Old 07-26-2014, 08:35 AM #16
alexb's Avatar
alexb alexb is offline
alexb is on a distinguished road
alexb's Avatar
Originally Posted by Desert Dawg View Post
I was struggling with this too but I just fitted a Cooper ST MAXX LT255/80R17 onto the factory spare rim and location; fit just fine!
That's great news. I'll be picking one up eventually to do the same.
It seems like my MPGs have started to even out since getting these. Averaged 17.5mpg on a 2 hour trip to the lake at 75-78mph yesterday.
Another great thing about the skinnies, max stuffage and no rubbing.
'14 Trail Super White|Nav|Tint|EnTune|Toytec BOSS Kit|Konig Countersteer Type X Matte Bronze 17x8"|Cooper Discoverer ST Maxx 255/80/17|SPC Light Racing UCA's|WeatherTech|4300K HID's|Valentine 1|White Knuckle Offroad Sliders|GOBI Stealth
Build & Photo Thread
alexb is offline   Reply With QuoteReply With Quote
Old 07-26-2014, 12:29 PM #17
Desert Dawg's Avatar
Desert Dawg Desert Dawg is offline
Real Name: Paul
Desert Dawg is on a distinguished road
Real Name: Paul
17.5 mpg average at that speed with the larger meats is not bad at all. Glad the new tires are working out! I really like mine too but still have another week for my first long trip and so will see how they do.
Previous 2014 4Runner Build Thread: http://www.toyota-4runner.org/5th-ge...at-switch.html
Desert Dawg is offline   Reply With QuoteReply With Quote
Old 07-28-2014, 08:56 PM #18
alexb's Avatar
alexb's Avatar
Finally got a chance to get off the pavement and test out the Coopers. Didn't get too far out there, but did get on some decently challenging terrain to test them on. First impressions they did fantastic. Most of the terrain was loose rock and some dirt that they plowed right over. The few places I got stuck momentarily then used the terrain select and diff lock and powered right on through. Did a few water crossing that felt solid as can be, one area the depth was just up to the rocker panels. This was all at 40psi, I imagine the grip will be even that much better aired down on the Coopers.
Enjoy some pics
And Tucker enjoying a nice dip in the river
Old 07-28-2014, 09:30 PM #19
Desert Fox's Avatar
Desert Fox Desert Fox is offline
Real Name: Bill
Desert Fox is on a distinguished road
Desert Fox's Avatar
Real Name: Bill
I canweigh in on a user test report.
I installed a set prior to the FJ Summit in Ouray.
The 2 trails that tested the tires are Black Bear Pass and Poughkeepsie Gulch. Both trails are similar but very different.
Black Bear Pass is a high, steep narrow trail on loose shale rock. Not so much as far as rock obstacles but a lot of loose stuff.
Poughkeepsie Gulch is rock from the start to the finish. Loose rock, rock obstacles, wet rock, dry rock moving rock and more rock. The mail trail is paver size rocks with water runner the rocks.
Tire pressure on Black Bear Pass was 22 pounds. No side wall flex was noticed.
The tires held extremely well. This trail seemed to me to be a very easy trail. The Coopers had to have something to do with that. I had no concerns on the tires holding the trail on all that loose shale.
Tire pressure on Poughkeepsie was 18 pounds. No side wall flex was noticed. I think I could have gone down to maybe 12 pounds with no problem.
The Coopers performed excellent again. Slipping rocks on the trail was hardly noticed. Obstacles on the trail were traversed with ease and some were challenging to all vehicles.
Climbing the wall. I did not approach the wall at the optimal line and I dropped my passenger rear tire into a hole. This caused some loss of traction and some spinning both front and rear occurred. After placing some well positioned rocks under the front tires the wall was traversed with ease.
Post trail run check. There is a small amount of cutting on the top tread but very small amount and given the tire slashing environment that Poughkeepsie Gulch is I consider this nothing. No sign of damage to the side walls.
No mud trails and not enough snow to comment on.
Wet pavement traction was excellent. At 70- 80 the tires seemed to float a little but I do not think these tires are made for that speed. Coming back over Monarch Pass the tires cornered well and held the road well but I did feel a little untrusting going top speed around tight curves.
The only negative I have for these tires is getting them balanced. It took 3 times of balancing to get them correct. They are fine now but I did have to request a Road Force balance.
I purchased the tires from Discount Tires. Discount is great to work with at all levels.
Bottom line.
For off-roading I have run Goodyear Duratrack, Silent Armors, Pro Comp AT tires and Hankook Dynapro. Out of the group the Goodyear Silent Armors and Copper ST Maxx are equal in my perspective.
Before buying the Coopers I had the Hankook Dynapros with 80% tread life left. I did not need to change tires but I wanted to try out the Coopers on the trails in Ouray and I wanted the tire warranty that Discount Tires provides.
I am happy with changing out the Dynapros to Coopers.
I pledge allegiance to the flag of the United States of America, and to the republic for which it stands, one nation under God, indivisible, with liberty and justice for all.
Desert Fox is offline   Reply With QuoteReply With Quote
Old 07-28-2014, 10:19 PM #20
Real Name: Paul
Real Name: Paul
@alexb and @Desert Fox ; great updates, thanks! I can't wait to try mine out!
Old 07-28-2014, 10:22 PM #21
Desert Fox's Avatar
Real Name: Bill
Desert Fox's Avatar
Real Name: Bill
@alexb and @Desert Fox; great updates, thanks! I can't wait to try mine out!
It would be good to see your 4Runner in Ouray at the next FJ Summit, you are not that far away.
Old 07-28-2014, 10:26 PM #22
Real Name: Paul
Real Name: Paul
Yeah, my brother has a FJ and wants to go with me too. Just might do it! Thanks!
Old 07-31-2014, 01:26 PM #23
TOYOTA_YV TOYOTA_YV is offline
TOYOTA_YV is on a distinguished road
Exclamation
Originally Posted by cleveland48 View Post
Have you tried to fit one of these in the spare location yet? Curious if it will work.
I have the same size but in BF MT KM2... (spare tire included) and NO PROBLEM... They fit perfectly!... But now, I'm using my truck 99.99% street, now I want those...
Cooper Discoverer ST Maxx 255/80/17 Skinnies-20131116_173603-jpg
TOYOTA_YV is offline   Reply With QuoteReply With Quote
Old 09-07-2014, 10:20 PM #24
4runner4MeCarp 4runner4MeCarp is offline
4runner4MeCarp is on a distinguished road
Did you keep your toytec coilovers set at the factory shipped setting or did you adjust? I'm about to install the Boss kit myself and I really like your truck's stance. I also purchased the S/T Maxx 255/80-17's.
4runner4MeCarp is offline   Reply With QuoteReply With Quote
Old 09-07-2014, 10:43 PM #25
alexb's Avatar
alexb's Avatar
Factory shipped settings. Thanks! You'll love it!
Old 09-18-2014, 08:01 AM #26
Oeconomia's Avatar
Oeconomia Oeconomia is offline
Oeconomia is on a distinguished road
Oeconomia's Avatar
I didn't go through your whole build... But can I ask?
Did you do any trimming, mud flap removal, or BMC in the front for rubbing?
2014 4runner Trail Premium w/ KDSS - 255/80/17 St Maxx, Toytec Boss, TC UCA's, Astro Start, TRD Logos
BUILD THREAD HERE
Oeconomia is offline   Reply With QuoteReply With Quote
Old 09-18-2014, 08:43 AM #27
alexb's Avatar
alexb's Avatar
I have not. With the stock wheels there was no rubbing, but with my Konig's the driver side rubs the mudflap slightly when turning at low speed. I haven't tried to remove them yet since it's pretty minor.
Old 09-18-2014, 08:57 AM #28
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
And slightly less weight per tire.
Less weight per tire, less wind resistance, less rolling resistance, less wear and tear on suspension and steering components, they're better across the board.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 09-21-2014, 01:01 AM #29
Vwright14's Avatar
Vwright14 Vwright14 is offline
Vwright14 is on a distinguished road
Vwright14's Avatar
Tires look great....I ran some 33x10.50's on a lifted 2dr Jeep XJ, being swampers they were killer in the snow and awesome in mud. Never even aired them down, in 26in of snow I seriously had no real issues. I like the tall and skinniness of the 255/80/17 and may run those when its time to replace the 285/70/17's my truck came with.
2012 Salsa Red Trail with KDSS
5100's with lift,285/70/17 Duratracs,some extra wattage and speakers in the stereo system.
2003 Chevy Tahoe 4x4 - 20in Rep's, lowered and loud 4x4
2002 Ford Crown Vic Sport - new project
Vwright14 is offline   Reply With QuoteReply With Quote
Old 10-03-2014, 08:01 AM #30
emcphotos emcphotos is offline
Real Name: :: e r i c ::
emcphotos is on a distinguished road
I love the look of your rig.
How is your mpg since you have FN wheels? It is because i believe FN wheels are more light than the stock wheels. Your rig did 17.5 mpg with stock wheels and stmaxx tires, right?
| 2014 Toyota 4Runner TE Premium - Silver - KDSS | Toyotec Boss 2.5" | Total Chaos UCA | RCI Metalworks Full Skid Plates | Nitto Ridge Grappler 285/70r17" | Metal Tech 4x4 Rock Sliders | Undercover HWMS | Smittybilt X20 Gen2 |
emcphotos is offline   Reply With QuoteReply With Quote
HTML code is Off
Cooper ST Maxx or GY Duratrac typehxr1 4th Gen T4Rs 8 03-17-2014 09:59 AM
Cooper ST MAXX Anybody? TacticalSR5 3rd gen T4Rs 7 02-19-2013 02:12 PM
Cooper S/T MAXX 265/70/17 Tires aviator31 For Sale: Suspension/Wheels/Tires 4 06-09-2012 12:06 AM
Cooper Discoverer S/T MAXX connorwongtellem Engines / Suspension / Wheels / Tires / Audio / Accessories 0 04-18-2012 11:36 PM
285s cooper st maxx? Brayt4r10 5th gen T4Rs 0 12-04-2011 07:25 PM
