Yo.... welcome to the forum. I bought a full set (2 pairs) of Infinity Kappas, and gambled that they'd fit without any significant mods to the mounting area. They do fit perfectly. I cut out the stock 6x9 with Dr.Dremel, and glued some oval donuts that I made out of .75" MDF inside that oval ring. Then I mounted the Kappas to the MDF - in the exact middle of the oval so they wouldn't hit the door panel where it justs out and outlines the oval speaker shape. (Tough to explain, but you can see what I mean when you pull apart the door panel).
The rear was the same as the fronts, but I didn't have to fab an MDF donut, I epoxied the Kappa's thin metal mounting ring directly to the existing speaker's thick plastic mounting ring (after that speaker was cut out of it).
So, minor fab work and the Kappas fit perfectly without any depth problems.
2015 Black Limited.
2005 Silver Sport.
