Old 01-09-2013, 11:28 PM #1
sixxt sixxt is offline
sixxt is on a distinguished road
Remote Start Problem
Hi guys,
I have done some searching on the forum and couldn't quite find what I was looking for, so i figured it is time to post my problem.
I have an audiovox remote starter on my 99 4Runner, and it used to work fine until i got it serviced at a toyota dealership. I had the spark plugs replaced, and the timing belt replaced. Now my remote start doesnt work.
When i attempt to use it, it starts the car for about a second or two and then dies out, tries again two more times and then quits.
Any ideas of what the problem is and what I can do?
Thanks!
My 99 SR5 V6 Runner: http://photobucket.com/99-4runner
sixxt is offline   Reply With QuoteReply With Quote
Old 01-10-2013, 07:07 PM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
They might have gotten a wire loose, your best thing to do is take it to a stereo alarm shop to have a proper diagnostic and repair done.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 01-17-2013, 10:11 PM #3
Thanks for the response.
Any other ideas that I can do possibly by myself?
Old 01-18-2013, 06:24 AM #4
psiems's Avatar
psiems psiems is offline
psiems is on a distinguished road
psiems's Avatar
Unless you are really tech savvy, I would recommend spending a few bucks having it checked out by a reliable installer. Not worth the headache IMO.
"The problem with socialism is that eventually you run out of other peoples' money." - Margaret Thatcher
psiems is offline   Reply With QuoteReply With Quote
Old 01-18-2013, 12:49 PM #5
blcktpgsr's Avatar
blcktpgsr blcktpgsr is offline
Real Name: Ervin
blcktpgsr will become famous soon enough
blcktpgsr's Avatar
Real Name: Ervin
Does it exhibit the same symptom when you manually start it? if it does then it could very well be your starter contacts.
97 4Runner SR5 TRDSC URD Yukon Camburg Toytec Trekmaster 4Crawler SonoranSteel Level8 Nitto SavageOff-Road ARB Smittybilt MasterPull Powertank SpiderTrax B&M Jaos Gobi Flowmaster Cobra Firestik Alpine CompuStar Hella PIAA RigidIndustries WeatherTech
my build
http://www.toyota-4runner.org/3rd-ge...formation.html
July 2012 T4RoTM / 2012 T4RoTY
blcktpgsr is offline   Reply With QuoteReply With Quote
Old 01-18-2013, 06:26 PM #6
delz05 delz05 is offline
delz05 is on a distinguished road
I had a similar issue... under the hood there is a trigger wire that should be connected to a tach sensing wire. Could be on the ignition coil circuit, a fuel injector circuit or some tach signal circuit. Check under the hood, you may be able to follow the wires that pass from the interior to under the hood. (There may be only 1 single wire)
06 4Runner Limited V8, 05 Tundra Stepside
16 Audi A8L, 13 Audi S5 Convertible
Family comes first....nice cars a close second!
delz05 is offline   Reply With QuoteReply With Quote
Old 01-19-2013, 02:09 AM #7
riceandpho's Avatar
riceandpho's Avatar
a better install will have atleast 4 sets of wire going in and out the firewall, one pair for siren, one for hood pin and one for main power to the alarm brain. i would take it to a shop for a small fee for the job be done right.
Old 01-19-2013, 02:00 PM #8
Not to discredit anyone... but the response regarding 4 wires does not apply to a remote start.
A simple remote start install utilizes a tach sensor connection under the hood, as opposed to tapping in at the computer. Hood pin switches are not commonly used due to the fact that they rust and corrode, making them ineffective. A toggle switch in-line with the brake light switch is a much safer way of disabling a remote start unit.
All other wiring is done under the steering column and driver side kick panel.
Old 01-20-2013, 01:42 AM #9
riceandpho's Avatar
riceandpho's Avatar
The hood pin is just there for added security, if for some reason anyone open the hood while the car is arm, alarm should go off, just like the doors. I know most people dont run a main fused line in the car for the alarm brains, the installers like to tap a constant on for the main power for the alarm.
HTML code is Off
RFID Keyless Entry, Push Button Start and Remote Start BFLAN 5th gen T4Rs 41 04-17-2012 09:36 PM
Remote Start or Security + Remote Start dheeter 4th Gen T4Rs 3 12-29-2008 05:49 PM
2006 4Runner SR5 remote start w/factory remote?? brantatchison Engines / Suspension / Wheels / Tires / Audio / Accessories 3 12-04-2006 12:18 PM
Can a remote start be used with existing remote transmitter? atomic punk 4th Gen T4Rs 7 12-02-2006 11:23 PM
Remote start with factory remote entry?? Jay Engines / Suspension / Wheels / Tires / Audio / Accessories 9 01-15-2006 10:44 AM
