Old 04-18-2017, 12:45 PM #1
GChristo's Avatar
GChristo GChristo is offline
GChristo is on a distinguished road
GChristo's Avatar
Anyone running 255/75r17 C KO2's?
Would like to know members' experiences with these KO2s. Happy with the size, any issue with load rating, performance, uneven wear, etc? What PSI worked out best on and off road?
I see a lot of members considering these this size when searching but am having trouble finding any first hand info.
Thanks
edit:
Coming back to add pictures and info for those interested in this route.
Running 40psi provides a load of 2055 according to BFG table provided by BFG email. Running 45psi reaches 2230 by that table. Don't rely on me here of course.
Installed height, @ 40psi cold, I get around 30 7/8" from ground to the shoulder with tread bulge reaching around 31 1/4".
Coming from Cooper AT3 P265/76r17 at 35psi, my front fender went from 35 7/8" to 36 1/2".
Right now, new, they're quiet (didn't notice the difference coming from my AT3), ride nice on and off road. No noticeable vibrations or issues when braking hard.
Will update with mpg change after a few fill-ups.
Anyone running 255/75r17 C KO2's?-teakettle-jpg
GChristo is offline   Reply With QuoteReply With Quote
Old 04-18-2017, 03:51 PM #2
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
I'm running exactly that setup on my '06 Sport V8. I love it. I run at 40psi highway. Comfort and handling are great, they run very smooth, and there is no noticeable mileage hit. They've done great on the mountain passes on ski trips, as well. I have about 9000 miles on them thus far. I get 17 mpg at interstate speeds, about 17.5 around town, and 19 at more moderate (50-60mph) highway speeds.
I've only done a little bit of moderate off-roading with them, but they worked well. I don't have on-board air on the '06, so I didn't air them down.
I've also been running C-rated BFG KO's on my '94 for 8 years for more serious offroading and am very satisfied with the performance.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 04-19-2017, 11:28 AM #3
GChristo's Avatar
GChristo's Avatar
That's great. The tread-wear been even so far?
Old 04-19-2017, 12:37 PM #4
Real Name: Ron
Real Name: Ron
I haven't checked it with a calipers lately, but eyeball observation looks very good. If I think about it I'll make some measurements and post them.
Old 10-10-2017, 05:57 PM #5
alpha_king's Avatar
alpha_king alpha_king is offline
alpha_king is on a distinguished road
alpha_king's Avatar
Thanks
edit:
I've been looking into this same tire size of the BFG and can't find much info, so glad I found this!
I'm considering these KO2 255/75r17 with 5100's + wheelers T1 & T13 springs.
How did you like the setup? Any other photos? Thanks!
alpha_king is offline   Reply With QuoteReply With Quote
Old 11-14-2018, 04:35 PM #6
GChristo's Avatar
GChristo's Avatar
Back for an update at around 14K miles on these KO2's.
Still happy with these tires.
I notice some road noise now at around 35 or 40 mph (can't recall exactly) on certain paved road surfaces. I have to be paying attention to notice.
Did take a MPG hit coming from AT3, estimate between 0.5 to 1.
No wet weather complaints.
Yet to have a traction issue off-road in dry, dusty and rocky socal conditions.
Never had rub on Bilstein 5100's with stock OEM wheels. Switching to SCS F5 wheels I had liner rub in full turn reverse.
Settled on inflating to 45psi cold on-road and have had even tread wear so far. That psi is not pleasant for quick jaunts off-road if you're the lazy type.
2014 Trail w/KDSS - LT255/75r17 C KO2 - King C/O - Baja UT - 140/440 mobile - Dual Bat
Old 11-21-2021, 07:49 PM #7
David9962000 David9962000 is offline
Real Name: David
David9962000 is on a distinguished road
Real Name: David
Anymore feedback? Thank you
David9962000 is offline   Reply With QuoteReply With Quote
Old 11-22-2021, 04:18 PM #8
shiftgear's Avatar
shiftgear shiftgear is offline
Real Name: Arthur Czerniak
shiftgear is on a distinguished road
shiftgear's Avatar
That is the setup I am also looking for, stock 19 trd pro, however I want to get aftermarket wheels and go 16" on the rims.
shiftgear is offline   Reply With QuoteReply With Quote
Old 11-24-2021, 08:50 AM #9
Gstick Gstick is offline
Gstick will become famous soon enough
To use 16" wheels, you will have to grind some metal off of the calipers.
2010 4R SR5, "best 4 wheel vehicle that I've ever owned" TRADED !
2019 4R TRD Off Road
Gstick is offline   Reply With QuoteReply With Quote
Old 11-25-2021, 04:20 AM #10
shiftgear's Avatar
shiftgear's Avatar
Oh, I never knew that, maybe I will stick with the stock 17's then. Thanks for letting me know.
HTML code is Off
4 BFG Mud Terrain KO 255/75R17- SE VA- $450 dlavallee For Sale: Suspension/Wheels/Tires 3 12-21-2014 08:43 AM
Anybody running 245/75r17 tires? huntsonora 5th gen T4Rs 6 07-17-2013 05:29 PM
Anyone running Nitto Trail Grapplers 285/75R17 ? Lebengeek 5th gen T4Rs 4 12-08-2012 07:48 PM
255/75r17 cj80cruiser 3rd gen T4Rs 6 01-13-2012 12:15 PM
