Old 03-31-2022, 08:02 PM #1
Ill4Runner's Avatar
Ill4Runner Ill4Runner is offline
Ill4Runner is on a distinguished road
Ill4Runner's Avatar
What is the best air pressure for my tires?
I recently had a new set of tires mounted. The shop aired them up to 40 psi. Is that the proper psi for my tires? I don’t haul anything I just commute. 4Runner info in my sig.
2017 4Runner TRD Pro
Ill4Runner is offline   Reply With QuoteReply With Quote
Old 03-31-2022, 09:38 PM #2
BadTrainDriver BadTrainDriver is offline
BadTrainDriver will become famous soon enough BadTrainDriver will become famous soon enough
25-32 PSI most likely. Chalk test them.
Using The Chalk Method for Determining PSI | Interco Tire
BadTrainDriver is offline   Reply With QuoteReply With Quote
Old 03-31-2022, 09:38 PM #3
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
If the tires are E rated, 40 psi sounds about right. Certainly not too high.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 03-31-2022, 09:40 PM #4
Load rating on the tire has nothing to do with the pressure to run, that's strictly for the weight of the vehicle.
Old 04-17-2022, 01:46 AM #5
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Tires have different ratings at different pressures.
LT tire load rating drops steeply under 35 psi and the chalk test isn't exactly state of the art. Chronic overheating reduces lifespan and can cause explosion. This is per about every tire manufacturer there is. Toyo has materials available online.
Now, I, too, don't follow recs blindly so I do 35-38 depending on the load and outside weather for my ATZ tires. If I were to follow advice blindly, I would have to run like 42-45 which would result in a terrible ride. The reason is that I base my pressures on my vehicle's weight and the tires' capabilities. By contrast, tire manufacturers look at nominal generic numbers.
But I don't run less than 35 except when I am on vacation and moving on pavement at lower speeds like around Ouray or Moab. Not worth the safety risk.
I have seen more than a few 4x4 with blown MTs on the interstates. My guess is chronic overheating due to always running them too low for highway conditions.
Also, there is no difference whatsoever in the load capacity between LTC, LTD, and LTE at pressures under 50 psi. The difference is that the more robust construction allows higher pressures which in turn allow higher load rating. But an LTE at 35 psi carries the same as an LTC and likely less than a P at the same pressure.
Old 04-17-2022, 01:50 AM #6
johnnygraphic johnnygraphic is offline
johnnygraphic has a spectacular aura about johnnygraphic has a spectacular aura about johnnygraphic has a spectacular aura about
I ran the tire pressure calculator in one of the other tire pressure threads on here and came out to 44 PSI. This is for the stock size and E Load tires. (Falken Wildpeaks AT3W). Aired them up and no issues over 1800 miles on a trip to Sedona. Aired down to 25 off road (Outlaw OHV Trail).
johnnygraphic is offline   Reply With QuoteReply With Quote
Old 04-17-2022, 09:37 AM #7
That's what I said, just in less words.
Old 04-17-2022, 09:57 AM #8
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
OEM recommendation stated on door jamb sticker is 32. Whatever anyone prefer and reason for it is their business.
<<<< is offline   Reply With QuoteReply With Quote
Old 04-18-2022, 12:17 PM #9
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
What is says on the door frame sticker.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 04-18-2022, 01:10 PM #10
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Do a chalk test to find out
How To Find The Right Tire Pressure For Your 4x4 Using Chalk - The Dirt by 4WP
Google "tire pressure chalk test"
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 04-18-2022, 04:56 PM #11
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
Yes, this should be the starting point. Load range, size, etc are secondary.
Start with the doorjamb spec, then maybe the chalk test as the next step.
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
don’t , haul , proper , psi , tires
HTML code is Off
LT tires need more air pressure. JB. Engines / Suspension / Wheels / Tires / Audio / Accessories 118 12-12-2021 01:05 PM
5th Gen 4Runner - Tires and Ground Pressure 1engineer 5th gen T4Rs 17 04-16-2013 12:47 PM
New Hankook tires pressure??? GLO Engines / Suspension / Wheels / Tires / Audio / Accessories 7 01-20-2013 11:18 PM
What Tire Pressure do you run on your Stock Tires? New03formeh Polls 4 06-25-2008 09:29 AM
Tires pressure desertrat Classic T4Rs 3 06-12-2006 04:13 PM
