Originally Posted by URBAN ASSAULT
The TG pump will bolt up. I have it, and run it with the PSC hydro assist. Just make sure you order the right pulley. 3rd gens use the ribbed pulley.
If I recall correctly, 851 or 861 are about the tallest coil you can get. Even with those I couldn't get level after my swap. I ultimately went all out and did 14" ORI struts on all 4 corners. Infinite adjustability with ride height and ride quality.
Otherwise, you could use trim packers or spacers on top of your coils. Just make sure to not overextend your shocks, and your brake line.
thanks bud. This was the exact answer I was looking for. Ill be ordering the trail gear soon. I went out this weekend and was up in a tight dry creek bed and turning these 37''s with very little room on this pump was beyond a workout.
The 851s are supposed to be the tallest. The 861s are about an inch shorter. I will def be doing matching ORIs in the rear this winter, just wanna get rid of some of this squishy rear sag for the time being.
Thanks again.
