Real Name: Ron
Real Name: Ron
I don't have numbers for a 97 handy, but for a 94 v6 valve cover, the torque spec is 48 in-lb, or 4 ft-lb. So, not a lot. More than finger tight, but not much.
They generally loosen up with age as the gasket shrinks. You can carefully snug them up, but don't over do it.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
