Old 01-13-2014, 08:01 AM #1
Swimmerboy2112's Avatar
Swimmerboy2112 Swimmerboy2112 is offline
Swimmerboy2112 is on a distinguished road
3VZ-FE cams in the 5VZ-FE
In the never ending search to find ways to modify my trucks, I stumbled across the 3VZ-FE cam swap.
Supposedly the 3V-FE cams swap right into the 5VZ-FE. Based on the way these cams are ground, I should gain a good deal of mid range to top end power without losing much if any low end power.
Supposedly these cams make that much more if you're supercharged which I am.
There are a few threads of people talking about this but so far I cannot confirm anyone has actually done this. It seems as I will be heading into uncharted waters.
About shimming the cams, it makes most sense to me to shim these for the 3VZ-FE not the 5VZ-FE.
Just looking to bounce ideas off someone who knows their stuff.
Aftermarket cams for the 5VZ-FE are around $1000. Hopefully this will be a cost-effective alternative.
Off to the junkyard this weekend in search of a 92-93 Camry/ES300.
-Brian
Swimmerboy2112 is offline   Reply With QuoteReply With Quote
Old 01-13-2014, 07:21 PM #2
No one?
Old 01-14-2014, 10:14 AM #3
Bump!
Old 06-24-2014, 07:51 AM #4
Robb235's Avatar
Robb235 Robb235 is offline
Real Name: Robert
Robb235 is on a distinguished road
MY GARAGE
Robb235's Avatar
Real Name: Robert
MY GARAGE
-Brian
Did you ever try this?
1999 Toyota 4Runner Limited 4x4 - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - Lifetime LED Headlights - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2003 Yamaha R6 - My speed machine
Robb235 is offline   Reply With QuoteReply With Quote
Old 07-04-2014, 07:54 AM #5
Never got a chance to, kinda don't want to be the ginuea pig either...
1997 4Runner - converted to 5 speed, TRD supercharger, 3" lift, 285/75/R16 BFG A/T, stealthbox sub, etc.
Old 07-04-2014, 11:11 AM #6
T4R2014's Avatar
T4R2014 T4R2014 is online now
T4R2014 has a spectacular aura about T4R2014 has a spectacular aura about T4R2014 has a spectacular aura about
T4R2014's Avatar
I have seen this posted a bunch of times over the years, yet no one has actually attempted it. You may end up being the guinea pig on this one. I would look forward to seeing the results if you do attempt this.
T4R2014 is online now   Reply With QuoteReply With Quote
Old 07-15-2014, 11:27 PM #7
xcmountain80 xcmountain80 is offline
xcmountain80 is on a distinguished road
MY GARAGE
MY GARAGE
I'm interested but just N/A.
xcmountain80 is offline   Reply With QuoteReply With Quote
Old 04-19-2017, 01:09 PM #8
TRDHybrid TRDHybrid is offline
TRDHybrid is on a distinguished road
Well i did
Three days ago i finally found cams out of a 93 camry, tackled the project in my back yard in one day, shimmed to 5vzfe specs, and only needed to change 3 of the exhaust shims all others we're in spec. As i am sc'ed loss of low end torque is not noticeable but mid and high is deff. Noticeable increase. I have a 98 limited 178k on clock and runs just as smooth as my rx450h. I did notice im running 190 deg f now as before was 183 with a 180 stat. I prob iv had since i purchased is from 50% throttle to 90% its lime the timing is hunting but full throttle its fine, any thoughts? During the cam install i replaced the knock sensor harness. It did this hunting thing before the cams swap and before the sc was installed by me. Thoughts?
TRDHybrid is offline   Reply With QuoteReply With Quote
Old 05-05-2017, 08:58 AM #9
Robb235's Avatar
Real Name: Robert
MY GARAGE
Robb235's Avatar
Real Name: Robert
MY GARAGE
That's awesome that you did the swap. I think you're the first person to actually go through with it.
Old 05-12-2017, 07:15 PM #10
RAHagen RAHagen is offline
RAHagen is on a distinguished road
Awesome! Obviously new to the forum as you can see by my post count(1), but those are some neat results! Out of curiosity, how is your fuel economy after the swap?
RAHagen is offline   Reply With QuoteReply With Quote
Old 04-09-2018, 07:56 PM #11
jerrydub10 jerrydub10 is offline
Real Name: Jerry
jerrydub10 is on a distinguished road
MY GARAGE
Real Name: Jerry
MY GARAGE
Sorry, I know this post is old, but im about to rebuild my engine after cracking a cylinder due to my inexperience and lack of tuning knowledge after a turbo install. are you still running the 3vz-fe cams? and if so how are they holding up?
jerrydub10 is offline   Reply With QuoteReply With Quote
Old 04-14-2018, 03:13 AM #12
Lefty JD's Avatar
Lefty JD Lefty JD is offline
Lefty JD is on a distinguished road
Lefty JD's Avatar
Originally Posted by jerrydub10 View Post
Sorry, I know this post is old, but .....are you still running the 3vz-fe cams? and if so how are they holding up?
THIS. We all need to know!
Sent from my iPhone, so probably some stupid typos and autocorrects
'97 3.4 Supercharged+URD 7th
Front: Fox 2.5 resi's Rear: 861/bilstein
255/85 D/C Extreme Country's, e-locker retrofit
Addicted Hybrid front bumper, M8000
Savage Rear Bumper/Tire carrier, skids and sliders
Lefty JD is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 09:01 PM #13
DrewZ28's Avatar
DrewZ28 DrewZ28 is offline
Real Name: Drew
DrewZ28 is on a distinguished road
MY GARAGE
DrewZ28's Avatar
Real Name: Drew
MY GARAGE
Old thread, but did you swap all 4 cams from a 3vz-fe or just the exhaust cams? I'm researching this swap now.
97 4Runner Limited, Desert Dune with Rear Locker
OME 881/891 springs with Bilstein 5100 shocks
Goodyear Duratracs LT265/75R16
DrewZ28 is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 06:32 PM #14
gamefreakgc's Avatar
gamefreakgc gamefreakgc is online now
Real Name: Jerod
gamefreakgc is a jewel in the rough gamefreakgc is a jewel in the rough gamefreakgc is a jewel in the rough
Real Name: Jerod
You swap all 4. If you did only exhaust, the valve timing would be thrown off and you might have too much overlap (exhaust open before ignition completes) which will result in a loss of power, not a gain.
This swap is about taking cams from a higher revving engine that makes power on the top end and trading it for power on the bottom end. This is just the stock stats for the engines and how they are tuned:
3VZ-FE: 188 HP at 5200 rpm and 203 lb⋅ft at 4400 rpm
5VZ-FE: 183 HP at 4800 rpm and 217 lb⋅ft at 3600 rpm
Looking at the two engines, you might say the are almost identical in power output. But let me ask you this, how much time do you drive your 4Runner over 5000 RPM's, let alone 4000 RPM's? A torque curve that comes in faster, in the 3000's is better than one that comes in the 4000's. Torque is what you feel on the road, HP is just a multiplier of torque, (RPM * TQ) / 5252. Even I don't spend that much time over 3600 RPM's.
This is why the 3VZ-FE camshaft swap has little to gain but much to lose. You'll gain a bit of HP up high but you're losing TQ where you use it the most everyday. I'm one of the few that has swapped out cams, and it cost me and engine but hey, learned something new.
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
gamefreakgc is online now   Reply With QuoteReply With Quote
Old 08-06-2019, 05:20 PM #15
Daluvian Daluvian is offline
Daluvian is on a distinguished road
I heard of something like this but I thought it was the complete heAd?
Daluvian is offline   Reply With QuoteReply With Quote
HTML code is Off
cams?? 924runnerSR5 Classic T4Rs 11 05-19-2011 09:12 PM
AfterMarket Cams For 3VZ? K_Labs Classic T4Rs 2 11-28-2010 11:49 PM
Cams Cbpcop06 3rd gen T4Rs 2 09-18-2009 12:16 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
