This may depend on how big your amp is, but I would recommend putting it under the driver's seat. The power wire routing to the battery would be the shortest and easiest from that location: run the power wire through the big grommet in the firewall and inside the kickpanel, and inside the plastic trough in the door sill. Then route it to the amp from under the carpet.
The RCA's as you said, can be routed right down the center console, totally separate from the power wire. You might have to make slits in the carpet with a Xacto or utility knife where you want the RCA's to come out of the carpet near your amp, or to open up an existing hole. I did that, it's no big deal, you can't see it anyway.
Run your amp's remote turn-on lead either way (center console or behind the dash to meet up with your power wire in the kickpanel area).
2015 Black Limited.
2005 Silver Sport.
