Old 01-12-2016, 06:28 PM #1
D's Trail D's Trail is offline
D's Trail is on a distinguished road
LED Bar switch with ignition on only
Hi everyone, newbie here and need some help.
i got an question. i purchase the OPT7 Offroad Light Bar wiring Harness Kit for my LED bar and want the switch enable when car in ignition only
do i cut the switch 12v wire and T-tap to other 12v ignition wire?
D's Trail is offline   Reply With QuoteReply With Quote
Old 01-12-2016, 07:01 PM #2
2014 Warthog's Avatar
2014 Warthog 2014 Warthog is offline
2014 Warthog will become famous soon enough 2014 Warthog will become famous soon enough
I would not try to wire it directly to an ignition switched source. Rather tap an ignition switched source off the fuse box using an add-a-fuse or something and run that to a relay. Then cut your +12 harness wire and wire either side to the high current side of the relay. That way the light current is only going through the harness wiring/switch and relay and not drawing off of anything under your dash. (relay draw is very low so would be much much safer to where ever you end up attaching it)
The Warthog
Too many mods to list See my build thread ---\/
http://www.toyota-4runner.org/5th-ge...re-thread.html
2014 Warthog is offline   Reply With QuoteReply With Quote
Old 01-13-2016, 12:05 AM #3
1996_4_runner 1996_4_runner is offline
1996_4_runner is on a distinguished road
Yeah I wouldn't recommend directly wiring it into the ignition
1996_4_runner is offline   Reply With QuoteReply With Quote
HTML code is Off
Has anyone had this happen to their ignition switch? MaukaRunner 3rd gen T4Rs 6 08-03-2022 09:31 AM
Ignition switch Takuanda07 3rd gen T4Rs 0 06-05-2015 04:22 PM
What is ruining the ignition switch? Graham 3rd gen T4Rs 22 12-31-2013 03:55 PM
ignition switch and key 4runnerman09 4th Gen T4Rs 10 10-12-2010 10:39 AM
Starter or ignition switch chriley 3rd gen T4Rs 4 08-08-2005 02:06 PM
