trailtruck
At a glance it looks good... nice work
I would loom the positive cable, at least between the fuse and battery, for additional abrasion resistance/protection.
I think 3/8 is the correct size for 4 AWG... but dont quote me on it.
https://www.amazon.com/Burnstine-T-3...2F8+split+loom
Did you go with all the sizes in the thread like 4 AWG, 125A fuse, 100 breaker?
Aside from that, just make sure your ground connections are good, and the terminals/lugs are tightened down with an appropriate torque...
Is ground going to battery neg or to something else like the engine bay walls?
Also, this isn't necessary, but you can always get a paint pen and index / witness mark all your final connections. This way you can visually see if anything has moved or un-tightened over time without having to put a tool on it. Note the orange marks on the terminal/screws...
Example:
