Old 01-21-2013, 11:03 PM #61
treklights's Avatar
treklights treklights is offline
treklights is on a distinguished road
treklights's Avatar
Originally Posted by Desert Fox View Post
Do you have Lumens ratings for the XT series?
I am trying to decide between the XT series and TrekPods.
I want to add flood lighting to the front.
Definitely.
See below for a list of each light's LED type and Lumen rating.
Sorry for the late reply, I'm in Maine on business and haven't been at my computer all day.
ES Series TrekLight LED Light Bars
7 Inch TrekLight ES - 3W Epistar LED's - 2,500 Lumens
13 Inch TrekLight ES - 3W Epistar LED's - 4,500 Lumens
22 Inch TrekLight ES - 3W Epistar LED's - 7,500 Lumens
33 Inch TrekLight ES - 3W Epistar LED's - 11,250 Lumens
42 Inch TrekLight ES - 3W Epistar LED's - 15,000 Lumens
XT Series TrekLight LED Light Bars
4 Inch TrekLight XT - 3W CREE LED's - 1,600 Lumens
6.5 Inch TrekLight XT - 3W CREE LED's - 2,800 Lumens
9 Inch TrekLight XT - 3W CREE LED's - 4,500 Lumens
12 Inch TrekLight XT - 3W CREE LED's - 5,700 Lumens
18 Inch TrekLight XT - 3W CREE LED's - 8,600 Lumens
22 Inch TrekLight XT - 3W CREE LED's - 10,000 Lumens
36 Inch TrekLight XT - 3W CREE LED's - 18,500 Lumens
TrekPods
TrekPod OctaPlus (Round) - 3W Epistar LED's - 1,600 Lumens
TrekPod OctaPlus (Square) - 3W Epistar LED's - 1,600 Lumens
FloodPod - 3W Epistar LED's - 1,000 Lumens
TrekPod Mono XT - 10W CREE LED's - 900 Lumens
TrekPod 4x4 - 3W Epistar LED's - 2,800 Lumens
TrekPod Quad XT - 10W CREE LED's - 3,600 Lumens
1997 FZJ80
treklights is offline   Reply With QuoteReply With Quote
Old 01-23-2013, 09:50 PM #62
SV_Dude SV_Dude is offline
Moderator
Real Name: Jonathan
SV_Dude will become famous soon enough
Moderator
Real Name: Jonathan
@treklights
Troy,
How much amperage do your lights draw? I'm working on a wiring diagram to run the lights as I told you. Check out the thread below:
Electrical Guru's
SV_Dude is offline   Reply With QuoteReply With Quote
Old 01-23-2013, 10:27 PM #63
treklights's Avatar
treklights's Avatar
Originally Posted by SV_Dude View Post
@treklights
Troy,
Electrical Guru's
Hey SV,
Funny you should ask, I had these hooked up to a tester the other day.
The 4" XT's were drawing just above 1 amp at 12 volts.
The 18" XT's I believe were right around 6 amps at 12 volts, but I'll have to double check, as I don't remember exactly.
1997 FZJ80
Old 01-24-2013, 01:08 AM #64
SigSense SigSense is offline
SigSense is on a distinguished road
Question
Troy, are there plans in the future for any "combi" series lights? I'm interested in a flood/spot combination for a ATV.
SigSense is offline   Reply With QuoteReply With Quote
Old 01-24-2013, 07:53 AM #65
treklights's Avatar
treklights's Avatar
You guys are quicker on the draw than I am today!
I blame it on the flu I'm currently nursing.
Starting today, all ES Series TrekLight bars are available in spot/flood combo beam.
1997 FZJ80
Old 01-24-2013, 02:21 PM #66
treklights's Avatar
treklights's Avatar
Guys, you'll have to excuse my idiocy.
I was messing around with an XT Series TrekLight Bar today and found out that the mounting points DO in fact slide from side to side!
There's a little bit of play when the mounting points are on either end of the bars, so mounting to something slightly wider than the mounting range should take up the last of that slack.
Here is the mounting width range for the XT Series TrekLights:
4" TrekLight XT: One mounting point (can be moved all the way left or all the way right along the bar).
6.5" TrekLight XT: One mounting point (can be moved all the way left or all the way right along the bar).
9" TrekLight XT: One mounting point (can be moved all the way left or all the way right along the bar).
12" TrekLight XT: 1.5" apart to 8.75" apart
18" TrekLight XT: 1.5" apart to 14.75" apart
22" TrekLight XT: 1.5" apart to 18.75" apart
36" TrekLight XT: 1.5" apart to 32.75" apart
1997 FZJ80
Old 01-24-2013, 07:32 PM #67
Desert Fox's Avatar
Desert Fox Desert Fox is offline
Real Name: Bill
Desert Fox is on a distinguished road
Desert Fox's Avatar
Real Name: Bill
So how does that work? Is one half flood and one half spot?
I pledge allegiance to the flag of the United States of America, and to the republic for which it stands, one nation under God, indivisible, with liberty and justice for all.
Desert Fox is offline   Reply With QuoteReply With Quote
Old 01-24-2013, 08:05 PM #68
treklights's Avatar
treklights's Avatar
More like 80/20.
The inner lights (80%) are spot, and the outer lights (20%) are flood.
1997 FZJ80
Old 01-24-2013, 09:15 PM #69
Desert Fox's Avatar
Real Name: Bill
Desert Fox's Avatar
Real Name: Bill
More like 80/20.
Are they operated by the same switch where they both come on at the same time or is there some kind of dual control?
You may have changed my entire plan
This option is not showing on the web site yet.
Old 01-24-2013, 09:18 PM #70
Desert Fox's Avatar
Real Name: Bill
Desert Fox's Avatar
Real Name: Bill
Talking
By the way. There are some guys talking about your product on a Colorado FJ site. One of them saw the MUD group buy.
I have been sharring the info you give me. Is that worth a 25% discount?
Colorado FJ Cruiser enthusiasts
Old 01-24-2013, 09:19 PM #71
treklights's Avatar
treklights's Avatar
Sorry to throw the monkey wrench into your plan!
Same switch. The floods and spots do not operate separately. The only thing that's different is the shape of the reflectors.
1997 FZJ80
Old 01-24-2013, 09:28 PM #72
treklights's Avatar
treklights's Avatar
PM Sent.
1997 FZJ80
Old 01-25-2013, 11:05 AM #73
treklights's Avatar
treklights's Avatar
TrekPod Mono XT Night Shots
Low Beams:
ONE TrekPod Mono XT Spot Beam:
1997 FZJ80
Old 01-25-2013, 11:54 PM #74
treklights's Avatar
treklights's Avatar
18" TrekLight XT Night Shots
Some TrekLight eye candy:
18" TrekLight XT Spot Beam
Obligatory "Twin Trees" Shot
Into the sky. Notice how there's enough spread to shine a bright light onto the trees, while throwing a killer spot beam into the sky:
Into the Woods:
1997 FZJ80
Old 01-28-2013, 05:17 PM #75
treklights's Avatar
treklights's Avatar
So, I'm thinking about opening the GB up a little early since the other one is already over.
What do you all think?
Anyone itching to reserve a light?
1997 FZJ80
cree , epistar , led bars , led light bars , led lights
HTML code is Off
rigid led 2x2 or led pods in place of 99's fog light bumper? Supra725 3rd gen T4Rs 1 12-09-2012 11:35 AM
Light bars flatboy 3rd gen T4Rs 5 12-22-2011 01:37 AM
Tacoma light bars/bull bars weeeee 3rd gen T4Rs 0 06-07-2009 01:10 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
