Old 08-20-2013, 09:55 PM #1
Carl Fisher Carl Fisher is offline
Carl Fisher is on a distinguished road
Bus bars for power/ground distribution
Prototyping power distribution for future power hungry upgrades plus the standard big 3 upgrade and the audio amp run. I'm not happy with the layout yet but it at least shows some of the ideas I'm playing around with. Ultimately there will be a plexi cover over the entire assembly.
This shows the home made bus bars from 3/16" x 3/4" copper, UHMW and 1/4x20 stainless hardware. There will be a 1/0awg feed to each side of the bus from the battery and then branch off as needed with Pico copper rings.
My only unknown is if I want to fuse between the battery and the bus bar. If I do decide to fuse between the two, I may relocate the entire assembly to the passenger side of the engine compartment in the big empty space over the wheel well.
Once I finalize the layout, I'll make a permanent base painted red and black to distinguish the two sides.
Comments and ideas welcome.
Bus bars for power/ground distribution-img_2007_small-jpg  Bus bars for power/ground distribution-img_1996_small-jpg  Bus bars for power/ground distribution-img_2001_small-jpg
Carl Fisher is offline   Reply With QuoteReply With Quote
Old 08-27-2013, 03:19 PM #2
blkexp98 blkexp98 is offline
blkexp98 is on a distinguished road
Thats a good idea and much more user friendly than a standard battery clamp. Glad to see someone else from SC is working on it. I have a small desktop mill and thought about doing this as well.
Is your base material the UHMW under the screw heads and whats keeping them from turning? It looks like just a pan head screw unless that was just for the mock up. A simple fix would be a square head bolt. That would keep the bolt head from turning better than a hex head. Unless you want to get fancy and cut a hex you can just cut an oval with the sides long enough to fit the square head.
2007 Limited 4Runner
4x4 V8
blkexp98 is offline   Reply With QuoteReply With Quote
HTML code is Off
Power not getting to the ground in Reverse? aha2988 4th Gen T4Rs 3 04-29-2012 10:47 AM
Power not getting to the ground in reverse? aha2988 Off-Roading 2 04-24-2012 10:02 AM
power but No ground to the injectors s2kpuddydad Classic T4Rs 11 12-19-2011 07:51 PM
Amp power and ground wire tannerc Engines / Suspension / Wheels / Tires / Audio / Accessories 1 10-24-2009 04:14 PM
Power or Ground?? tomhaney1 Problems & Warranty Issues 11 11-19-2007 01:12 AM
