Old 09-22-2008, 04:11 PM #31
BullDawg BullDawg is offline
BullDawg is an unknown quantity at this point
There are several variations to the way you do this mod for the foglights. I suggest you read this thread...
http://www.toyota-4runner.org/showth...?threadid=8435
JA's method can be changed so that the fogs will come on a.) any time car is cranked b.) only when parking/head lights are on or c.) any combination with the fog light switch on the stalk with either a or b. Just a matter of where you hook the fog relay power on the pin. It really is easy just take plenty of time to decide which way you want them to work before you start and its straight forward. check it out.
BullDawg is offline   Reply With QuoteReply With Quote
Old 12-21-2008, 12:58 PM #32
cmb cmb is offline
cmb is an unknown quantity at this point
cmb cmb is offline
Has anyone had the chance to compare the Hoen fog lamp bulb to the Hella? Wondering how much difference there is before I order one or the other.I've heard from others that bulbs can't be returned after they're opened....?
cmb is offline   Reply With QuoteReply With Quote
Old 12-26-2008, 12:44 AM #33
ALLEGRO's Avatar
ALLEGRO ALLEGRO is offline
ALLEGRO is on a distinguished road
ALLEGRO's Avatar
After driving in significant fog this week, I notice that the projectors for the low-beam on my 07 are too high for use in that much soup. I wish there was a mod to have the foglights on WITHOUT the low-beams. That way all the light, the only light, would be coming from down low.
Comments?
2007 Driftwood Pearl Limited
ALLEGRO is offline   Reply With QuoteReply With Quote
Old 12-26-2008, 01:17 AM #34
Comments?
Allegro.. that is exactly what my setup did. I connected the power on for the relay to the driver side parking light.. ie anytime my parking lights are on, my fogs can be on also. By hooking the wires underneath the steering wheel that go to the stalk also, you are able to keep control of the fogs by the switch on the stalk. Using this method my fogs relay is always controlled by the parking lights (so they still turn off when the key does), but I can run 1.) only fogs and parking lights or 2.) I can run fogs and parking/low beams (OEM setup) or 3.) I can run fogs and parking/high beams together (for those dark roads at night).
Old 12-26-2008, 04:52 AM #35
ALLEGRO's Avatar
ALLEGRO's Avatar
Well hook a fella up on the "how to" of it all.
Old 12-26-2008, 09:53 AM #36
You will need to do a little reading most likely but essentially this is the method I followed:
http://www.top4runners.com/ja/2007/fogmod.html
Only modification I made to JA's solution was in the relay power on pin 2 of the fog relay. JA pulled power for the fog relay from an "always on" source in the relay/fuse box (truck is on, fogs work all the time). I ran the wire from pin 2 of the relay out to the drivers side running light with a T-connector (so that only when the running lights are on, power is sent to the fog relay and fogs can only come on when running lights are on, which are on all the time with any other combination of hi/low/off headlights). I followed the same procedure for the C-12 connector in JA's write up on the stalk. He already has a good write up so give it a good read thru and it has plenty of pictures and wiring diagrams to.
this is the thread I started reading when I modded mine. I may even be the last poster in the thread. JA's solution is pretty much the entire thing but others have changed it slightly and offer options. Just make sure how you want them to work and make it happen.
Good luck. Let me know how it turns out.
Old 01-10-2009, 11:04 PM #37
ALLEGRO's Avatar
ALLEGRO's Avatar
Well I have to agree with just about everything on this thread. You need to raise you Fogs quite a bit to make them more effictive, and EVERYONE should do both mods for keeping the fogs on.
The only change I made in Mod 1, was that I got my power for the fogs from the parking light bulb harness (green wire). I still used the #2 pin from the Fog Relay, but made an 18" jumper that ran behind the battery and to the drivers park light harness. What this does is have the lights come on ONLY when the light switch is in the Park or Headlight position. This is different than getting Fog power whenever the ignition is on. Still have control of the Fogs on the stalk, same as OE.
I wasn't too crazy about completing Mod 2, but decided to try it as I could always remove the spice. I do like it much more than I first thought. You get both Hi and Lo beams, plus the Fogs when on bright (all lights are on!). Very full light pattern from close to far.
Old 10-08-2009, 11:14 PM #38
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Originally Posted by Jacobzky View Post
is there a specific tool to turn those aiming wheel (or gears) it hurts when i turn them with my finger. if so, where can i find one?
The picture suggests that these work the same way as the headlights. If you slide a Phillips screwdriver in sideways through the channel in the housing, the teeth in the driver will engage the teeth in the aiming gear. I don't have the stock fogs, but this technique works great on the headlights which are built the same way.
My Backyard Frame Swap
Old 12-08-2009, 11:56 AM #39
hulk311's Avatar
hulk311 hulk311 is offline
hulk311 is on a distinguished road
hulk311's Avatar
How exactly would you aim these lights?
Toyota 4Runner SR5 Micro DE Fog Lamp Kit
I'm thinking of buying that and putting HIDs in.
'97 4Runner Limited
▌Fully loaded Locking Rear diff. Retrofit HIDs 265/75R16 Michelin LTX M/S2 OME 2.5" Lift ▌
hulk311 is offline   Reply With QuoteReply With Quote
Old 02-20-2010, 05:56 PM #40
rolla_dink rolla_dink is offline
rolla_dink is an unknown quantity at this point
you can also use a phillips to adjust. I know it sounds funny but there is a groove that allows you to fit a #2 head phillips in there and turn. Same goes for the headlights, at least on my corolla.
as for the foglight control on the stick I have it on my corolla as well. My fogs are independently controlled on the stick and can be on or off with the highbeams.
2003 Limited V8
TRD SC - Removed
Waag Grille/Tails
Revo 265/70 17
Denso HID Conversion Low Beams
Silverstar Fogs
JAOS Catback Exhaust
Volant CAI
Click here to Listen Supercharged-4Runner-and-JAOS-Exhaust-Audio-Only
See My 9th Gen Corolla
http://www.cardomain.com/ride/694320/
rolla_dink is offline   Reply With QuoteReply With Quote
Old 08-17-2010, 01:20 PM #41
MaliciousClout's Avatar
MaliciousClout MaliciousClout is offline
MaliciousClout is on a distinguished road
I'm getting ready to aim my fogs-
Does anyone know it there is a left to right adjustment or is it just up or down?
Thanks
MaliciousClout is offline   Reply With QuoteReply With Quote
Old 03-21-2012, 10:08 AM #42
jshill jshill is offline
jshill is on a distinguished road
fog light aiming and new fog/driving lights
I know that the fog lights are adjustable on my 2003 Sport Edition. I cannot find the directions, but a web search should come up with something. I researched this and adjusted mine shortly after buying it, but don't know where I put the directions. IT CAN BE DONE.
jshill is offline   Reply With QuoteReply With Quote
Old 12-05-2014, 11:29 PM #43
toyo's Avatar
toyo toyo is offline
Real Name: Steven
toyo will become famous soon enough
toyo's Avatar
Real Name: Steven
Here is the procedure for adjusting the headlamps on a 2008 4Runner.
2008 4R LTD V8 4WD, ICON Stage 3, TRD Pro Wheels, GOBI Rack, TRS HID Swap along with too many other mods to list here!
toyo is offline   Reply With QuoteReply With Quote
Old 12-05-2014, 11:31 PM #44
toyo's Avatar
Real Name: Steven
toyo's Avatar
Real Name: Steven
Here is the Fog Lamp aiming procedure.
Old 01-17-2016, 01:59 AM #45
That_One_Guy That_One_Guy is offline
That_One_Guy is on a distinguished road
I didn't know where else to post this so, I was looking to buy a 42" curved LED light bar for my 1995 4Runner and I was wondering if anybody knows of a cheap (<$50) set of brackets so I don't have to drill into my roof?
That_One_Guy is offline   Reply With QuoteReply With Quote
HTML code is Off
