09-23-2006, 10:45 PM
Just installed Optima Yellow Top
I just finished installing an Optima Yellow Top battery in my 2003 4Runner. It took a little bit of wiring and some spacers but it's rock solid now. Will post some pics tomorrow.
2003 Land Cruiser V8 Thunder Cloud
Tundra Wheels, HID Kit, Dual Batteries, Ultimate Air CO2 Kit, Sirius Sat Radio, DVD Hack
2003 4Runner SR5 4x4 V8 - Sold
09-24-2006, 12:30 PM
Here are some pics of the finished install. To fit the battery with the stock mounting posts, you either need the optima spacer (which I didn't get) or use some wood shims (which I used for now). I will probably replace the rods with shorter ones today to avoid using shims.
Since the Optima Yellow Top is not available with reverse posts, the stock wiring is a little short. You can make the positive side work without modification but on the negative side you have to extend the ground wire to the chassis.
In my case I just wrapped the stock ground to the main wire with electrical tape and made a new ground wire out of 10 gauge black wire. Looks almost stock.
If you just want to get a high performance starting battery, just get a Red Top 34R. The red top is for starting while yellow top is a hybrid starting and deep cycle. Blue top is deep cycle. With the Red Top 34R you will still need shims but the stock ground should still reach the chassis.
09-24-2006, 12:31 PM
Another shot:
09-24-2006, 12:32 PM
Last one:
10-05-2006, 03:18 PM
So whats the real diffrence between the red top, and the yellow, and the blue. I always though that a deep cycle battery allowed you to run it completely down, and charge it back up without damaging the battery. Is this correct?
I know that with regular car batteries, if you run them completely down a few times, they do not hold the charge as well anymore.
10-07-2006, 01:11 AM
ya thats what Ive read
1997 White 4Runner Limited
20% Tinted Front Windows
Bug Shield (Someone broke it)
200 Watt Pioneer DEH P-6700MP
2-6.5in. Alpine SPS-170A speakers, 2-6.5in. Alpine SPS-17C2
12" Diamond D612D4
Custom Built Box done by myself
Alpine MRD-M605
HTML code is Off
