Another angle.
You may notice I installed the HID bulb into the headlight housing during this step. When you do this, be careful not to touch the glass bulb, as your skin oils will cause the bulb to fail early. If you accidentally touch it, wipe the glass with alcohol to clean it.
After twisting the bulb into the housing, move the two wires out of the way. You will connect these later.
