05-02-2006, 02:27 PM
#16
chuey12, I did not add any more tranny fluid to it. I did not see the point as I only lost maybe an ounce at most when I did the install. The cooler itself does not take much fluid so I think I am alright. I have towed about 6000 pounds and no tranny overheating problems at all.
Sold out to the Sequoia 10/08
Will miss my 2005 Titanium 4WD SR5 V6
Mods and Accessories:
22" Xpower Revolver Rims wrapped in 285/45/22 Nitto Dune Grapplers. Cornfed 3" Front / 2" Rear Spacer Lift. Halo Projector Headlights. 6000k. HIDs Low Beam & Fog. Chrome Door Handles. Custom Iron Cross Grill. Led Running Board Lights. All bulbs replaced with Leds. Bumper Light Mod (Running Lights only). Map light mod. Constant Power 12V Outlets. Tinted Front Windows to Match Stock. Pioneer DEHP7600-MP HU. JBL 400w Amp. Eclipse 12" in Bandpass box. K&N Drop In. Flowmaster SUV 50 Series. Chrome Taillights. Added 12v Outlet to Center Console. Hayden 679 Trans Cooler. Tekonsha Prodigy Brake Controller. Hidden Hitch Class III WD Hitch. Air Lift 1000's. Load Controller II
06-23-2006, 06:12 PM
#17
I am going to give this an attempt in the next day or two. I just bought a 4100lb travel trailer and want to make sure I do all I can to protect the 4runner. I also ordered a better hitch and picked up a prodigy brake controller.
Questions.
- After I drop the skid plate I will want to tap into the return line to the tranny...correct?
- Is this line on the drivers side of the car?
I am sure it shold become apparant when I drop the skid plate and get under the truck. I just want to make sure I put the cooler in correctly.
This may have to wait until Sunday my honey dew list this weekend includes sodding the back yard.
Any guidence you guys have will be greatly appreciated.
07-12-2006, 08:22 PM
#18
Just wondering, doesn't the 4Runner come with a transmission cooler standard like the GX does from the factory?
07-13-2006, 08:42 AM
#19
not V6 4Runners
Jim _ My Adventure Blog: http://suntothenorth.blogspot.com
2018 TRD Off Road Premium
ARB on-board compressor - RadFlo coilovers & rear suspension - Engel freezer-fridge - All Pro LCAs - African Outback roof rack, RCI skid plates
01-26-2007, 02:17 PM
#20
What Toyota says about v6 tranny cooler install
I got news back from the Toyota people. The following was cut and pasted from my email.
Response (Jessica C) 01/26/2007 08:17 AM Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
We apologize; we do not recommend or assist with modifying our vehicles from their original factory specifications.
Modifications could affect the vehicle
2005 SR5 V6 4x4
Hayden 1678 (First Mod)
DONT BOOZE CRUZ
Yah, yur aboot ta do some aff roaden, arencha?
03-17-2007, 03:19 PM
#21
Re: What Toyota says about v6 tranny cooler install
[QUOTE]Originally posted by TheBlueWave
[B]I got news back from the Toyota people. The following was cut and pasted from my email.
07-17-2007, 08:57 AM
#22
Re: Re: What Toyota says about v6 tranny cooler install
That is my question, do we go from the existing radiator transmission cooler to the new ext. cooler then back to the trans or do we go around the radiator? I would think you go through the existing radiator, then to the new cooler. that way the radiator still helps to cool the oil a bit before it gets to the ext. cooler and you don't need to plug anything. I plan on adding a cooler to my 96 4runner 4wd. I just bought a brand new crate motor for it and the 4runner seems to have problems towing. I was spraying oil on my last trip (300 miles) if anyone has any advice I would be greatfull.
God Bless
Originally posted by JungleJim
In another thread, Kmvreter wrote, " The stock tranny cooler is internal to the radiator. The lines are the 2 small diameter hoses going to fittings on the driver's side of the rad (next to the battery; above the large diameter lower rad hose.)"
So it looks like it does have a transmission cooler, just different from the V8 one that is outside (external) the radiator.
The members earlier in this thread say that the external one they installed does not hold much fluid, so it might not be any larger than the stock one internal to the radiator. Also, it's unclear whether they are bypassing the stock one, or adding the external transmission cooler in addtion to the stock one.
09-07-2007, 12:03 PM
#23
I was poking around looking at the cooler just yesterday and i saw that the V8 one has a integral cooler in the radiator (like the V6) then comes out to a external one in front of the radiator, so it pretty has dual coolers.
I was thinking of dumping the small stock one and putting in a bigger cooler thats made by Calsonic (its a Nissan 300ZX oil cooler) its a better core design made for flow and large fluid capacity. This cooler holds a additional 1qt of oil. Its about 12" wide, 10" tall, and 2.25" thick.
2003 4Runner Limited V8 2WD -Stock
1990 300ZX Twin-Turbo -Modded
1990 300ZX Non-Turbo -Stock
09-05-2008, 09:03 PM
#24
Super Moderator
Super Moderator
Bored. Thought I'd add a few pics of my install. I took inspiration from LV4R, thank-you.
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
09-08-2008, 11:39 AM
#25
how much hosing was used? I'm planning to pick one up from summit racing. They have many many brands for great prices!
09-08-2008, 11:34 PM
#26
Super Moderator
Super Moderator
Make sure the cooler you get is setup for 3/8" line size. Many have 5/16" fittings which will restrict flow. I chose an engine oil cooler and screwed in my own fittings.
How much line? I forget... I purchased by the foot fom a local parts store. It's cheap. Get 8 feet and you'll be fine, 5-6 is probably enough but why come up short. It's 3/8" ID hose. Get genuine transmission cooler line (not fuel line) and I highly recommend fuel injection style hose clamps. NAPA stores usually carry both.
Look at my pics to see the clamp type.
Chris
09-09-2008, 10:10 AM
#27
what size was your cooler? I'm about to order the B&M SuperCooler 11'' x 5-3/4'' x 3/4'' . I hope thats the right size and fitting.
09-09-2008, 12:14 PM
#28
Super Moderator
Super Moderator
Yes, http://store.summitracing.com/partde...56+4294782889, this one will be good. I used the thicker variant but that's wretched excess. Mine measures almost 1.5" thick but the same in other dimensions. I could possibly have issues with overcooling in cold climates too. If I've linked to the one you're buying my 2 cents is that it's perfect.
Chris
09-19-2008, 02:57 PM
#29
I got it...installed it......and it's fine! Hardest part was figuring how and where you want to mount it! I also did not add any oil...or lost any oil. EASY! Should be the first mod!
2007 SPORT 4x4 | DDM 4300k HIDS | Dobinson Coils | Bilstein 5100 | JBA UCA |SuperPro LCA | Goodyear SS brakelines | Allpro 1.5 spacers | Toytec sway mods and diff drop | Energy Suspension poly sway bushings | TRD Exhaust | RSG Sliders | Defiant Light Bar
10-15-2008, 04:22 AM
#30
Banned
Banned
WTF? Mine already has one. I thought ALL 4th Gens already had intercoolers installed.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
HTML code is Off
