Old 10-15-2008, 08:03 AM #31
boostedprozac's Avatar
boostedprozac boostedprozac is offline
boostedprozac is an unknown quantity at this point
They ALL have lines going to the side of the radiator for cooling......but ONLY the V8 had an external cooler after the radiator. The V6 didn't have the external cooler.
2007 SPORT 4x4 | DDM 4300k HIDS | Dobinson Coils | Bilstein 5100 | JBA UCA |SuperPro LCA | Goodyear SS brakelines | Allpro 1.5 spacers | Toytec sway mods and diff drop | Energy Suspension poly sway bushings | TRD Exhaust | RSG Sliders | Defiant Light Bar
boostedprozac is offline   Reply With QuoteReply With Quote
Old 10-16-2008, 02:28 AM #32
Uneek's Avatar
Uneek Uneek is offline
Super Moderator
Uneek is on a distinguished road
Super Moderator
Uneek's Avatar
Originally posted by MikesToy
WTF? Mine already has one. I thought ALL 4th Gens already had intercoolers installed.
V8s have the additional auxilary cooler installed in front of the radiator. V6s do not. Both have a cooler inside the radiator. So there are two on the V8, one on the V6.
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
Uneek is offline   Reply With QuoteReply With Quote
Old 08-12-2009, 12:53 AM #33
wes smith wes smith is offline
wes smith is on a distinguished road
trany fluid
you can fill through the dipstick stem for the trany fluid on the pasenger side. just need a small funnel
wes smith is offline   Reply With QuoteReply With Quote
Old 04-24-2010, 06:18 PM #34
CJ3Flyr's Avatar
CJ3Flyr CJ3Flyr is offline
Super Moderator
CJ3Flyr will become famous soon enough
Super Moderator
CJ3Flyr's Avatar
Cool thread for 3rd gen install
3rd gen install here: Writeup on tranny cooler install??? Thanks HockeyRunner.
CJ3Flyr is offline   Reply With QuoteReply With Quote
Old 04-29-2010, 05:20 PM #35
jpless's Avatar
jpless jpless is offline
jpless is on a distinguished road
jpless's Avatar
I bought the one that CJ3Flyr linked to and I believe boostedprozac installed.
I was just out there for a while trying to figure out how to mount it. I ended up trying to do what Chris did with 3 mount points but mine didn't line up well with the holes provided.
However, in doing so, I tried to put one of the longer bolts that came with the B&M cooler back into the bottom left mounting hole that Chris used and ended up ripping the bolt head off, pretty easily I might add.
So, I need to figure out how to get that bolt out of there now but when I do, any advice on how to install the B&M? I guess I'm looking more for boostedprozac's final setup since I have that exact same one but all advice is appreciated!
I'm going to have to cool off on mods for a little after this one, my girlfriend is getting annoyed with how much time and money I'm spending on my t4r recently.
My Build Thread
2006 Grey Mica Limited 4wd, JBL, RCI Skids, FJ TT suspension, aFe stage 2 CAI + URD MAF cal, Sprint Booster, Cobra 75 CB, 17" MB Gunner6 wheels + 265/70 Cooper Discoverer AT3s, Poly Bushings, Rear Diff Breather Mod, Morimoto XB 4500k HID Lows, LEDs in and out, Husky Liners, Load Warrior.
jpless is offline   Reply With QuoteReply With Quote
Old 04-29-2010, 06:42 PM #36
mndanielsncsu's Avatar
mndanielsncsu mndanielsncsu is offline
mndanielsncsu is an unknown quantity at this point
Originally Posted by jpless View Post
So, I need to figure out how to get that bolt out of there now but when I do, any advice on how to install the B&M? I guess I'm looking more for boostedprozac's final setup since I have that exact same one but all advice is appreciated.
I bought and installed the B&M Cooler that CJ3Flyr recommended as well. I installed mine in a similar place to where he installed his, but i just used some self-tapping metal screws and lock-washers and drilled through the frame in front of the radiator beneath the horn. I've had it mounted there for a couple of months now and nothing has come loose and I've had no issues.
Here are a couple of pics.
Hope this helps.
Transmission Cooler Install-tc-1-jpg  Transmission Cooler Install-tc-2-jpg
'07 Shadow Mica SR5 V6
Xenon Depot 4300k HID's, 35% tint front, 5% back, JL 10W3v3, 18" Limited Wheels, Diff Breather Mod, Swaybar Bushing Upgrade, Transmission Cooler, LED Interior, Remote Start, Classic Soft Trim Leather
mndanielsncsu is offline   Reply With QuoteReply With Quote
Old 04-29-2010, 08:12 PM #37
jpless's Avatar
jpless's Avatar
Thanks for the pics.
I took the lower grill out so the drill could fit and tried to drill and tap the bolt I ripped the head off of but it didnt work.
I gave up on that for the time being and decided to drill some holes in the cross and vertical bars for install. They were a tad bit too small for the bolts so I put on a bigger drill bit and widened them to the right size. On the LAST hole, the bit busted through with too much force and put a hole in the AC condenser
So, as I was getting the feeling of "wooo almost done!" the condenser got a hole and started spraying out fluid. It was awful, especially since its just starting to heat up and I'll need the AC soon! That and I dont think I can afford to fix it yet.
Needless to say, I'm giving up on the cooler until I fix the condenser but at least the holes are there for when I get back to it!
spraying out:
better angle of hole in vertical bar lined up with hole in condenser:
My Build Thread
Old 04-29-2010, 10:27 PM #38
the_josh's Avatar
the_josh the_josh is offline
the_josh will become famous soon enough
the_josh's Avatar
spraying out:
pull the condenser and take it to a radiator/muffler shop- they can fix it for like $50 its a easy fix and no need to replace it
Tiny House Basics
www.TinyHouseBasics.com
the_josh is offline   Reply With QuoteReply With Quote
Old 04-29-2010, 11:20 PM #39
jpless's Avatar
jpless's Avatar
I read on yotatech and some other forum that if you put a hole in the fins (like I did) there's nothing you can do and to seal it up until you replace the condenser. Either way, I'd love to hear your feedback but to not take this off topic, here's the link to my dedicated thread (I'll be adding a write-up when I get it done)
Replacing AC Condenser suggestions
My Build Thread
Old 05-17-2010, 06:15 PM #40
JAM07Sport's Avatar
JAM07Sport JAM07Sport is offline
JAM07Sport is an unknown quantity at this point
JAM07Sport's Avatar
So from what I have read you guys came off the bottom of the factory rad/trans cooler and went into the secondary cooler then back to trans line. Correct. So the top line going into the rad is where the hottest fluid would befor a trans temp sensor. Please correct me if I am wrong.
Thanks,
07 sport V6
JAM07Sport is offline   Reply With QuoteReply With Quote
Old 05-17-2010, 08:58 PM #41
CJ3Flyr's Avatar
Super Moderator
Super Moderator
CJ3Flyr's Avatar
Thanks,
That's where I'd put a temp sending unit for a gauge, on the line flowing TO the cooler which seems to be the top line (it was on my '07 V6).
Old 05-27-2010, 01:21 AM #42
CJ3Flyr's Avatar
Super Moderator
Super Moderator
CJ3Flyr's Avatar
Sweet 3rd gen install
Great install... Transmission Cooler with Fan (pics)
Great 3rd gen thread: B&M 70268 SuperCooler Transmission Cooler Install on a 3rd Gen
Old 11-12-2010, 03:18 PM #43
SSt4r's Avatar
SSt4r SSt4r is offline
SSt4r is on a distinguished road
SSt4r's Avatar
Has anyone on here with a V8 added a larger trans. cooler and converted the existing trans. cooler to a power steering cooler? I was thinking of adding a larger one and the existing power steering cooler (just a simple single metal line) runs right by the factory cooler. I think it would be easy to tie the factory cooler into the power steering line. Any thoughts?
1999 BMW M3 coupe(E36) & 2005 V8 sport 4X4 black: ARB bull bar with 4 hella 500s,backup camera in spoiler,VSC off, springs:Tacoma w/ toytec(1/2"Fr) & FJ w/ daystar(1.5"R) spacers,Bora .75" front & Spidertrax 1.25" rear spacers,swaybar bushings upgrade,Stoptech rotors,SS brake lines,RCI Metalworks skids (front, trans.,transfer), Volant CAI,DT shorties w/ Dirty Deeds exhaust,fully soundproofed,Rostra seat heaters,HID (lows),HIR (highs),running board lights (added),aux reverse lights,2006+ tail lights,rear fog mod (tail, brake, directional OR rear fogs),Scion T1819,LED int. lights, key reminder diabled, Land cruiser steering wheel,rear window dog barrier, vent visors, Ultraguage, Enkei Deep Six 20" wheels for summer, factory sport wheels with A/Ts, FJ cruiser wheels with winter tires
SSt4r is offline   Reply With QuoteReply With Quote
Old 11-24-2010, 07:35 AM #44
lynnabelone lynnabelone is offline
lynnabelone is on a distinguished road
new jersey carpet cleaners
Well, i just buy the corolla atlis and i want to know about the highest intensity speaker for my car, what sound it will spread and what is the cost for installing that.
steamcarpetcleaningnj.com
lynnabelone is offline   Reply With QuoteReply With Quote
Old 12-26-2010, 11:41 PM #45
lruss7 lruss7 is offline
lruss7 is on a distinguished road
Trans cooler installation detailed instructions with photos
Just like all of you, I attempted to find instructions for trans cooler installation, and just like you - failed miserably. There are a few advices but I didn't like any of them. Here is my solution:
http://anti-lemon.com/transcooler/4RunnerCooler.pdf
Questions/suggestions? [email protected]
Good luck!
lruss7 is offline   Reply With QuoteReply With Quote
HTML code is Off
Who has the best transmission?? Thai Maintenance/Detailing 13 01-12-2021 05:43 PM
**SOLD** Tru-Cool 4454 Transmission cooler jusgroovin Classifieds - buy & sell (no commercial ads please) 8 09-23-2010 03:04 AM
Transmission cooler line leaks. TechWrench 4th Gen T4Rs 6 10-15-2009 08:39 PM
Does the 4Runner V8 Limited come with a transmission cooler BigK75 4th Gen T4Rs 3 09-21-2009 03:44 PM
Transmission Cooler / Heater? osxcode 4th Gen T4Rs 3 05-18-2008 09:59 PM
