Originally Posted by dodder
Our V8's are 2.5" center in offset out, That does not seem to be an option on this muffler, did you buy a different configuration and have the stock pipes ran to the different configuration?
Right, 2.5" isn't an option if you want center in/offset out. So I bumped up to the 3". Still worked great for the exhaust shop and doesn't restrict flow any over stock. I got the center in/offset out. I confirmed with Dynomax that you can run the muffler with the offset end coming out on either side. They just said to not run the muffler "on it's side"...it needs to be mounted with one of the wide sides facing up/down.
