Old 09-09-2019, 06:32 PM #46
4Regrets 4Regrets is offline
Real Name: Ben
4Regrets will become famous soon enough
Real Name: Ben
Is anyone running this tire in the P285/70R17? I'm thinking of trying some out to replace my E load rated 275/70R17 KO2s.
I'm curious if they run "big" or "small" for a 285. I'm attracted to the weight and the reported wet-weather performance.
2019 Midnight Black Limited with Beige Interior
275/70R17 Nokian Hakkapeliitta LT3 on FN FX Pro -- Winter
275/70r17 BFG KO2 on stock Trail wheels for summer/shoulder seasons
H11 to H9 low beam conversion
4Regrets is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 02:49 PM #47
Rebmit Rebmit is offline
Rebmit is on a distinguished road
Originally Posted by Wally517 View Post
Just replaced my old tires with these in 265/70/17 p rated. Very happy with them after a few thousand miles. Highway mileage went down by approximately 1 mpg. They have a nice aggressive look but are still understated. Solid choice so far especially if you spend most of your time on pavement.
Sent from my Pixel 3 using Tapatalk
Do you get any rubbing with this size? Reverse, full lock, etc.?
I've got the older AT3's in the 265/65/17 but am considering getting the new 4s in 265/70/17.
Love my AT3's.
Rebmit is offline   Reply With QuoteReply With Quote
Old 10-08-2019, 06:53 PM #48
ran ran is offline
ran is on a distinguished road
ran ran is offline
I have the new 265/70 on stock Sport Edition, no rubbing or problems. less than 1 K.
______________________
2007 SE V6 Titanium
ran is offline   Reply With QuoteReply With Quote
Old 10-27-2019, 12:51 PM #49
BamaTrav BamaTrav is offline
BamaTrav is on a distinguished road
I am close to pulling the trigger on these for the same reasons as you, except to replace a set of AT3's in 2757017C. Looking like the 275's will not be available anymore in C. I don't do much more than dirt and gravel roads so even the C's were probably overkill. After close inspection of my current setup, I will definitely need to do some adjusting/trimming to make these fit. Will post up my experience if I do.
BamaTrav is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 01:31 PM #50
Failed_1 Failed_1 is offline
Failed_1 is on a distinguished road
Same. Been thinking about the AT3 4S, but also hear great things about the Wildpeaks. been tossing these around as they seem like a similar tire.
Failed_1 is offline   Reply With QuoteReply With Quote
Old 01-01-2020, 02:53 PM #51
Just had the Cooper AT3 4s P285 70 17's installed yesterday as replacements for 275 70 17 Cooper AT 3's in C. 4Regrets Before my 275 Coopers I also ran the old BFG 275 70 17's in E. According to the specs the 285's are several pounds lighter per tire despite being 1/2 an inch larger in diameter and I believe just a bit over 1/2 an inch wider. Obviously the P rating is impacting the weight.
As with most folks upsizing their tires I wondered about rubbing. Checked things out this morning and only rubbing is on the front wheel liner at close to full lock. It is only touching that vertical ridge piece that sticks out into the wheel well about 1/2 an inch. If I trim or push the liner forward about a 1/4 of an inch it would clear.
Only have about 15 miles on the tires. Ride feels much softer in a good way. Also much more quiet than the 275's, but the tread wear on the 275's likely contributed to the increases loudness over the last year or so.
Last thought, to me the tire looks much larger than my 275 Coopers despite only being both only a 1/2 inch larger in diameter and approx. 1/2 inch wider in width. Will post up pics in a bit when I can remember how to do it.
Old 01-01-2020, 03:16 PM #52
Cooper Discoverer AT3 4s P 285 70 17
Cooper Discoverer AT3 4S-image-jpg
Old 01-14-2020, 12:34 PM #53
WAT4R's Avatar
WAT4R WAT4R is offline
WAT4R will become famous soon enough
WAT4R's Avatar
Update: Snow over the puget sound region the past few days means the first snow with the AT3 4S. Result...
Cooper Discoverer AT3 4S-20200113_145221-jpg
2018 CSM TRD OR, 5100 leveled, RSG sliders.
WAT4R is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 06:15 PM #54
jbinmd's Avatar
jbinmd jbinmd is offline
jbinmd will become famous soon enough
jbinmd's Avatar
Another update:
About 12k on my AT3 4S's and first real snow last week. Snow handling was amazing (5" fluffy snow with slush underneath).
Ride quality/noise had not increased. I'm very happy with these tires.
2014 4Runner Limited - Barcelona Red
LFD Offroad 3/4 Roof Rack, Eibach Pro-Truck suspension kit, TE rocker conversion, OEM running boards from a TRD OR, 17x8 -10 FN Countersteer Type-X wheels, Cooper AT3 4S tires 265/70-17.
jbinmd is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 09:23 PM #55
truc.karl truc.karl is offline
truc.karl is on a distinguished road
Just installed my Cooper AT3 4s last month and I'm very pleased with their performance. They are buttery smooth on the highway and no noise at all. Grip in the dry and wet pavement is good also. In the dirt, they hook up nicely though I haven't tried these cooper tires in deep mud and gravel yet.
truc.karl is offline   Reply With QuoteReply With Quote
Old 02-29-2020, 02:26 PM #56
aliasneo07 aliasneo07 is offline
aliasneo07 is on a distinguished road
I think I'll be going with these. 2020 4Runner ORP. 98% off driving is on pavement, but I take between 6-8 trips to Northern VA per year and go offroad. None of these trails are difficult, but one day I'd like to work my way up to intermediate.
The selection of tires is overwhelming but this seems to be the most suggested for a pavement T4R with the occasional off road.
aliasneo07 is offline   Reply With QuoteReply With Quote
Old 04-21-2020, 08:16 PM #57
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
This thread has pretty much sold me on the Coopers...thanks for all the reviews~~
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 05-15-2020, 04:55 PM #58
Deuxdiesel Deuxdiesel is offline
Deuxdiesel has a spectacular aura about Deuxdiesel has a spectacular aura about
Originally Posted by YBstranded View Post
I was surprised to see all of the positive comments regarding these in snow. I put a set on a 2014 Ram 1500 and they seemed to do OK at first, but really lost their grip after about 10k miles.
The tires I ran before them were the Cooper ST MAXX and they were phenomenal in the snow and dirt, but very pricey.
The AT3s were good tires and did surprisingly well in the dirt and rocks. Rode nice and seemed to wear OK.
But, up here, I have to have a tire that does exceptionally well in the snow.
Thinking about trying out the Kumho AT51 tire next...
Old post dig- I used the AT 51's on my 2nd gen 4Runner, my '10 Xterra and my '16 Frontier. They are a fantastic tire in snow, pretty quiet on the road and are priced reasonably. The most recent set I had on my Frontier gave me a lot of cold-morning "thump" and took a bunch of weight to balance, but the others not so much. It's a decent tire that looks great, but I think the QC could be better.
Deuxdiesel is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 02:31 PM #59
CoffeeIntern94 CoffeeIntern94 is offline
CoffeeIntern94 is on a distinguished road
Has anyone looked at running the Cooper LT's? I like all the praise that the AT3 4S gets, but I am curious if the LT's have anything more to offer? I don't really think I want 285s, which is the smallest size of the XLT, unfortunately.
2020 Super White ORP
CoffeeIntern94 is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 05:03 PM #60
Jargonyargon Jargonyargon is offline
Jargonyargon is on a distinguished road
Any additional updates on these after more miles? Maybe a brief road and trail manner description if you don't mind. I am considering this tire in 285, really wish they had a 275 offering though. And what kind of milage are you getting with these? I have to commute to trails/mountains so Im looking for a capable tire that isn't going to absolutely destroy milage. Thanks.
Jargonyargon is offline   Reply With QuoteReply With Quote
cooper , cooper discoverer at3 , discoverer at3 4s
HTML code is Off
Cooper Discoverer AT3 255/75/17 youngr Engines / Suspension / Wheels / Tires / Audio / Accessories 11 02-27-2014 04:20 AM
Cooper Discoverer ATP PLT? twojciac Off-Roading 5 10-23-2013 11:29 PM
FS: 285/70/17 Cooper Discoverer AT's jacob_wood Classifieds - buy & sell (no commercial ads please) 0 05-17-2011 07:04 PM
New Cooper Discoverer Gstick Engines / Suspension / Wheels / Tires / Audio / Accessories 0 04-26-2011 05:56 PM
