quote
door , driver's , driver's side door unlock , side , unlock
HTML code is Off
Driver side door lock/unlock cvvoord New Members 2 09-05-2012 09:36 PM
Installed new HU, now driver's side window auto down feature doesn't work... YotaDriver Engines / Suspension / Wheels / Tires / Audio / Accessories 8 06-18-2011 12:38 PM
2003 4Runner Driver Door Unlock Issue 2003T4Runner 4th Gen T4Rs 0 11-14-2010 12:55 PM
2005 driver's side door will only lock/unlock manually klev48 Problems & Warranty Issues 2 12-16-2008 02:26 PM
Driver side door won't unlock all doors with Key NYT4RBlack 3rd gen T4Rs 5 12-11-2008 01:54 PM
