12-19-2005, 07:21 PM
LED For Turn Signal, Will It Work?
Sometimes there is a problem with LED blinkers, due to reduced resistance they blink faster than OEM. I ordered pair for tail @ Superbrightleds.com, will those work? Company claims they're plug in and play. Has anyone done it though?
12-19-2005, 08:39 PM
I'm pretty sure they'll blink to fast, just like you said.
Does anyone know what type of flasher the Runner uses. Can a load independant one be swapped out, to stop this.
Check out my 2004 4Runner Audio upgrade.
12-19-2005, 09:36 PM
It's a 7443 type bulb. The one I ordered has resistor instaled inside. I'm just curious if there's enough resistance? Any way mine should arrive in 2 days. I'll post on what happens.
12-19-2005, 09:39 PM
Real Name: Karl
Real Name: Karl
I had this issue when I turned the rear fog lights into LED blinkers. You need to order the resistors that they sell-
http://www.superbrightleds.com/1157.htm
Scroll down and you will see LED resistor kits.
2013 4Runner TE Salsa Red Pearl
My Baby- 2011 Jerez Black Metallic M3
Sold and Missed Dearly:2004 Toyota 4 Runner
12-20-2005, 07:11 AM
if i remember correctly someone tried fitting the led bulbs into the tail light assembly but had to trim a peice because the led module couldn't fit through the narrow hole of the stock bulbs.
2004 Galactic Grey 4Runner Sport Edition
2006 Redline 350Z Coupe
Current Mods- | Sylvania Silverstar lights | White LED front side markers | DEH-9450Mp3 Pioneer HU | White LED Door step, Map Light, Dome Light bulbs | 6x9 front Type S Alpines | 6.5 Rear Type S Alpines | Alpine V-Power F240 4channel amp |
Plans - 2006 LED tail lights | Alpine Mono amp + 12inch Type R | Independant fog light mod | 4.3k Hid Retrofit (Possibly with Projectors)
" Nothing is ever perfect, so don't go ranting around every issue... think and fix it rather than opening your mouth."
12-22-2005, 12:40 PM
Those fit nicely, no triming needed. I love the color and fit, but Damit those blink like mad. Normal blinker rate is 80 per minute, LED goes probubly 280-360. Resistors definatelly needed. I give up, OEM amber back in and LED back to store
12-26-2005, 10:47 AM
If you getting right bulbs, they will fit without any problems. ksneubec is right you'll need to add parallel resistors to flush the LED like the filament bulb
2005 4Runner Limited V6
Safari Snorkel, Custom 5”, ARB Lockers, 4.56 Nitro Gears, 285/65-R18 + 18x9 (-12), 315/70-R17 + 17x9 (-6), ARB Front Bumper, WARN 9.5xp, Custom Full Undercarriage Protection: bumper to bumper, Custom Rock Sliders/Steps, CBI Rear Bumper.
2016 4Runner Limited
Safari Snorkel, 3" OME, 285/65-R18, 18x9 (-12), Custom Rock Sliders/Steps,... work in progress
12-26-2005, 08:05 PM
What I wanna know is if the 06 LED tails also have LED amber turn indicators! Can someone who has the new LED tails please chime in on this!
---2004 Galactic Grey SR5 4X4 V6 w/ Factory moon roof, Toyota carpet floor mats, Emergency kit, first aid kit, cargo net.
---My Mods: Rear spoiler w/ LED brake light, 17"Sport Edition rims upgrade w/ wheel locks, hood bug deflector, 3M stick-on dark gray tinted side window visors, smoked moon roof visor, polished stainless exhaust tip, Scion HU T1804, DRL's, Toyota seat covers, Factory RS3200+ Security alarm, 2nd Ashtray for extra plug, OBX racing pedals, De-badged front doors, Rear Bumper red lens mod (Stop and Tails only), front chrome Strona Bull bar, Nerf chrome side step bars, upgraded to the 7500 lb Hidden Tow Hitch.
---Future mods and wish list: 2-3" Donahoe Coilover lift spring shocks with a 1" Roger Brown body lift, Donahoe or Total Chaos control arms, bigger & better tires after the lift, A rear protection bar and Reverse sensors, or a backup camera.
12-26-2005, 11:27 PM
i have LEDs on my signal tail light. and it looks pretty good. it's RED though but i'm pretty sure they sell them with amber. but of course you could always make your own. buy 7-8 LEDs, resistor, and a chip to make it blink however fast you want it to blink.
12-28-2005, 12:00 PM
I have them. NO, LED is just tail/stop part.
12-28-2005, 12:57 PM
Well, you could have it for the front bumper signal and maybe corner lights if it fits. My big sister got hyper white LEDs on her Honda Accord's corners, which is illegal so she took it off. But you could put LEDs wherever you please but sometimes it's not legal.
12-28-2005, 01:09 PM
Yes, that the only way to do it - put aftermarket LED replacement bulbs, but do not forget to add parallel resistors to the circuit.
The original question was if Toyota OEM LED tails has LED turn signal - answer is no. Here is the link to my LED retrofit: LED Tail Lights
12-28-2005, 07:02 PM
Real Name: Karl
Real Name: Karl
mmmmm . . . . not so sure they will. I installed them into my rear fog lights and they work as blinkers, but if I wire them up to the parking lights, then they screw up. I think you'll find that you need the resistors that they sell as well. Let us know how it works out.
12-29-2005, 12:28 PM
It depends of setup you are in. If just replacing regular turn signal bulbs in tails to LED, you will need 3Om resistors on each one. If you doing rear fog light mod, there is two ways. First: tails/brake - connecting to tails - LED works fine (I personally have this one and it works great with red LEDs). Second: tails/brake/turn - connecting to towing wiring - LED might not work well due to low resistance. In this case you might add some resistors to turn wiring or find relay which switches the signal from brake to turn.
01-02-2006, 03:09 AM
Registered User
Registered User
I ordered the amber lights for the tail lights on my 1st Gen does anyone know what size resistor would work. I know they sell a kit that is about $10 but, if its only a resistor and they sell 10 packs at the local computer store for about $3. Maybe its just me being cheap but wouldn't one of those do the same thing? If so, can anyone tell me what size resistor to use?
HTML code is Off
