Thread Tools Rating: Thread Rating: 10 votes, 4.60 average. Display Modes
Old 08-18-2016, 09:23 AM #61
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
Talking
Seeing that this thread is alive and kicking, can someone confirm if the TEP wheels are lug centric? One of the earlier posts indicated that a tech claimed the TRD Pro wheels were hub centric and I thought that sounded odd if they are different from TRD to Trail.
Anyway, I am somewhat sure the Trail are lug centric. Not sure how one can inspect to make the determination.
Thanks
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 11-30-2016, 06:25 PM #62
Superposed Superposed is offline
Superposed is on a distinguished road
Tire Imbalance/Vibration
Hello, I have a 2016 4Runner TEP w/KDSS, and from day one tire balance issues.
Resolution took time, 8k miles, and collaboration with two Toyota dealerships.
One dealer did not work with me and the other one did worked with me.....
The one that did not, wasted three trips/time and wrecked (gouged) two rims (which were replaced on their dime). Third trip was to show them the proof of the issue per other dealer.
The dealer, that did worked with me, participated in the follow.
NOTE: Yes, I did spend $$$$ but only by the dealer taking responsibility and assisting me did we sort the issue...
Initially one of the Dunlop Grandtrek AT20 tires was determined to be defective and was warrantied and replaced ... Dunlop was great on this along with dealer, but still imbalance/vibration.
Moving on I tested with my 2014 FJ Cruiser's stock wheels/tires (same rims and tire (Bridgestone) dimensions as 2016, with smooth results, so not anything but wheel assemblies in play for issue.... Check!
Next, changed out Dunlop Grandtrek AT20 tires, known to be not that true/smooth a tire with new Michelin LTX tires...
Still balance issue; however, at this point I knew, as did the dealer, that something was not correct... and not with the 2016 or the tires... but their equipment.
Next, dealer had their road force balance machine re-calibrated, along with the fact that anything more than 11 to 14 on the road force balance would be felt in the truck..... One Michelin was defective due to high road force measure and was replaced under warranty.
At this point, smooth ride, but very sensitive to any rocks or such stuck in the tread, and still does have cold tire feel until tires warmed up....
Final close up test, to further flush the "sensitivity" present in the 2010-2016 4Runners (I have also a 2008 4Runner SE V6 which does not have this issue), I took the original Dunlop Grandtrek AT20 tires (from 2016 4Runner) and put them on my 2014 FJ Cruiser as the Bridgestone tires were getting down on tread.
Guess what, no issues with balance/vibration with the FJ, even when not road forced balanced...
Hope this helps others cope with balance/vibration on their 4Runners.
PS: The dealer that worked with me, communicated to me that of late they had another 2015 4Runner (having A/T tires) have the same issue. It ended up that acorns stuck in the tire treads were causing the imbalance/vibration... Amusing and again showing of the sensitivity issue....
Superposed is offline   Reply With QuoteReply With Quote
Old 12-14-2016, 08:25 PM #63
foo's Avatar
foo foo is offline
Banned
Location: USA 97 4Runner 2WD manual 150K miles 2.7L 3RZFE
foo is on a distinguished road
foo foo is offline
Banned
foo's Avatar
Just FYI, there is a thread over here where we discuss checking and adjusting static tire balance after mounting and dismounting your Toyota tires at home.
Advice requested from those of you who have mounted tires & balanced wheels at home
We cover the PRAGMATIC stuff (not theory), so, for example, we covered where to mount the red dot versus the yellow dot (depending on whether you have match mounting marks) and which takes precedence (i.e., whether the tire's high point for radial runout and radial force variation takes precedence over the tire's light spot), etc.
We also cover PRACTICAL matters such as what type of inexpensive tools to use at home and exactly what types of wheel weights specifically to buy and how to eliminate the need (if possible) for dynamic balance.
All this practical advice was compiled simply by doing three basic tasks in the home garage which everyone should be able to do for about $250 in shop tools:
1. Dismount & mount tires and valves
2. Balance (static) wheels off the vehicle and test on the road for vibration
3. Align the front camber, caster, and toe (rear is a solid axle)
foo is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 02:24 AM #64
ThePurposeIs ThePurposeIs is offline
Real Name: Drew
ThePurposeIs is on a distinguished road
Real Name: Drew
[QUOTE=foo;2551817]Just FYI, there is a thread over here where we discuss checking and adjusting static tire balance after mounting and dismounting your Toyota tires at home.
Fascinating, I have never heard of static balance. Most of the links in this thread are broken so it was good finding good info here at the end.
ThePurposeIs is offline   Reply With QuoteReply With Quote
Old 06-16-2020, 07:55 AM #65
Khouji123 Khouji123 is offline
Khouji123 is on a distinguished road
Fuel Off-Road Wheels offer a wide range of world-class wheels, they have the latest off-road wheel designs for off-roaders who wish to add style and elegance to their trucks. Fuel wheels are crafted by professional wheel designers who have extensive experience in the wheel industry. They are also made of high-quality materials that are highly resistant to corrosion and endure harsh driving conditions.
Khouji123 is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 08:11 AM #66
mnofpeace's Avatar
mnofpeace mnofpeace is offline
Real Name: Patrick
mnofpeace has a spectacular aura about mnofpeace has a spectacular aura about
mnofpeace's Avatar
Real Name: Patrick
JACKPOT!!!
My go-to mechanic has these in place...and i just ordered tires for them to mount this week.
aint life grand
Patrick L
Ft. Washington, Md.
2014 SR5 w/ 3rd row
My TRD-Pro-Lite
mnofpeace is offline   Reply With QuoteReply With Quote
Old 09-12-2020, 01:53 AM #67
HiHoStevo HiHoStevo is offline
HiHoStevo is on a distinguished road
I also have tried the links to locate this Hunter machine in my area (Las Vegas), and they are still broken... so I did drop a line to the sales rep for the machine... perhaps he can tell me who in Vegas uses this machine and adapter plate.
My '98 4runner has 106k and a set of Pathfinder tires... that I just cannot get to run straight. I have had it into Costco 3 times and once to Les Schwab Tires...
the last time at Costco they mentioned that one of the tires had a "hard" spot which they said could be causing the tire to "hop." Even though the shops have claimed that the tires are correctly balanced the Runner has a definate shimmy at freeway speeds even on smooth roads (of which there are not a lot).
As I have discovered (they were on the car when I purchased it) the tires are an in-house brand from Discount Tire... I am hoping they will be able to diagnose the problem and see if this "hard" spot will cause a warranty replacement.
There are only Two Theories on how to Successfully argue with a female..., unfortunately neither one Works!
HiHoStevo is offline   Reply With QuoteReply With Quote
Old 10-23-2020, 11:11 AM #68
TrailGunner TrailGunner is offline
TrailGunner is on a distinguished road
Great info here, thanks all.
TrailGunner is offline   Reply With QuoteReply With Quote
Old 07-08-2023, 01:46 PM #69
lakerman lakerman is offline
lakerman is on a distinguished road
well I'm one of them
rotated tires now have a shimmy, road force them, fail, got 2 new tires, still a shimmy, rotate tires shimmy gone, The bleeding continues, front end shimmy stopped when the back tires got placed on the front. Logic says it was those 2 new tires, so replaced, put them on the front, shimmies back, balanced multiple times, one guy says good, next guy says their out. Shop replaced all 4 tires with cooper tires,2 tires needed excess weight off they go, got a wheel alignment, and now worse than before, shakes everywhere and pulls to one side. Any recommendations in Edm Alberta canada area. Tire shop has the elite hunter machine telling me 20lbs is normal, oh what a headache.
lakerman is offline   Reply With QuoteReply With Quote
Old 07-08-2023, 02:03 PM #70
HTML code is Off
BEFORE Up-sizing your tires...read this! Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 43 08-23-2021 10:28 AM
More Tire Help CannondaleMan Engines / Suspension / Wheels / Tires / Audio / Accessories 0 08-20-2007 11:56 AM
tire balancing Toyboomer Engines / Suspension / Wheels / Tires / Audio / Accessories 1 06-14-2006 12:22 PM
Dueler A/T REVO TRD04RUNNER Engines / Suspension / Wheels / Tires / Audio / Accessories 85 10-24-2005 11:01 AM
Tire pressure light "explained" carina71 Problems & Warranty Issues 4 12-28-2004 08:16 PM
