Old 10-22-2005, 11:50 AM #31
iFORCE's Avatar
iFORCE iFORCE is offline
iFORCE is on a distinguished road
iFORCE's Avatar
Originally posted by sharp4runr
I doubt that 1157 bulb could generate so much heat to cause the housing to melt. I'd think the bulb would go bad before that happened.
Its less heat than my nieces Easy Bake oven
actually... it would generate enough heat to melt the plastic. If the bulb touches the plastic then over time it'll melt. Best to use LEDs and put an inline resistor.
Black 2003 4Runner Limited V8 4WD
(Canadian Edition)
- TRD High Performace Air Filter
- TRD Cat-Back Exhaust
- 25% Front Tint / 15% Rear Tint
- Bridgestone Dueler Revo A/T
- Projector Foglights w/ 4300K HID
- Black JDM style Taillights
- 2006 Projector Headlights w/ 4300k HID LINK
- Custom Rear Fog Lights w/ Switch - LINK
Pictures on My Website
iFORCE is offline   Reply With QuoteReply With Quote
Old 10-22-2005, 01:41 PM #32
HRunner HRunner is offline
HRunner is an unknown quantity at this point
Quoted from bryancos's thread
IMPORTANT NOTE REGARDING HEAT ISSUES!
I've found that filament type 1157 bulbs DO generate enough heat to melt the plastic in the extended "tube" of plastic" where the bulbs mount if run as tail lights. Recommend that you consider either using LED 1157 type bulbs, or dremel/saw off about 3/4" or more of the "tubular section" so that the bulb itself extends into the actual lamp housing when it's mounted and is not surrounded by the plastic.
Refer to http://www.toyota-4runner.org/showth...5&pagenumber=1
HRunner is offline   Reply With QuoteReply With Quote
Old 10-23-2005, 12:11 AM #33
Techenigma's Avatar
Techenigma Techenigma is offline
Techenigma is an unknown quantity at this point
Techenigma's Avatar
Thought I'd update this with the actual wire colors and which pin they go to on the tail light connector.
Ok on the diagram earlier in the thread if the plug is oriented the same as in that diagram the yellow wire runs to the top left socket, the black is of course in the bottom right and the brown goes in the 2nd row 2nd column. This is assuming of course you bought a 1157 socket with three wires a black for ground, a brown live, and a yellow live. Hope this makes it easier for those attempting this mod.
2005 4Runner Sport Edition 4X2 V8 Black - 20% front - 2% Back Tint - Magnaflow exhaust
- Faux JDM tails - Bumper Light Mod -
Custom Alpine Audio System
XM satellite Radio
KCA-420i iPod interface /w 60 gig iPod video
Coming Soon: NVE-N872A Navigation
Viper 791XV
Mini piezo
Field Disturbance sensor
Backup Battery
Coming soon:
JDM faux Black Headlights
Dual Optima's
1200 watt hardwired inverter
Techenigma is offline   Reply With QuoteReply With Quote
Old 10-23-2005, 03:10 AM #34
Techenigma's Avatar
Techenigma's Avatar
HRunner... Can you perhaps elaborate on how you remove the wire pins in the tail light connector? you say you push up and then pull it out the back but I've been fiddling with the darn things for 40 minutes and cant get them to come out. Anyone done this mod and run it to the stock wire connector feel free to also chime in. thanks.
XM satellite Radio
Viper 791XV
Mini piezo
Backup Battery
Coming soon:
Dual Optima's
Old 10-23-2005, 04:26 AM #35
Techenigma, it's not easy to explain...
Basically, it has a clip for each pin inside of the plug. Use a tiny screwdriver to pull in, then up and down a bit while you pressing the screwdriver in. (Damn... it's very hard to explain...)
All you need to do, is to press the clip, then the wire could easy pull out from the back. Another simply way, is to jam the wire (or cut the wire) behind the plug.
It's not a "must" to remove the wire pins. This just looks better (in fact, no one can see it anyway).
Good luck!
Old 10-23-2005, 04:28 AM #36
Techenigma, you may also get some jamming connector (I am not sure what it called) from electronical store. It is simply to clip-in another wire with the exsiting wire.
Old 10-23-2005, 11:52 AM #37
00328's Avatar
00328 00328 is offline
00328 is on a distinguished road
00328's Avatar
Techenigma - what I did (and I think it's in iForces thread) I took a male blade connector and cut it narrow with some tin snips or you could use a very sharp scissor. Once it's cut to the right width, you can just slip it into the back of the plug. Took me a couple tries, if you cut it too narrow it will not stay or make a good connection.
HRunner - don't mean to step on your thread, just giving a different way to connect the wires.
2005 4X4 V8 LTD 4Runner Black
Driver's side upper assist handle, tail/stop bumper light mod, Flowmaster 50 suv with side exit exhaust and Valor tip, 20% tint on fronts and 27% add'l tint on rear window, DIY blacked-out headlights, Stainless door sills, VIP Plus w/GBS alarm, OBX pedals, Can. hood protector, ash tray kit, '06 LED tails, T&H Euro bar, OME lift, Spidertrax spacers, LT275/70R17 Cooper AT3s, HIR bulbs in LB and fogs, VSC mod, AFE Pro Dry S filter, White LED cluster and HVAC
00328 is offline   Reply With QuoteReply With Quote
Old 10-23-2005, 12:32 PM #38
Techenigma's Avatar
Techenigma's Avatar
Ahh Ok well I have a bunch of blade connectors on hand, and that would make this easily reversible. I didn't like the idea of messing with the original wiring, especially since its fairly short, and any mistakes and you'd have to redo a section of wire.... Ok guys thanks for the input. really appreciated!
XM satellite Radio
Viper 791XV
Mini piezo
Backup Battery
Coming soon:
Dual Optima's
Old 10-24-2005, 09:36 AM #39
AlexJet's Avatar
AlexJet AlexJet is offline
AlexJet is on a distinguished road
AlexJet's Avatar
That's exactly what I did with my mod. I would recommend using plastic wiring strips to fix it in place for secure reasons. Works fine so far, I didn
2005 4Runner Limited V6
Safari Snorkel, Custom 5”, ARB Lockers, 4.56 Nitro Gears, 285/65-R18 + 18x9 (-12), 315/70-R17 + 17x9 (-6), ARB Front Bumper, WARN 9.5xp, Custom Full Undercarriage Protection: bumper to bumper, Custom Rock Sliders/Steps, CBI Rear Bumper.
2016 4Runner Limited
Safari Snorkel, 3" OME, 285/65-R18, 18x9 (-12), Custom Rock Sliders/Steps,... work in progress
AlexJet is offline   Reply With QuoteReply With Quote
Old 10-24-2005, 11:58 AM #40
00328's Avatar
00328's Avatar
[QUOTE]Originally posted by AlexJet
[B]That's exactly what I did with my mod. I would recommend using plastic wiring strips to fix it in place for secure reasons. Works fine so far, I didn
Old 10-24-2005, 12:01 PM #41
AlexJet's Avatar
AlexJet's Avatar
What are "plastic wiring strips"?
Its "Nylon Cable Ties" in other words. I can make some pictures tonight and post them tomorrow if you want.
Old 10-24-2005, 08:36 PM #42
00328's Avatar
00328's Avatar
I am a little curious as to how you secured the wires in the back of the plug with cable ties.
If that's what you did.
Old 10-24-2005, 10:27 PM #43
MDT4RNR's Avatar
MDT4RNR MDT4RNR is offline
Real Name: Dax
MDT4RNR is on a distinguished road
MDT4RNR's Avatar
Real Name: Dax
[QUOTE]Originally posted by HRunner
6a) To connect the 1 feet wires that prepared in the step 4a, to the taillight plug. Simply use a tiny screw driver, pull in a bit and you could pull out the pin from the back of the plug. NOTE: the black color plug shows in this picture in the right side tailight, which the white plug above is the left side. But both are the same.
6b) This picture shows the wires are connected to the plug.
NOTE: you need to take off the taillight piece (just 2 nuts) and then you could have the both couplers connected inside the bumper.
[/QUOTE
Thank you or the write up HRunner,
Could you clarify how ecxactly you attached the wire to the plug. I was able to take out the pin from the back of the plug and after looking at it I tried to picture where you secured the connector wire to the pin.
Did you just slide the wire in along with the pin into the plug?
Did you solder the wire to the tail end of the pin? (cause I was thinking about buying the "Cold Heat" soldering tool to do this)
Does one really have to take the tail lights off in order to run the wires or is there another way?
Sorry about all the questions, but thanks to your work so far I feel I should ask you this before I mess things up
Thanks
Black '03 SE 6Cyl
212,000 miles as of 11/18/2018
JBL Synthesis with Kenwood DDX-470
Otherwise stock As f@#k
MDT4RNR is offline   Reply With QuoteReply With Quote
Old 10-24-2005, 11:28 PM #44
Thanks
I strip the wire about 1/8 inch, then solder it to the end of the pin. It takes a bit skill because you need to make sure you're able to put the pin back into the plug.
I skipped this part in my writeup, because there're many ways to do... Have fun!
Old 10-24-2005, 11:32 PM #45
I won't say you can't... however, this is the shortest route (don't want to have a very long long wires)... and simple!
Just 2 bolts.... take you less than a minute
HTML code is Off
Putting the red bumper lenses to use bryancos Engines / Suspension / Wheels / Tires / Audio / Accessories 397 05-12-2023 11:15 AM
New CBI Rear Bumper wb880 4th Gen T4Rs 9 04-21-2011 10:11 PM
wrong year ARB bumper hoggy 4th Gen T4Rs 1 04-03-2009 02:08 AM
How to replace rear bumper red reflector? testrider 4th Gen T4Rs 11 01-10-2008 09:40 AM
Urgent Please Help: Bumper Issue for my 03 Sport Edition Wai 4th Gen T4Rs 5 09-27-2005 12:14 PM
