Old 07-10-2006, 02:08 PM #31
UoD's Avatar
UoD UoD is offline
Location: Charleston SC / Tallahassee FL / Daytona Beach FL
UoD is an unknown quantity at this point
UoD UoD is offline
UoD's Avatar
I think I know which wires I need to tap into now ... but, I have not had any time to mess with it yet.
I did not notice any increase in the sound quality after installing the 06 unit.
Titanium 2005 4Runner Sport V8
*Replaced '05 JBL headunit with '06 JBL headunit
http://www.psy.fsu.edu/~thornton/4ru...ld-and-new.jpg
UoD is offline   Reply With QuoteReply With Quote
Old 07-10-2006, 04:01 PM #32
santana's Avatar
santana santana is offline
santana is an unknown quantity at this point
santana's Avatar
yeah ive been pulling my hair out trying to figure out which wires i need to splice to get the aux working. i dont have the 06 unit yet. but i might consider doing this to my 05 jbl. if you have any ideas i would appreciate it.
i even considerd modifying the tape deck. the head that reads the magnetic strip has a left and right channel just like every tape unit out there. trick would be just to solder the head off and add some RCA female ends to it. then all i would have to do is hit tape and i would have whatever input.
2005 4runner SE V6
santana is offline   Reply With QuoteReply With Quote
Old 11-22-2006, 10:55 AM #33
bcnland bcnland is offline
bcnland is an unknown quantity at this point
AUX?
Hello!! Did you ever figure out how to get the AUX function to work on the 06 JBL unit? I just purchased a unit and will upgrade from an 05 6-dics JBL to the 06. Thanks,
bcnland is offline   Reply With QuoteReply With Quote
Old 11-22-2006, 11:00 AM #34
UoD's Avatar
UoD UoD is offline
UoD UoD is offline
UoD's Avatar
I have yet to get a chance to tear everything apart and start figuring everything out. I think I know what I need to splice into ... and I think it can be done with about $10 worth of parts from radio shack. Sorry I have been dragging my feet on this --- work got really busy back in July and has not slowed down since. I will get to it around the holidays when things calm down.
Old 12-25-2006, 09:14 PM #35
RevoRunner's Avatar
RevoRunner RevoRunner is offline
RevoRunner is an unknown quantity at this point
RevoRunner's Avatar
A little off subject
I'm interested on the turn out for this one as well. Sorry to get a little off subject. I searched the forums as much as I could but didn't find a definitive answer. It's pretty apparent that the 06 JBL 6 disc will work with an 05... my question is, I have an 04 JBL 6 disc and was wondering if the 06 model would work/fit?
Thanks for any help. Santa brought me a Sirius Sportster 4 so I'm looking at different scenarios for an install.
Black 2004 Limited 4WD V8
RevoRunner is offline   Reply With QuoteReply With Quote
Old 08-22-2007, 04:13 PM #36
dai_lo dai_lo is offline
dai_lo is an unknown quantity at this point
Did you find the AUX cable for the headunit? Or did you get a chance to figure out how to add an AUX in? I just purchased an 07 jbl unit for my 05.
dai_lo is offline   Reply With QuoteReply With Quote
Old 05-03-2008, 07:05 PM #37
meljunew meljunew is offline
meljunew is an unknown quantity at this point
Anyone know the model numbers of either the 2006 or 2007 JBL 6 disk head unit? I currently have the 2005 JBL 6 disc and it's not working. I don't want to get an aftermarket stereo, can't find any on ebay and want to do a search by model numbers on the internet. Click the link to see what the problem is with my current system. If anyone is selling a 2006 JBL or 2007 JBL 6 disk head unit, please let me know. Thanks!!
http://s33.photobucket.com/albums/d6...t=P1040589.flv
meljunew is offline   Reply With QuoteReply With Quote
Old 05-03-2008, 09:03 PM #38
drmorbius's Avatar
drmorbius drmorbius is offline
drmorbius is on a distinguished road
drmorbius's Avatar
It kind of looks like there is something keeping the drive spindle from coming all the way up through the hole in the disk so the disk can't come up to speed and just slips. There are three little clamps arranged in a triangle and they should go through the disk and then move out against the center hole in the disk. Instead the disk is just sitting on top of them. Try pushing them in toward the center. I think you can turn off the key while the spindle is up so you can work on it.
Larry
"Monsters From the Id"
2004 SR5 V6 Titanium Metallic/Stone, Auto Dimming Compass Mirror, Valor Tip, Overhead Console W/HomeLink, Cargo Net, Michelin Cross Terrains, Added JBL Synthesis 10 speaker system 6/08, USA Spec PA-15 TOY Ipod Interface, Drivers Side Overhead Handle, Valvoline Synpower 5W-30, Mobil 1 75W-90, LEDs
drmorbius is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 10:59 PM #39
EvanSun's Avatar
EvanSun EvanSun is offline
Real Name: Evan Sundgren
EvanSun is on a distinguished road
EvanSun's Avatar
Originally Posted by UoD View Post
Well --- ERROR 3 just means that the changer is jammed. Surprisingly, these head units are very easy to get inside of. If you remove the top two screws on each side, you can remove the top plate. Here are some pics :
THE YELLOW ARROWS SHOW THE LOCATIONS OF THE SCREWS THAT NEED TO BE REMOVED. THIS NEEDS TO BE DONE ON BOTH SIDES OF THE UNIT. (The screws were already removed in this picture).
GIVE THE BACK OF THE TOP PLATE A LITTLE TUG AND IT WILL UNLATCH. PULL UP AND THEN TOWARDS THE BACK OF THE UNIT.
Ok --- So, in my case there were actually two things causing the ERROR3. The first was the fact that the previous owner left two jammed CDs inside of the thing. One disc was in slot 3 and the other disc was jammed in between slots 2 and 1. This in turn cause the second problem --- the laser that moves between the discs also got jammed when trying to get around the jammed disc.
Removing the jammed disc wasn't too bad. I brought the unit back out to the car and plugged it in with the cover off. I held down the eject button while pushing on the jammed disc and it managed to jump back into place and eject without a problem. Once the disc was ejected, I was able to move the laser back into place. Its hard to illustrate this with a picture... but I will do my best.
THE YELLOW ARROW IS POINTING TO THE LOCATION OF THE LASER ARM. THIS WILL SOMETIMES GET STUCK WHEN TRYING TO RETURN TO ITS DOCKING POINT. WITH THE UNIT TURNED ON, I APPLIED PRESSURE TO THE LASER IN A DOWNWARD MOTION AND THIS ALLOWED IT TO JUMP BACK INTO PLACE.
So --- unit is working now.
So... Uod, I know this is a really old thread, but I just purchased a similarly aged 2006 T4R with the same jammed CD player problem. Any chance of reposting the pics for me? Links to them are no longer any good. FSU ditched them.. Thanks!
Moonshadow: 2006 UnLimited VVT-i V8 RWD Titanium Metallic, Stock
Every time I step on the gas it makes me smile.
EvanSun is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 11:26 AM #40
EvanSun's Avatar
EvanSun's Avatar
SUCCESS!!!!
CD's stuck in the changer!!
I'm still interested in learning how to take the face plate off of the head unit Uod if that's easy for you. Otherwise.. Content to cruise with just good luck.
HTML code is Off
JBL in dash 6changer 2005 CookieRoe Classifieds - buy & sell (no commercial ads please) 0 06-20-2010 12:37 AM
OEM 2006 CD player non jbl purrfactor Classifieds - buy & sell (no commercial ads please) 3 01-11-2010 08:12 PM
Plug and Play adapter for installing Aftermarket radio in JBL equipped truck.... MercuryEvo Classifieds - buy & sell (no commercial ads please) 2 08-24-2009 01:12 AM
2006 Sport owners - Does anyone have a single-disc 10 speaker JBL system? Cobra Kai 4th Gen T4Rs 12 12-08-2006 11:26 AM
2006 Jbl And Xm? scott-s1 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-22-2005 06:00 PM
