Old 05-10-2006, 03:23 PM #1
mnaber mnaber is offline
mnaber is an unknown quantity at this point
after market amplifier for stock stereo
has anyone had any experience installing an after market amplifier to the stock stereo. Is the stock stereo capable of an after market amplifier? Was there engine noise? I would be using after market speakers as well. Just want to keep the stock look of the dash so I want to keep the stock head unit.
2006 4Runner Sport Edition V6 Silver
mnaber is offline   Reply With QuoteReply With Quote
Old 05-16-2006, 05:42 PM #2
seconds2none seconds2none is offline
seconds2none is an unknown quantity at this point
Re: after market amplifier for stock stereo
You should try looking at digital amps made by Eclipse. The stock HU does not out put like aftermarket HU in terms of wiring. HU sends an IP Buss signal that is converted by the amp into front, rear, left, right. To use an aftermarket amp you have to use speaker level to line level converters AFTER the JBL amp.
2004 Limited V6 4x4
Dark Blue
Eclipse AVN 6600
7"headrest LCD
seconds2none is offline   Reply With QuoteReply With Quote
Old 06-11-2006, 01:58 AM #3
animator's Avatar
animator animator is offline
animator is on a distinguished road
animator's Avatar
Found this thread searching. I assume the same is true for all wiring, that they must be connected AFTER the stock amp?
I ask because I will also be wiring up an amp to my stock unit. I have an RCA convertor that will need to be wired up along with the amp turn-on wire, since the stock head unit does not have RCA outs.
animator is offline   Reply With QuoteReply With Quote
Old 06-13-2006, 12:40 AM #4
EddieinD EddieinD is offline
EddieinD is an unknown quantity at this point
I used an adapter like this one.
These guys also make a 4 RCA version that I have. Works well. I use it with the Scion head unit, but the harnesses are the same. It includes a turn-on wire. I am assuming that your Sport has the same 6-speaker stereo that my '04 has. You just plug it into your stock harness and the radio.
2004 SR5
2006 Scion HU
Alpine MRP-M350 mono amp
Kicker 8" CompVR CVR84 sub
Alpine MRV-F345 V12 4-Channel amp
CDT CL-61 components
Second Skin sound deadener
EddieinD is offline   Reply With QuoteReply With Quote
Old 06-13-2006, 01:50 AM #5
mit_peid's Avatar
mit_peid mit_peid is offline
mit_peid is an unknown quantity at this point
mit_peid's Avatar
Before I had my AVN5435 navigation system, I had a stock JBL 6 disc system with aftermarket infinity two-channel amp, infinity reference speakers in front, and infinity basslink.
I hooked it up after the stock JBL amp using the speaker-line input. Surprisingly, it sounded quite good. The important thing is to ground the amps down very well. As far as sound quality, it may only be slightly lower than my current setup.
The reason why I upgraded was because I wanted the new functionality of the aftermarket setup. But for just listening to CD's and using the USA spec auxilary adapter, SQ was more than adequate with the aftermarket amp after the stock amp.
2005 Black Sport Edition V6 4WD
18" Limited Rims
Eclipse AVN5500 w/ Ipod Adapter
Infinity 6.5" Reference x 4
Kenwood 4-Ch amp
Infinity Basslink
mit_peid is offline   Reply With QuoteReply With Quote
HTML code is Off
Scion T1807 install in 3rd gen '99 Limited (pic heavy) CO_FlyFisher 3rd gen T4Rs 39 03-23-2014 09:33 PM
Looking for stereo and speaker recommendations jediwebdude Engines / Suspension / Wheels / Tires / Audio / Accessories 6 01-13-2011 09:50 PM
Reinstalling a factory stereo in a 99? Martinjmpr Engines / Suspension / Wheels / Tires / Audio / Accessories 1 09-02-2009 08:42 PM
Radio reception poor on newly installed Kenwood DNX5140 NAV stereo ryanhokie2001 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 07-27-2009 02:00 PM
Navigation system and stereo amplifier Hitman Engines / Suspension / Wheels / Tires / Audio / Accessories 0 10-07-2004 01:02 AM
