Old 01-14-2013, 06:15 PM #46
theizzardking's Avatar
theizzardking theizzardking is offline
theizzardking will become famous soon enough
i'm becoming interested, who's got one of the longer bars mounted up on an ARB? (preferably 3rd gen) thinking of ditching the hellas and replacing with a single LED bar, the pricing is finally starting to look right.!
'76 FJ40, '87 4runner, '98 LC 100, 99 4runner,'02 Tundra,'02 LX470,'08 Tacoma Dbl cab,'09 LC200, '16 Trail Premium. also 76 super beattle,'06 XR650L,'18 Triumph Scrambler-XE.
theizzardking is offline   Reply With QuoteReply With Quote
Old 01-14-2013, 06:24 PM #47
SV_Dude SV_Dude is offline
Moderator
Real Name: Jonathan
SV_Dude will become famous soon enough
Moderator
Real Name: Jonathan
I have an ARB on the front of my 4runner for now. I am going to put the 18" in the middle on the top bar and the 2 4" lights on the corner upper bar as well. The arb bumper is a temp bumper though. I'll be building a bumper for it soon... hopefully!
SV_Dude is offline   Reply With QuoteReply With Quote
Old 01-14-2013, 06:46 PM #48
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
I've got a 30" on the top of my ARB. It's not from treck lights though. The main reason I went with the bar I did was 1) Locally from a good friend so I got the hook up and 2) Has a versatile mounting system where the mounting brackets slide in a rail on the back of the housing, then tighten. This allowed me to mount it wherever I want, thus why it is where it is with no extra mounting fabrication. It's a good representation of what it would look like though if you got one up there.
If no mounting points on these lights line up with the existing holes you could always make some kind of bracket (flat steel) that bolts to the existing tabs on the arb and then mount your light on the bracket. That's what I did with my 10" I use to have.
Keep in mind that any kind of light will most likely obstruct opening and closing your hood. It depends how deep the housing is and how far the light sits back. My bug guard hits the one I have. If I didn't have the bug guard I'd be ok.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | SherpaEC | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 01-14-2013, 06:51 PM #49
treklights's Avatar
treklights treklights is offline
treklights is on a distinguished road
treklights's Avatar
Originally Posted by cruisermansd View Post
Troy, thanks for the speedy service!!!
Troy handled my order like a pro, customer support was top notch and the shipping was super fast!!!
I have a trip planned and Troy surpassed my expectations.
Troy hooked me up with one 13 inch and two 7 inch bars!!!!
Thanks again Troy.
You're most welcome, sir!
Be sure to post pics on here and my facebook page when you get them installed!
-Troy
1997 FZJ80
treklights is offline   Reply With QuoteReply With Quote
Old 01-14-2013, 09:26 PM #50
looks good man!! what do you think about replacing the hella's with say 24 inch or 2x10's in the lower down in the normal location?
Old 01-14-2013, 09:51 PM #51
JWaldz's Avatar
Moderator
Real Name: Waldo
Moderator
JWaldz's Avatar
Real Name: Waldo
Those are old photos.. I've since then sold the hellas. I actually just recently bought a pair of fog pattern 4 cree led pods from a place called www.okledledlightbars.com. The owner is a member on TacomaWorld. They're 2180 lumens each. I'm going to wrap the lenses with yellow vinyl
Old 01-16-2013, 06:39 PM #52
rickashay's Avatar
rickashay rickashay is offline
Real Name: Addison
rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold
rickashay's Avatar
Real Name: Addison
Pretty excited to see you offering wiring as well. Just makes the whole thing that much easier. +1 on the rocker switches, but I also don't have a problem swapping in my own switch later - pretty easy.
rickashay is offline   Reply With QuoteReply With Quote
Old 01-16-2013, 10:34 PM #53
treklights's Avatar
treklights's Avatar
Still working this one out.
Haven't found a solution I like enough to build mass quantities of.
At the very least, I'll be shipping a rocker switch and fuse holder with each light.
1997 FZJ80
Old 01-16-2013, 11:58 PM #54
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
You having issues with your web page or are you no longer selling the single row led lights?
Old 01-17-2013, 12:03 AM #55
treklights's Avatar
treklights's Avatar
Waiting for my OEM to give me some more documentation on those lights. I've pulled the line while I'm waiting.
If I put them back up, I'll let you guys know.
Sorry if that put a damper on your plans
BTW, your lights should be at my doorstep by Tuesday.
1997 FZJ80
Old 01-17-2013, 12:13 AM #56
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
If the hanma group buy continues at the end of the month I'll probably try a $30 cheapie 2x6 from them. At this point I'm not sure if my idea is going to work or not with the rear facing light we were talking about. I don't want to spend a lot of money on an experiment. I think I'm going to pull the rear upper brake light and try to fit a 2x6 flood in there and tap the reverse light wiring to a relay to turn rear flood light on and off. I'll rig a 3 position switch on the dash to turn the light on/off via the switch and the relay too so it doesn't come on at night when driving around town or in parking lots. But I'm not sure if I can fit the light in the rear brake light housing on the body. It will be a cool little experiment.
Old 01-17-2013, 12:18 AM #57
treklights's Avatar
treklights's Avatar
It'll be interesting to see how that works out.
1997 FZJ80
Old 01-21-2013, 02:08 AM #58
vlafrank vlafrank is offline
vlafrank is on a distinguished road
Are any of your lights legal for street use? I'm especially interested in those 4" (?) square ones.
2007 4Runner Sport edition, Titanium metallic
Bi-xenon HIDs, combo GPS/radar detector/laser detector/laser jammers/laser & photo diffusers on licence plates/trailer hitch tow hook/Python 460 intrusion alarm/OEM SiriusXM upgrade/leather int.
vlafrank is offline   Reply With QuoteReply With Quote
Old 01-21-2013, 07:59 AM #59
treklights's Avatar
treklights's Avatar
Hey vlafrank,
These lights are for off-road use.
Not sure the DOT would approve of insanely bright LED's for street driving
1997 FZJ80
Old 01-21-2013, 08:05 AM #60
Desert Fox's Avatar
Desert Fox Desert Fox is offline
Real Name: Bill
Desert Fox is on a distinguished road
Desert Fox's Avatar
Real Name: Bill
Do you have Lumens ratings for the XT series?
I am trying to decide between the XT series and TrekPods.
I want to add flood lighting to the front.
I pledge allegiance to the flag of the United States of America, and to the republic for which it stands, one nation under God, indivisible, with liberty and justice for all.
Desert Fox is offline   Reply With QuoteReply With Quote
cree , epistar , led bars , led light bars , led lights
HTML code is Off
rigid led 2x2 or led pods in place of 99's fog light bumper? Supra725 3rd gen T4Rs 1 12-09-2012 11:35 AM
Light bars flatboy 3rd gen T4Rs 5 12-22-2011 01:37 AM
Tacoma light bars/bull bars weeeee 3rd gen T4Rs 0 06-07-2009 01:10 AM
