Old 06-10-2019, 04:12 PM #46
skag1T skag1T is offline
skag1T is on a distinguished road
Originally Posted by Raptor008v2 View Post
I've seen this tire in person (LT285/70R17). The actual, physical plies of the tread are: 2 polyester, 2 steel and 2 polyamide (nylon is an example of polyamide). The actual plies of the sidewall are 2 polyester. I've measured the sidewalls of the ATX (again in LT285/70R17) with an outside caliper and got approximately 8.5mm (previously I mentioned it was a little more than that but I've since remeasured and was consistently getting close to 8.5mm). I've got the same size and load rating in the BFG KO2's (3 ply sidewall) and consistently got 9.5mm. So the ATX is close but not quite the same thickness. The ATX is also about 2-2.5 lbs heavier than the KO2 in LT285/70R17. Hope this helps.
Does the KO2 in P rating have the same 3-ply sidewall strength as the LT rating version ? Can anybody confirm ?
Same question for the ATx, how does the sidewall strength compare between the P rating and LT rating.
skag1T is offline   Reply With QuoteReply With Quote
Old 06-14-2019, 09:13 AM #47
mitchell.marsh mitchell.marsh is offline
mitchell.marsh is on a distinguished road
I am having the issue with my 2015 4Runner, I went all the way through that process. Brand new tires and same problem. Toyota rep came out and road with me and said he didn't feel a thing. Well, he was about 250lbs (big and tall) plus the service manager about 240lbs and me 115 lbs. while they were in the car I didn't feel a lot of shaking/shimming etc.
mitchell.marsh is offline   Reply With QuoteReply With Quote
Old 06-18-2019, 08:39 PM #48
Raptor008v2 Raptor008v2 is offline
Raptor008v2 is on a distinguished road
I don't believe the KO2 in that rating has a 3-ply sidewall. Not even the C-load LT KO2 has 3-ply. I don't know much about the P-rated ATX.
2017 4Runner TRD ORP - Barcelona Red // 285/70R17E BFG KO2 // FN F(x) Pros - Matte Black // JBA UCAs // Ironman Foam Cell Pros // Demello Hybrid Sliders // Pelfreybilt Front Bumper - Aluminum // Baja Designs 30" S8 // Baja Designs Squadron Sports // ARB Safari Snorkel // ARB Rear Diff & E-Locker Breather // RCI Engine, Transmission and T-Case Skid Plates - Aluminum
Raptor008v2 is offline   Reply With QuoteReply With Quote
Old 07-19-2019, 10:41 AM #49
dug23 dug23 is offline
dug23 is on a distinguished road
Originally Posted by Nefarioc View Post
I intend on getting these tires. Does anyone know what size these come with the Red lettering on the side walls?
The General A/TX is not offered in red lettering, only the X3 and discontinued Grabber were.
dug23 is offline   Reply With QuoteReply With Quote
Old 07-28-2019, 09:44 AM #50
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
So since some of you have been running these for a while, how are they in water and rain? It rains a lot here on the gulf.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 07-29-2019, 05:16 PM #51
@Signal : they have excellent wet traction, I live in Seattle and am very happy with these tires. I run them at 38 psi, and still wasn't able to spin them on wet roads.
Old 07-29-2019, 06:07 PM #52
quicksandTRDPRO's Avatar
quicksandTRDPRO quicksandTRDPRO is offline
Real Name: Trent
quicksandTRDPRO is on a distinguished road
Real Name: Trent
Agreed, wet traction is great. Snow and ice traction are great too. Still loving these tires!
2016 Quicksand TRD PRO
quicksandTRDPRO is offline   Reply With QuoteReply With Quote
Old 07-29-2019, 06:45 PM #53
Thanks, I miss the A/T2's but I might go to the X3's . I want a beefy tire and I am waiting for a discount tire sale.
The Build
Old 08-13-2019, 03:27 AM #54
d.hamstr d.hamstr is offline
d.hamstr is on a distinguished road
So I'm on the wait list for a 2020 TRDORP and the first thing(okay, maybe 2nd/3rd behind lights) I'd like to get are new tires. I'm leaning towards the ATX in stock P265/70/17 and would like to hear more about others' experience(s) w/ these tires! I'll be driving ~85-90% city/highway with the occasional 1-day offroading once or twice a month.
I'd like to add that, though SoCal isn't known for much rain, wet performance is a top priority and I'll be hitting Mammoth/Big Bear during snow season.
d.hamstr is offline   Reply With QuoteReply With Quote
Old 08-28-2019, 08:25 AM #55
Matt831 Matt831 is offline
Matt831 will become famous soon enough
How are these balancing? Anyone having trouble getting a good balance?
Matt831 is offline   Reply With QuoteReply With Quote
Old 09-19-2019, 09:59 PM #56
Aspen Thicket Aspen Thicket is offline
Aspen Thicket is on a distinguished road
Yes...road forced twice and still get an intermittent shimmy in the steering wheel above 60 mph.
Aspen Thicket is offline   Reply With QuoteReply With Quote
Old 09-20-2019, 01:28 PM #57
Real Name: Trent
Real Name: Trent
I've had zero issue with balancing. Maybe you got a bad set, or it's something else?
Old 09-20-2019, 02:45 PM #58
I dunno but my 2019 TRD OR only has about 11K on the odometer and was like glass with the factory tires.
Now I get intermittent shimmy in the steering wheel and the only thing changed was the tires.
Old 09-26-2019, 12:02 PM #59
FUseaKU FUseaKU is offline
Real Name: Derek
FUseaKU is on a distinguished road
Real Name: Derek
Those look great man!!
I'm in the market for new tires on mine and I'm stuck between these and the Falken Wildpeak A/T3W's.
Can anyone persuade me in my choice please? I've never bought A/T tires before, so I'm having a hard time. Thanks in advance!
FUseaKU is offline   Reply With QuoteReply With Quote
Old 09-26-2019, 03:33 PM #60
Decipher's Avatar
Decipher Decipher is offline
Real Name: B-Money
Decipher is a jewel in the rough Decipher is a jewel in the rough Decipher is a jewel in the rough Decipher is a jewel in the rough
Decipher's Avatar
Real Name: B-Money
You really should read the Falken AT3W thread if you have the time or want an abundance of information. I’ll save you the hassle...The Falkens have absolutely crushes the market.
I have tried three of the most popular tires out there (Falken AT3W, BFG KO2 and Nitto Ridge Grappler) and the Falkens are the hands down winner.
There have been exceptions here with the Generals and with the Falkens for some people, but the overwhelming consensus is that the Falkens are the tires to beat.
Anger Fuels Motion...Motion Fuels Momentum...Momentum Fuels Action...DO SOMETHING!
2010 4Runner SR5
Decipher is offline   Reply With QuoteReply With Quote
feel , general , grapplers , tire , tires
HTML code is Off
General Grabber AT2 vs X3 RoadRunner69 5th gen T4Rs 17 05-01-2019 07:05 PM
Tire Poll: general grabber at2 vs Falken wildpeak a/t3 alia176 Engines / Suspension / Wheels / Tires / Audio / Accessories 16 06-02-2017 06:35 PM
Tire Advice - Kumho, Continental & General Grabber HiDEF Engines / Suspension / Wheels / Tires / Audio / Accessories 7 01-11-2016 06:41 PM
General Grabber AT/2 Buckfever Engines / Suspension / Wheels / Tires / Audio / Accessories 4 02-23-2015 07:54 PM
General Tire Grabber HTS. Who has them?? I'm thinking of buying tomorrow baronvdb Engines / Suspension / Wheels / Tires / Audio / Accessories 8 10-20-2013 01:19 AM
