Factory AMP spec
Hi guys, sure this has been discussed before, did a search and could not find it.. Getting the Panasonic 6503U double din head unit. Don't know if I should bypass the factory amp(using amp in new head unit) or use the factory amp.. What do you guys think and does any one know the specs of the factory amp..
Also what size is the factory sub, checked on crutchfield but they dont say. I wonder if a pioneer shallow mount sub would fit in the same spot.. I would run another amp for that though.. Any help would be great..
2003 4Runner Limited V8
