Old 04-30-2019, 03:23 PM #31
Thai's Avatar
Thai Thai is offline
Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold
Thai's Avatar
Originally Posted by 4runr4eva View Post
I believe
SL = 2 ply
E=10 ply.
SL = 44lbs.
E= 54lbs.
Sidewall is either 2- or 3-plies. You’re confusing sidewall with tread layers.
My 2019 Land Cruiser
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
Thai is offline   Reply With QuoteReply With Quote
Old 04-30-2019, 03:31 PM #32
4runr4eva's Avatar
4runr4eva 4runr4eva is offline
4runr4eva will become famous soon enough 4runr4eva will become famous soon enough
4runr4eva's Avatar
Thanks. Corrected. I saw it stated on a tire website, but not Generals so it is now a 2.
4runr4eva is offline   Reply With QuoteReply With Quote
Old 04-30-2019, 03:33 PM #33
4runr4eva's Avatar
4runr4eva's Avatar
4 NEW LT265/70-17 GENERAL GRABBER ATX 70R R17 TIRES 43618 51342191888 | eBay
This ad has it listed as 10 ply. Reputable dealer too. Not sure why General doesn't add the information on their website.
Old 04-30-2019, 03:47 PM #34
Thai's Avatar
Thai's Avatar
That’s the TREAD plies, not sidewall plies. You can tell by looking on the side of the tire. It should say...TREAD xx plies, SIDEWALL xx plies.
2023 Lexus GX
Lets Go Brandon!
Old 04-30-2019, 03:59 PM #35
Raptor008v2 Raptor008v2 is offline
Raptor008v2 is on a distinguished road
I've seen this tire in person (LT285/70R17). The actual, physical plies of the tread are: 2 polyester, 2 steel and 2 polyamide (nylon is an example of polyamide). The actual plies of the sidewall are 2 polyester. I've measured the sidewalls of the ATX (again in LT285/70R17) with an outside caliper and got approximately 8.5mm (previously I mentioned it was a little more than that but I've since remeasured and was consistently getting close to 8.5mm). I've got the same size and load rating in the BFG KO2's (3 ply sidewall) and consistently got 9.5mm. So the ATX is close but not quite the same thickness. The ATX is also about 2-2.5 lbs heavier than the KO2 in LT285/70R17. Hope this helps.
2017 4Runner TRD ORP - Barcelona Red // 285/70R17E BFG KO2 // FN F(x) Pros - Matte Black // JBA UCAs // Ironman Foam Cell Pros // Demello Hybrid Sliders // Pelfreybilt Front Bumper - Aluminum // Baja Designs 30" S8 // Baja Designs Squadron Sports // ARB Safari Snorkel // ARB Rear Diff & E-Locker Breather // RCI Engine, Transmission and T-Case Skid Plates - Aluminum
Raptor008v2 is offline   Reply With QuoteReply With Quote
Old 04-30-2019, 04:07 PM #36
4runr4eva's Avatar
4runr4eva's Avatar
Thank you. I appreciate the help as I was totally confused by those numbers.
Old 05-03-2019, 11:54 AM #37
SkidPalace's Avatar
SkidPalace SkidPalace is offline
SkidPalace is on a distinguished road
SkidPalace's Avatar
Having mine installed tomorrow morning. I really hope they are quiet. Stock 265/70r17 P-rated on TRD Pro wheels for my Limited.
2015 Magnetic Grey Limited with Redwood interior. 275/55r20 Michelin Defender LTX on stock wheels. Daystar 2.5/1.5 puck lift.
Gone but not forgotten: Black 2000 SR5 "Highlander", Supercharged, Black pearl emblems, Factory e-Locker.
SkidPalace is offline   Reply With QuoteReply With Quote
Old 05-07-2019, 01:44 PM #38
ToyoTex's Avatar
ToyoTex ToyoTex is offline
ToyoTex is on a distinguished road
ToyoTex's Avatar
Originally Posted by MAST4R View Post
Was that the P-metric or the LT-E version? At what psi did it happen?
Thanks!
Sorry about the delay in response!
He has the LT-E and didn't air down far enough :-)
2019 LE Nautical Blue|"Onroader"
2017 Chevrolet Silverado LT Z71 Summit White|"Bess" - SOLD: 12,500 MI, 1.5 years ownership TOO BIG
1999 Mercedes ML320 White|"Rustbucket" - DONATED: 335,000 MI, 20 years ownership I MISS IT EVERY DAY
ToyoTex is offline   Reply With QuoteReply With Quote
Old 05-07-2019, 02:01 PM #39
Swipter Swipter is offline
Swipter will become famous soon enough Swipter will become famous soon enough
So that's an issue that can happen with any tire, regardless of tread plies?
Swipter is offline   Reply With QuoteReply With Quote
Old 05-07-2019, 07:14 PM #40
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Thanks!
Yes.
Generally, P-metric tires are not part of offroad discussions and for LT metric it goes like this:
Air down offroad for:
1/ Comfort. Normally 20sh should ok.
2/ Traction. I am sure there is a thread about what psi for what conditions, it also depends on wheels, loads, etc.
3/ Prevent through-the-tread punctures like that.
As for P-metric tires, few of us do a lot of offroading on those and it is different as they are more likely to burst a sidewall when run at lower pressures. They also deflect plenty at 30-33 psi and so there is no need to air down for comfort or traction, except on deep, soft surfaces.
Old 05-07-2019, 11:08 PM #41
Decipher's Avatar
Decipher Decipher is offline
Real Name: B-Money
Decipher is a jewel in the rough Decipher is a jewel in the rough Decipher is a jewel in the rough Decipher is a jewel in the rough
Decipher's Avatar
Real Name: B-Money
General Grabber ATX tire
Nice looking tire but the design is in line with the Ridge Grappler and a few others I’ve noticed in that the actual tread contact patch is more narrow than the actual tire by design. What I mean by this is the sidewall steps inward a good deal before the tread actually begins. I never paid much attention to this until I got my Grapplers. I don’t like this for two reasons; 1, the aesthetics of this look make the tire look smaller than it actually is and, more importantly, this design lends to less contact width on your driving surface. As measured, my RGs only have a contact patch of 9” when the tire itself is over 11” wide. I don’t care for this because it upsets my pursuit and desires in my off roading tire.
Just be aware of this for those it may matter to. An example of a tire achieving the advertised width would be the KO2 and Falken AT3W by design of the sidewall integrating into the tread.
Anger Fuels Motion...Motion Fuels Momentum...Momentum Fuels Action...DO SOMETHING!
2010 4Runner SR5
Decipher is offline   Reply With QuoteReply With Quote
Old 05-08-2019, 11:08 AM #42
bsufan bsufan is offline
bsufan is on a distinguished road
Okay I have decided to go with these tires in stock size on my stock SR5 wheels.
What I haven't decided is the p or LT version.
P version is $35/tire cheaper, 12 lbs lighter.
90% of my driving is around town and highway, 10% is forest service roads.
I MAY drive the thing from atlanta to colorado this fall and do some back country style camping. that is the only reason I think I need the LT version unless one of you convinces me otherwise. Am i taking too much puncture risk with the P rated tire?
I missed the TRD pro wheel sale or I'd be like everyone else here and upgrading to those wheels too. sad about that.
bsufan is offline   Reply With QuoteReply With Quote
Old 05-08-2019, 11:28 AM #43
MAST4R's Avatar
MAST4R's Avatar
Here is my latest on the P use offroad subject, maybe it will help you decide:
https://www.toyota-4runner.org/3282400-post1412.html
Old 05-12-2019, 05:46 PM #44
bring_it_on's Avatar
bring_it_on bring_it_on is offline
bring_it_on will become famous soon enough bring_it_on will become famous soon enough
Do the A/TX's in 275 70 R17 fit a 4runner?
bring_it_on is offline   Reply With QuoteReply With Quote
Old 05-13-2019, 01:43 PM #45
quicksandTRDPRO's Avatar
quicksandTRDPRO quicksandTRDPRO is offline
Real Name: Trent
quicksandTRDPRO is on a distinguished road
Real Name: Trent
Yes. You may have to modify the fender liner a bit if you haven't already.
2016 Quicksand TRD PRO
quicksandTRDPRO is offline   Reply With QuoteReply With Quote
feel , general , grapplers , tire , tires
HTML code is Off
General Grabber AT2 vs X3 RoadRunner69 5th gen T4Rs 17 05-01-2019 07:05 PM
Tire Poll: general grabber at2 vs Falken wildpeak a/t3 alia176 Engines / Suspension / Wheels / Tires / Audio / Accessories 16 06-02-2017 06:35 PM
Tire Advice - Kumho, Continental & General Grabber HiDEF Engines / Suspension / Wheels / Tires / Audio / Accessories 7 01-11-2016 06:41 PM
General Grabber AT/2 Buckfever Engines / Suspension / Wheels / Tires / Audio / Accessories 4 02-23-2015 07:54 PM
General Tire Grabber HTS. Who has them?? I'm thinking of buying tomorrow baronvdb Engines / Suspension / Wheels / Tires / Audio / Accessories 8 10-20-2013 01:19 AM
