04-29-2012, 07:30 PM
Real Name: Tim
Real Name: Tim
the TRUTH about CAI (cold air intake)
i notice a lot of post on here about CAI much like any other forum, i have a little write up i like to post from time to time if you guys have a minute to read i can share my thoughts.
Have you purchased a cold air intake kit for your vehicle yet? If so, you are among the many thousands who (for various reasons) have bought into this technology. But does it really do what you thought it would?
The most common reasons people give for installing a Cold Air Intake are:
1.More Horsepower
2.Better Fuel Efficiency
More Horsepower! Now this one is true, but might be a little misleading. Cold air intakes can result in actual gains in power, but not necessarily in the way most people are expecting them. The key that is typically missing in the mind of the average consumer is that the only time power is increased is when the engine is at Wide Open Throttle (WOT). For those who don't know what that means, WOT is basically when the gas pedal is pressed all the way to the floor.
Some are now thinking "Wait a minute! The cold air intake lets cooler, more dense air into the engine. It also has less restriction than the stock setup. This lets it 'breathe' better, and therefore is more efficient." What can I say? You're right...at wide open throttle. What many people don't realize and what many others simply forget to consider is that there is a throttle valve connected to your gas pedal that is constantly restricting the air flow into the engine. The only time it is not restricting the airflow is when it is wide open...hence the term WOT. Some will now say "But it will still breathe more efficiently even at part throttle." You must then remember why there is a throttle valve in the intake to begin with. The throttle valve determines how much air enters the engine, and the engine computer (for fuel injected engines) determines how much fuel to mix with the air. Several factors influence how the computer determines this, but the result is basically the same: a fixed Air/Fuel Ratio will be supplied to the cylinders. This should be obvious since all modern vehicles have to comply with EPA emissions standards.
That means that more air = more fuel = more power = more speed. Now that's good if you're at WOT, but how many of you drive at WOT even 1% of the time? The fact is that you almost always drive in part throttle...because you're usually limiting the vehicle's acceleration. That is the key. Any time you limit vehicle's speed/acceleration with the gas pedal, you are actually limiting (restricting) the amount of air entering the engine. This defeats the purpose of the cold air intake, high-flow intake, high-flow filter, etc. It is only effective when you're at WOT.
One thing should be clarified here...when I refer to WOT, that can also be a little misleading. The condition where these devices increase power is not always exactly at WOT. The throttle valve on a car's intake system is typically a butterfly valve. The more it is closed, the more restrictive it becomes. The least restrictive condition is when it is wide open. Keep in mind that the intake system is sized to operate the engine through a full range of speeds and load conditions. If you get full power from your engine at 5,000 rpm, the throttle valve is sized allow air to flow through it at that speed. Now how much air do you suppose is flowing when you're only turning the engine at 2,500 rpm? This is the situation you have when your're pulling a heavy load (trailer, etc.) in a high gear. This is the situation I find myself in with my pickup when pulling a travel trailer. In 3rd gear at 60 mph, the intake manifold pressure and mass airflow don't change at all from about 70% open throttle to 100%. Why? The throttle valve is effectively at WOT for that speed. There is no measurable resistance being offered by the valve when at 70% open. Does that mean that a cold air intake would help when towing heavy loads? Probably not. The reason is that when you have the condition described above (you have more pedal, but it doesn't change anything), the intake system (filter & piping) is providing very little air resistance. You know this because the primary form of resistance--the throttle valve--isn't even doing anything from ~70% and up. That tells you that there is not as much air flowing through the intake as there would be at high rpm (like if you down-shifted), and therefore your air filter creates a very small amount of resistance by comparison. NOTE: This is assuming that the air filter is clean. If it is clogged up, that's a different story.
In summary, the cold air intakes and high-performance filters are good for improving full-pedal engine power. Practically that means that you are buying a modification that helps you pass (at full-pedal) or race. Don't expect fuel economy gains…sorry.
He's an angel dressed in oilskins; he's a saint in the "Sou'wester,"
He's a pluck as they come, or ever can;
He's a hero born and bred, but it hasn't swelled his head,
For he's just the U.S. Government's hired man.
05-26-2012, 04:23 PM
it's all about air density. cooler air is more dense!
05-26-2012, 04:29 PM
Real Name: Tim
Real Name: Tim
The factory intake is already cooler than the ambient temps inside the engine bay. You won't get a much cooler charge without meth/water or an intercoooler. Or maybe sitting bags of ice on top of your intake...you can try and disprove this post but these aftermarket "CAI" are only good at WOT and marginal at best. 110% waste of money on a stock engine
06-01-2012, 05:22 PM
Re: Cai
I bought into this. The only thing I gained was an AMAZING combination of Volant CAI and Borla Dual Exhaust growl paired up together for an awesome sound.
My HCF deleted stock airbox is back in with a K&N drop-in reusable filter. The sound alone wasn't enough for me to continue to use the CAI.
2005 Sport Edition 4.7L V8 4x4
-Borla Dual Exhaust -HCF Delete -OEM 2006 Tail Light MOD -Pioneer AVH-4200NEX -Automatic Start -Lo Jack -Heated Seats Mod -WeatherTech All Weather Floor Mats -Sport Pedals -Black Headlight Housings -ALL LED External Lights -Bilstein 6112/5160 Lift -FJ Coil Swap -C4 Low Pro Bumper -Warn VR Evo 10k-S Winch -Sherpa Princeton roof rack -Extreme LED Light Bars -SCS SR8 wheels on Falken Wildpeak tires 285/70/R17
http://www.toyota-4runner.org/4th-ge...ld-thread.html
06-10-2012, 09:53 AM
Real Name: Sam
Real Name: Sam
Maybe I'm the odd ball here. Bone stock, I got 20.5mpg on the hiway. After an Injen CAI, Airaid throttle body spacer, and custom catback with Borla Pro XS single in, dual out mufler, I now get 22.4 one the hiway. Maybe the intake by itself does nothing since the stock exhaust would still be restrictive? Idk. I do know for a fact that my mileage increased with the mods I've done. I check my mileage every time I fill up. I also drive like an old man 95% of the time. I'm sure that helps too.
'97 4Runner SR5 TRD S/C 3.4L 5spd 4x4, Injen this, Borla that, URD things. . . - 2014 Shamrock 21DK Camper
06-10-2012, 09:57 AM
Real Name: Tim
Real Name: Tim
Throttle body spacer on a modern EFI engine is also another product that's not worth anything. On a TBI or carb a spacer helps atomize the fuel mixture but not with our 4Runner engines
06-10-2012, 10:01 AM
Real Name: Sam
Real Name: Sam
I know. It was on the clearance rack at Summit Racing for $15. It was an impulse purchase. Its red so it matches a few other little things under the hood.
06-17-2012, 02:13 AM
I went the same route almost - an Injen intake with the new dry Amsoil filter and a Borla XR-1 muffler. I got back the gas mileage I lost when I went from 265 tires to 285/75/16. I have a 20 mile drive to work in mixed city and higway and I average 21-22 MPG. And I don't drive slow - typically 5-10 mph over the speed limit.
2002 SR5 4x4, Dorado Gold
Suspension:Front:Toytec Coilovers w/ 5100 Bilsteins/RevTek Diff Drop, 231mm Tundra Brake upgrade. Rear: ToyTec Superflex coils/5100 Bilsteins.
Tires: 285/75/16 Bridgestone REVO 2's
The Rest:I.S.R. Mod upgraded to an Injen intake, Borla XR-1 muffler, ARB Bumper, Shrockwork's Rock Sliders, CBI Rear Bumper and a pair of Hellas. Plus a whole bunch of other accessories.Topped off with Zaino's Polish.
06-17-2012, 03:09 AM
Real Name: Kevin
Real Name: Kevin
Rebel is exactly right. This tendency to call anything with a cone filter a "Cold Air Intake" drives me up a freakin' wall. There's nothing "cold" about the air under the hood, no matter what filter you're using.
High flow filters and ram air intakes can give horsepower gains as part of a balanced system (IE, in combination with things like a custom cam, free-flowing exhaust and fuel management mods). They don't do much by themselves, for exactly the reasons Rebel stated. A bigger funnel does you no good if the neck is the same size.
If you want quick performance gains, they're in your exhaust header and muffler.
06-21-2012, 12:13 AM
I'm doing better with the Injen than the Stock AirBox and the ISR mod. I'm also getting better mileage with E weight 285s that the Stock Air Box and 265 tires.
Also, here's a good thread about Intake Air temps.
ScanGauge II owners - Intake Air temps
Seems the Injen stays cooler than most CAIs because it's longer and extends past the radiator.
09-26-2012, 12:32 PM
This sounds good in theory.. Although the entire paragraph is arguing against a cai letting More air in.. The purpose of a cold air intake is Not to let more air total.. (Hence argument about only gaining at "wot"). But it is to let cooler denser air from outside the engine bay in, thus improving the power output.. I don't see how you're making the claim it only does anything when you're flooring it? :? Altho I do agree they are misleading when people think it will be a huge gain
10-03-2012, 01:39 AM
I threw a COBB CAI on my Subaru and I notice a SERIOUS gain in throttle response.. It was insane how much better the engine responded. So I guess what I'm saying is that it isn't all about HP and MPG...
That thing sounds amazing too. CAI on a turbo engine sounds gooood.
Cleans up the engine bay, sounds good... If you MPG and HP increase that is for sure a bonus.
10-09-2012, 12:38 PM
Real Name: David
Real Name: David
An intake needs to be tuned for the application you're using it in and is part of your overall tuning setup. While some vehicles can see a small improvement with a specific intake alone, others will actually see degradation in performance, especially if the intake is affecting the air/fuel management. I have a decent amount of experience tuning the K20Z3 motor (2006-2011 Honda Civic Si) and if you just slap an aftermarket intake on and call it good you will generally mess with your air/fuel ratios and end up with some weird throttle response issues since you've affected the way the air flows over the mass airflow sensor (most of us tune with the MAF disabled). In these cases if you haven't tuned the ECU to compensate for these changes and you are seeing a true increase in fuel economy then you're almost certainly running lean and on an engine that puts out 70lbft/liter in stock form and 90lbft/liter with simple bolt-ons and tuning, and you're asking for problems. We don’t have those kinds of outputs in these engines so it is probably harder to hurt the engine by blindly slapping on an aftermarket intake but I still don’t think it is a good idea regardless.
That being said, I don't know where the bottlenecks are on these engines. I have a feeling the header is the #1 offender. Personally I'm not at all concerned with the power output at 3500 RPM and above as I rarely see those kinds of engine speeds in my Runner. What I want is more power in the 1000-3000 RPM range where I do my daily driving and even towing at.
2007 V6 SR5 4WD - OME 884/Toytec Superflex with Bilstein 5100s - Air Lift 60809 Air Bags - Sixity Wheel Spacers - Draw-Tite 75155 Receiver - Tekonsha P3 Electric Brake Controller - B&M 70264 Tranny Cooler
2006 Jayco Jay Series 1206 PUP - 3450 lb GVWR/14' Carson Landscape Trailer - 7000 lb GVWR/16' Wells Cargo Enclosed Trailer - 7000 lb
16-19 MPG City/20-22 MPG Highway/17-20 MPG w/Jayco @ 55 MPH/16-19 MPG with Landscape Trailer @ 5500lb @ 55 MPH/12-14 MPG with Enclosed Trailer at 55-60 MPH @ 6000lb - Pushing air sucks gas!
10-21-2012, 12:46 PM
Used to muck w/ this stuff when I had a Supra but times pass... As do memories
CAI intakes were great when we were trying to make speed and times at WOT. The turbos, the intercooler and generally the entire engine bay were a massive heat sink which restricted how much air we could get into the engine. Devices like a turbo helped "suck" more air into the engine (and the engine was simply a massive air pump), and ice around the intercooler (water spray, alcohol combo) helped increase the air density.
But with those engines, it boiled down to getting as much air into the engine so the larger injectors and fuel maps could combine it at the right ratio in order to increase horse power.
With the 4Runner, it'd be different. The air/fuel mix is pretty good (constant) for whatever RPM you're at. Increasing the air density doesn't mean you have more air coming into the engine IF the throttle body is partially closed restricting that air.
The mass air flow sensors generally reads not only the amount of air coming through (fixed diameter, measures flow speed) but also the density of the air (temperature gauge). So the MAF knows exactly how much air is incoming.
Again, if your throttle body (butterfly plate?) is wide open and you are still not getting enough air because of whatever restriction - then yes, CAI will help. But if it's at 50-80%, CAI won't do a thing as the MAF is telling the system how much air is coming in and the system is accommodating the overal ratio of A/F mix.
Too much air is bad. You run too lean, burn the rings and fry your engine. A little lean is good as that's where you're close to your max HP/Torque. Too rich is a safety valve as it only costs fuel.
Way back when we'd wire in potentiometers (aka resistors) to our MAF in order to tell the system it was warmer than it was in order to allow more air in. There's a limit as you do start to reduce the life of your engine (but hey, the Toyota Supra engines are/were bullet proof).
Am I off, is my memory that shot?
12-03-2012, 01:34 PM
Solid post.
So i guess the only benefit of a CAI is the sound...
Current Ride: 2004 4.7L SR5 4Runner. JBL package.
Previous Rides:
1996 3.4L Tacoma
1998 Rav4.
HTML code is Off
