Originally posted by sharp4runr
There was a member who pulled the bulb for the light in the dash. Do a search.
You found him. It takes a little effort because you need to remove the instrument cluster to get to it. Start by removing the lower panel below the steering colum 2 bolts, pull the middle panel also two bolts (I believe) and you will see how the intrument cluster is mounted. Luckily the wiring was long enough to pull the cluster far enough forward so you don't have to disconnect anything. The light will pull out with a little effort.
