Old 04-23-2020, 06:16 PM #1
otter7's Avatar
otter7 otter7 is offline
otter7 is on a distinguished road
otter7's Avatar
Will They Fit? 285/70R17 Tires and New Rims
I have searched up and down this thread and cannot seem to find an answer to my questions so hopefully you all can help.
I have a 2020 4Runner ORP and am looking at getting the Bilstein 6112 for the front and 5160 for the rear and keeping stock rear coils. With that lift, i am looking to also upgrade my wheels: BF K02 285/70R17 tires with Fuel D600 Vector rims (17" x 8.5", +7 Offset, 6x139.7 Bolt Pattern, 108mm hub).
My question is - has anyone ran a 8.5"W wheel with a +7 offset on 285 tires? Did you have any rubbing issues? How did they look?
Bonus: Will the new set-up fit in the spare tire area underneath the 4R.
Bruce the 2020 Super White TRD ORP
IG: @bruce_the_4runner
Suspension: Bilstein 6112/5160. Wheels: Method 305-NV Bronze. Tires: BFGoodrich K02 285/70R/17. Pro Grille. Plastidip black emblems and valances. Fog light Bezel.
otter7 is offline   Reply With QuoteReply With Quote
Old 04-24-2020, 12:48 PM #2
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Wheel Offset Calculator
I get confused with all this offset and crap but most 285s rub something. My FNs -10mm offset rub the front fender had to do some plastic trimming.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 05-02-2020, 02:26 PM #3
otter7's Avatar
otter7's Avatar
Thanks Dillusion. I ended up going with different rims - Method NV 305. I get them installed in a couple of weeks along with the 285 KO2s and they will need slight trimming, but should be great - and should fit in the spare tire area.
Old 05-04-2020, 08:12 AM #4
safdSA safdSA is offline
safdSA is on a distinguished road
Slightly off topic, why not get the rear springs too? I have the same set up and got their springs all around. It's not that much more $ and you'll have it all apart anyway. Rides SO much better than stock.
Good luck with the wheels, should look cool!
safdSA is offline   Reply With QuoteReply With Quote
Old 05-04-2020, 11:53 AM #5
Timc03 Timc03 is offline
Timc03 is on a distinguished road
I am running the method 305 NV's as well. I have bilstein 5100's all the way around and i just had to do minor trimming. You can get away without trimming if you wanted but you would just not want to turn your steering wheel all the way because it will rub a little. other than that its perfect. I am also running the firestone MT tires in a 285/70/17
Timc03 is offline   Reply With QuoteReply With Quote
Old 05-04-2020, 02:09 PM #6
otter7's Avatar
otter7's Avatar
I was thinking about adding them as well, but from what i have researched on this forum, read, and heard from off-roading friends, unless you have the weight to help with the ride, upgraded springs at this point will ride rough. Since this is my daily commuter as well, i figured i'd wait until i have the added weight from sliders, rack, and skids until adding them.
Old 05-04-2020, 02:10 PM #7
otter7's Avatar
otter7's Avatar
Nice Timc03. I spoke with the install guy and he is going to do minor trimming so should be all set.
Old 05-07-2020, 12:42 PM #8
Frodaddy Frodaddy is offline
Frodaddy is on a distinguished road
Just remember that 4 Runners do not have a very steep rake like a pickup truck does. 2.5" lift in the front will probably have you around 1" nose high. But that is the style in SoCal!
If you go with rear springs, run the Bilstien's standard rate, they do actually ride better than stock!
Frodaddy is offline   Reply With QuoteReply With Quote
Old 05-26-2020, 11:01 PM #9
truc.karl truc.karl is offline
truc.karl is on a distinguished road
Post some pics when you are done installing your new wheels/tires. Fuel rims are a good choice. I like the style and color of their D600 Vectors.
truc.karl is offline   Reply With QuoteReply With Quote
fit , rear , rims , stock , wheels
HTML code is Off
Can someone post a pic of a 5th gen with TRD rims wrap in 285/70r17... KalihiRunner 5th gen T4Rs 8 09-14-2016 05:39 PM
WTT: FJ Cruiser rims and tires for Limited Rims and tires A_HuL For Sale: Suspension/Wheels/Tires 2 09-12-2012 09:50 PM
265/70R17 Mud Tires blk-4runner 4th Gen T4Rs 6 05-15-2012 10:23 PM
315/70R17 on stock rims?? 4runnerfourplay 4th Gen T4Rs 4 05-14-2009 04:37 PM
