Ok I have an 05 4Runner with the JBL package, I ordered:
Kenwood DNX6990
Metra ASWC
Metra Turbo Wire
PAC TATO
Ok...so if anyone can help a newb out, Im trying to figure out how these harnesses connect.
First thing Im stuck on, steering wheel controls. I bought the Metra ASWC and I bought the Turbo Wire which cuts down the splicing necessary for the ASWC and make its more plug and play.
So when I hook this up Im not sure if I have to splice the female 3.5mm jack to the Kenwood steering wheel input on their harness or if Im supposed to use the rca's to the back of the radio...I dont think I have to use the rca's on the 70-8114 because the PAC TATO should be using up all the rca's on the back of the radio.
If anyone could walk me through or has pictures with 3.5mm jack or rca's on a Kenwood that would help me out, I dont see a 3.5mm on the radio itself (like a remote in) so I assume I have to grab the remote wire on the Kenwood harness.
Ok second issue, the PAC TATO. Ive never used a harness like this before...usually every piece of the Kenwood harness gets plugged into every piece of the factory harness...so now I see it looks like I connect only 3-4 wires on the Kenwood harness to the TATO and then just plug the RCA's in?
It looks like I have a harness on the TATO and on the ASWC that look exactly the same...wondering if those two will be a conflict...
The harness tp the top/left but the plug on the right looks just like the harness on the 70-8114...
