Old 02-17-2019, 12:15 AM #1
bradze bradze is offline
Real Name: Brad Zellner
bradze is on a distinguished road
tire pressure recommendation
I bought my 4runner used with LT285/70r17 BFG TA KO2 tires. how much pressure should I be using? 45PSI?
'16 SR5, 285/70/R17 BFG T/A KO2, REVTEK 3"/2" LIFT, TRD WHEELS, WESTIN RUNNING BOARDS, ARB AWNING/TENT, WARN SEMI-HIDDEN WINCH MOUNT, SMITTYBILT XRC WINCH, METAL-X GRILL W/ 20" LIGHTBAR, PRINSU 7/8 ROOF RACK, EXTREME LED 38" LED LIGHTBAR, REAR LED LIGHTS, sPOD, Baja designs fog and ditch lights on rago brackets, interior accessories radio mount, hi lift mount, traction boards, spidertrax 1.5" wheel spacers
bradze is offline   Reply With QuoteReply With Quote
Old 02-17-2019, 12:35 AM #2
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R is just really nice MAST4R is just really nice MAST4R is just really nice MAST4R is just really nice
MAST4R's Avatar
I think that for any LT (C,D,E) in 265 70 17 the correct pressure is 44. That's what I was told by Nitto for the Ridge Grappler in C but I am pretty sure that C/D/E is the same for this, just that you can run D higher than C and E higher than D to support higher loads.
Since your tires are bigger, you may be able to run a bit lower psi to support the same load with reserve capacity similar to oem. Tire Pressure Checker: Righting the Pressure in Your New Tires | 4wheelparts.com
Old 02-18-2019, 08:03 PM #3
<<<<'s Avatar
<<<< <<<< is offline
<<<< will become famous soon enough
MY GARAGE
<<<<'s Avatar
MY GARAGE
What is your label on driver's door jam recommend? Now, without opening whole can of worms, why is everyone insists on running pressures in Mountain Bicycle (45-50 psi)and some here even in Road Bicycle (50-100 psi) ranges? You stated 285/70/17 tire which is not OEM size but your inflation pressure shouldn't be much if any different from 265/70/17.
Who Dares Wins
2013 TRAIL KDSS / Forged TRD 17x8.5 Wheels / Nitto TG 285/70/17 / Shrockworks Sliders / ASFIR Aluminum Trans Skid / 5000K HID Low HL / 5000K 10000 Lumen LED High HL /3000K LED Fogs / TRD Billet Oil Cap / B&I Carbon Fiber Dash / TRD Black Shift Knob / LED Interior / XUJI Leather Steer Wheel / Aluminum Pedals / Aluminum Battery Holddown / Northstar AGM battery / TRD Carpet Mats / LED floor lights / ARB on-board Air
<<<< is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 12:46 AM #4
MAST4R's Avatar
MAST4R's Avatar
Except he is running LT tires on a vehicle that came with P metric.
This is a good start:
LT tires need more air pressure.
Old 02-19-2019, 12:43 PM #5
<<<<'s Avatar
MY GARAGE
<<<<'s Avatar
MY GARAGE
Yes "definition "LT," signifies the tire is a "Light Truck-metric" size that was designed to be used on vehicles that are capable of carrying heavy cargo or towing large trailers..." I heard all discussions about those. It is what it is, you want stiff but let you believe more responsive ride get a truck tire inflate it to xx psi and call it a day if that makes you happy. Is to each their own.
Who Dares Wins
Old 02-22-2019, 01:38 AM #6
jicko jicko is offline
jicko is on a distinguished road
That's one of the best thread to go by, IMHO.
I am on my 2nd set of KO2, I have always been running it at 44 or 45psi. Before concluding to run this pressure, I did a lot of research (including the reference thread above), and I also did a series of drive tests in a period of a couple of weeks varying the pressure from 30 something to like 50 psi. I found that I like 44psi the most.
2015 SR5 Premium 4x4 / 3rd row seat
Jicko's Build & Adventure Thread
"Group buy, anyone?"
jicko is offline   Reply With QuoteReply With Quote
Old 02-28-2019, 01:46 PM #7
Decipher Decipher is offline
Real Name: B-Money
Decipher has a spectacular aura about Decipher has a spectacular aura about
Real Name: B-Money
OP, this is going to be subjective. The very best thing you can do is chalk test your tires to see what pressure works best for you.
Iím using the exact same tire (C-load) and my tires tested out best at 38 all around. If Iím loading down, then 40 rear. I get good ride compliance, good chalk lines, and they are properly stiff for daily use.
Anger Fuels Motion...Motion Fuels Momentum...Momentum Fuels Action...DO SOMETHING!
2010 4Runner SR5
Decipher is offline   Reply With QuoteReply With Quote
Old 03-01-2019, 05:14 PM #8
lincolnsmullet lincolnsmullet is offline
lincolnsmullet is on a distinguished road
I can agree with this.
lincolnsmullet is offline   Reply With QuoteReply With Quote
Old 03-02-2019, 08:16 PM #9
thanks, im gonna go with 45psi
Old 03-03-2019, 11:22 AM #10
Real Name: B-Money
Real Name: B-Money
Based on what?
Only reason I ask is that some people swear by one pressure while others swear by others. Trust me, Iíve read for hours on this. The consensus at the time I read was 38-40 and guys said they were getting the best results.
Those numbers got me in the ballpark of where to test my chalk lines. Donít simply decide your pressure based on what other people say. Go out and test for yourself. What works for one doesnít work for others.
Case and point; For me, at 45 I can visually see that my outer tread blocks were no where near touching pavement. Once I got rolling and pressure increased, it got even worse. That would lead to awful wear if I rode on that.
2010 4Runner SR5
Old 03-03-2019, 05:26 PM #11
ok, so 40 then
Old 04-28-2019, 01:43 AM #12
ninjaboym5 ninjaboym5 is offline
ninjaboym5 is on a distinguished road
I am running 28 cold after changing to 285/70/17. I am always under the impression the bigger volume tire run less air. My daily driver came with 21 inch stock wheels and running 42 cold from the factory.
ninjaboym5 is offline   Reply With QuoteReply With Quote
Old 04-29-2019, 05:52 PM #13
Dillusion Dillusion is offline
Dillusion has a spectacular aura about Dillusion has a spectacular aura about Dillusion has a spectacular aura about
45 here on Nitto Trail Grapplers
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 05-01-2019, 06:50 PM #14
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is on a distinguished road
MY GARAGE
rdruss's Avatar
Real Name: Ron
MY GARAGE
I have an '03 V8 Ltd AWD with Michelin Defender Lt265/65R17 installed for 2-/12 years.
I run them at 37 psi, rotate a different tire to spare every November and May.
They perform very well in northern Illinois weather and are wearing very evenly after 25K miles and on-road service only, mostly low speed city driving.
For what it's worth.
Old 07-04-2019, 03:09 PM #15
mitchell.marsh mitchell.marsh is offline
mitchell.marsh is on a distinguished road
Hi all, could you please advice me in a short, what is the best way to check tire pressure of Toyota?
mitchell.marsh is offline   Reply With QuoteReply With Quote
bfg , ko2 , pressure , tire , tires
HTML code is Off
Tire recommendation Neil Howe 3rd gen T4Rs 1 06-15-2017 06:05 PM
Premature tire dryrot (pic!) and new tire recommendation krmccour 3rd gen T4Rs 15 12-14-2013 05:56 PM
Tire recommendation wingshootin 5th gen T4Rs 4 06-30-2012 03:28 PM
Need tire recommendation 265/65 17 nauticalniremor Engines / Suspension / Wheels / Tires / Audio / Accessories 1 09-08-2011 01:26 PM
Tire Pressure & Max Rated Tire Pressure Phil 4th Gen T4Rs 7 03-10-2004 10:49 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
