11-20-2005, 07:58 PM
#16
I will get pictures of the bulbs considering I stored them and keeping them so I can replace them....
11-20-2005, 10:57 PM
#17
I remember they were similar to this.
Although some bulbs have a longer neck holding the bulb it self(the ones lighting the controls). The two bulbs lighting the info screen are similar to the one on the pic.
btw what type leds did you use... i think i saw a site that had leds with 360 degree lighting angles.
2004 Galactic Grey 4Runner Sport Edition
2006 Redline 350Z Coupe
Current Mods- | Sylvania Silverstar lights | White LED front side markers | DEH-9450Mp3 Pioneer HU | White LED Door step, Map Light, Dome Light bulbs | 6x9 front Type S Alpines | 6.5 Rear Type S Alpines | Alpine V-Power F240 4channel amp |
Plans - 2006 LED tail lights | Alpine Mono amp + 12inch Type R | Independant fog light mod | 4.3k Hid Retrofit (Possibly with Projectors)
" Nothing is ever perfect, so don't go ranting around every issue... think and fix it rather than opening your mouth."
11-20-2005, 11:40 PM
#18
yup.. the bulbs sort of look like that with long necks...
The LED's I used are 4000 MCD's.... so they are bright.. the only thing is that they don't have the 360 degree.. I definitely would be interested in the 360 degree LED's...
11-20-2005, 11:47 PM
#19
Well i'm not quite sure about the size leds you used, but here's the superbrightleds.com website listing of their bulbs. 360 degree ones are available i 5 and 8 mm.. might be a bit big to fit, but i believe you cut some of the board out on your previous posts. I like your mod and might do the same to mine once i find a spare cluster.
link - http://www.superbrightleds.com/leds.htm
Hope this helps
Edit - i'm guessing the leds are quite large to the ones you used.. but i'm not sure.. maybe a wider viewing angle could help more on lighting issues.
Edit 2 - The inverted lens leds would be a good too.
11-20-2005, 11:55 PM
#20
That looks like the same size bulb they use for the glove box. size 64 or something like that?
Check out my 2004 4Runner Audio upgrade.
11-20-2005, 11:56 PM
#21
Hope this helps
If you can find a wider view angle, that will help with the hot spots that you see. The leds you have now, most like likely have something like 10 or maybe 15 degree viewing angle.
11-21-2005, 12:06 AM
#22
Wasn't sure about the glovebox bulb size so i stuck my head in there to check.
The bulb aren't the same. i believe they are #73/74 in a twist lock base.
I'll yank out my hvac controls in a min to give some pics of the bulbs.
11-21-2005, 12:25 AM
#23
11-21-2005, 03:26 AM
#24
o wow i thought they were leds soldered straight into the circuits, didnt realize they wer scew in bulbs. def gunna have to do this now. what is so much harder about the guages? are they leds soldered in?
2016 White Tacoma Double Cab Short Bed TRD Off Road
SOLD
March 2007 T4ROTM
2004 Galactic Grey, 3rd Row, Leather, Scion FR-S Navigation, Daystar 2.5 Lift, Toytec 1in BL, 285/70/17 BFG All Terrain, Thule Rack and more
11-21-2005, 12:02 PM
#25
the Gauges were LED's soldered in... they are little squares... with round mirror bases and a tiny dot... like cellphone LED's.... so that's how come I'm not too excited yet to mess around with my gauges...
11-22-2005, 02:51 AM
#26
yea thats how i thought they all were... thats why i havent done this yet. I know i could do it, its just the time it takes and that fear in the back of your head that you will break something.
SOLD
March 2007 T4ROTM
11-25-2005, 08:44 PM
#27
Anyone ever replace - or want to replace - the bulb/led light source in the driver's side door panel (lights up = AUTO) ?
That switch is SOOOOO hard to read at night after taking your eyes of a well lit road, it's impossible to see. I'd like to replace that light with something ALOT brighter and NOT orange.
2015 Black Limited.
2005 Silver Sport.
11-26-2005, 04:53 AM
#28
yea i am thinking of replacing that one to something brighter, i took apart the switches and it should be a real easy switch, just gotta find a small bright led
also what size are the turn signal bulbs you used, wouldnt mind replacing those to blue, and how hard was it to take the dash apart?
thanks
SOLD
March 2007 T4ROTM
11-30-2005, 06:15 PM
#29
found this ... but too bad they don't have Blue LED
http://www.ledtronics.com/ds/BSD-1838-0Ux/default.asp
anyone tried these bulbs?
BLACK 2005 V8 Limited 2WD w/ NAV w/ NuShield Klear Screen, Stone Leather Interior, 20" 4Runner Limited Wheels, OEM Rear Spoiler, OEM Carpeted Floor mats, OEM All-Weather Floor mats, OEM SE Shift Knob, OEM Ashtray and Lighter Kit, OEM 2006 Front End Skid Plate, OEM Black Pearl Emblems, LoJack, KUDA Mount, DIY Rear Bumper Red Light MOD, DIY Fog Light MOD (ON with High Beam and/or Parking Light only), Tinted Tail Light, V-LEDS 5000K HID (Low Beam and Fog Light).
12-01-2005, 12:42 AM
#30
ohhh!!!!! noooo!!! where did you find that?!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
HTML code is Off
