this afternoon, i added a power port to my 4th gen. i tapped into the wires in the cigarette smoker/ashtray kit as detailed here:
http://www.toyota-4runner.org/access...connector.html.
i also wired it with the 115v toyota switch (even though i am not installing an inverter). here is the wiring diagram:
http://www.toyota-4runner.org/audio-...tml#post245497
i used position 6 for positive (pink with blue wire), position 4 as ground coming from the extra plug, and position 3 was grounded out. i also used one of the positive green wires to connect to the positive end to the power plug.
here's my problem: it only works when the headlights are switched on! once that happens, the switch does lit up and supply power to the plugs as needed. how do i get it to work without using the headlights? i know this behavior is not normal, because when i wanted to add another plug, i searched the forum here and loads of people tapped into the unused cigarette plug. i understand it probably has something to do with opening up a closed circuit, but that's as far as my understanding goes.
what am i doing wrong and how can i fix it?
2007 SE, Galactic Grey Mica - original owner
Mods/Upgrades: Oh Crap Handle on driver's side, Hilux Surf Trash Stash, Amber Colored Auto-Dimming Mirror w/compass,
USB ports using 115V switch, LED interior, Weathertech Digital Floor Liners, Homelink Garage Door Opener, Footwell Lighting, Automatic Headlights,
Dual Cargo Organizers, Maplight Mod, Morimoto 5k HID Low-Beam and Fogs, LED exterior, 15% 3M tint, AVIC-6100nex, Pioneer speakers (TS-G1345R, TS-G1645R, TS-T110), Limited Grill,
Mini Backseat Organizer,
Heated Cloth Seats, KO2s
