02-06-2006, 04:51 PM
#16
I don't have a skid plate. However, I could access that bolt from under the truck. I just laid on my back and looked up, and there it was. You shouldn' t need to remove anything. I hope this helps.
2005 Black Sport Edition 4x4
Magnaflow Catback exhaust,rear lens mod, fog light mod, T4R.ORG sticker, Hella FF50 driving lights, Alpine 9857 HU, Sirius, Infinity Reference 6.5" components, Ample Audio Exonic amp 60 x 4, Alpine 350 amp powering an L5 solobaric 10" square subwoofer sitting in a custom TRD stealthbox
red map lights, Overland Warehouse 2.0 3"lift, Cooper STT 285/70/17's
Valentine One Radar Detector with concealed display
02-27-2006, 10:23 AM
#17
I have just ordered a light bar from "stylin concepts" which is a light holder that attaches where the license plate attaches. The fog or driving lights attach there:
http://www.stylinconcepts.com/part.a...48/Category/25
It should save a lot of drilling. I plan on attaching a set of HID driving light to it:
http://www.sylvania.com/ConsumerProd...XenarcKits.htm
Total cost will be less than $400 and it should be an easy installation. I also found the wimpy stock "foglights" worthless. I hope this mod works out. Just in case it does, I will take photos. Everyone here has been very helpful, so maybe I can contribute something. Wish me luck!
02-27-2006, 10:34 AM
#18
Let us know how that works out for ya. I'm not sure if the plastic bumper on the 4th gens will be able to hold up the weight of large lights. On mine, the license plate is held up by two screws. Also, I'd be hesitant to put an expensive set of lights like those on the front without any protection.
02-27-2006, 11:19 AM
#19
sharp4runr-
I agree. I don't have the light bar yet and will make sure it is right before i order the lights. I may even drive around with it for a while to test it. Running over $300 in lights would make for a very bad day! I'll let you know. If I'm not 100% confident I'll go with one of the "bull" bars.
03-03-2006, 10:55 AM
#20
Installation complete and easy. I'm having trouble downsizing the photos to show up here. Still working on it......
03-26-2006, 06:29 PM
#21
is there a specific tool to turn those aiming wheel (or gears) it hurts when i turn them with my finger. if so, where can i find one?
03-26-2006, 07:26 PM
#22
hey tks! i just aim my up and it look 10x better!!! now you can actually see the fog at night in front of you!!
2004Runner SE 4WD
Natural White
________________________________________
Factory Option:Sunroof,Valor Tip,Double Deck Cargo,Rear Spoiler,DRL,Electrochromatic Mirror,Leather
Mods:Limited Sliver RB,OEM All Weather Mats,(F)Stainless Steel Door Sill,TRD Badge,20% Tint,SuperBrightLeds.com(6)White LEDs: Dome/License/Doors/& Map Light,Custom TRD License Plate Frame,Alpine IVA D900,7"VizuaLogic ADV. LC Headrest Monitor,Escort 8500 X50 w/ Custom Mounted Smart Cord,115v switch w/ X-Power 150W Inverter,G2 Sliver Painted Caliper,REVO 265/70/17,Rear Parking Light Mod,PAC SWI-ALP,OBX Sport Pedal,Ashtray&Lighter Kit,06 LEDs Taillight,55w yellow Foglight bulbs, McCulloch 6000k HID headlight
03-27-2006, 11:06 AM
#23
Glad i could help!!
All of the bolts in our truck (in my experience) has been between a 8mm and 14mm. I think that the aiming bolt is a 8mm, but it has been a while since I did this. It is just a bolt, so no special tools are required.
03-27-2006, 11:26 AM
#24
8 mm socket or wrench on the bolt in the center.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
03-30-2006, 04:19 AM
#25
thanks for the info.
for low beam aiming, clockwise lowers beam pattern and counter clockwise raises beam.
04-16-2007, 11:46 PM
#26
if your interested i just ordered pure yellow bulbs for my fogs...ill post pics when i get them installed. They are supposed to reduce glare in fog and are "30%" brighter than stock
2004 T4R Limited
04-08-2008, 02:26 AM
#27
Can you post some pics and tell us how esay it was to install these? I was thinking about getting them too.
I live in an area of California that gets so foggy sometimes, you can barely see the end of your hood, and your door is open so you can follow the yellow dashed line. One time I opened my drivers door and saw a solid WHITE LINE. My heart about stopped as I knew I was on the wrong side of the country road!
I honestly have never thought fog lights really helped much. Perhaps a 5%-10% increase but what kind of increase in visibility are you going to need to avoid wrecking? A lot more than 10% I'm sure. Sure, maybe the 10% will allow you to drive faster which means you'll get home about 20 seconds earlier than normal?
08-09-2008, 10:54 PM
#28
Did this today.. wow what a difference. I took a sharpie and marked the wheel so I would know exactly how many turns I made. Ended up with 3 complete turns of the wheel to get the right aim point... wow what a difference. Highly recommend doing this. Lo's and Fogs used to be separated on the road in front.. now its one solid wide path of light.
Also did the mode to Fog Relay to make them work with the parking lights, lo's and hi beams... but still allow the factory switch to control on/off on the stalk. Looks great at night now. Thanks guys.
09-20-2008, 12:05 AM
#29
What is this, if you dont mind me asking? Could you send me a link to this please.
04 SR5 4x4 v6
Urban Runner Bars & Rack-2/3 CF Lift-HID Converted Head/Fog Lights-JDM Taillights-Misc parts 18" Helo HE835 Black/Polished Wheels 265/70/18 Nitto Terra Grappler Tires
09-21-2008, 01:55 PM
#30
Super Moderator
Super Moderator
From member J.A.'s personal site.
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
HTML code is Off
