Old 04-05-2022, 09:26 PM #16
PJSnow's Avatar
PJSnow PJSnow is offline
PJSnow will become famous soon enough
PJSnow's Avatar
Bringing this back to ask a related question instead of starting a new thread. Forgive me for being a car audio newb...
I understand the dash tweeters and front door woofers work in tandem to provide the front sound. I am looking at replacing speakers only, no additional amp (please not try to convince me to add an amp).
Will replacing the front door woofers with 2-way speakers provide any benefit (would that make 4 tweeters in the front?)? Or would that just negate the dash tweeters? Would this provide better sound quality?
PJSnow is offline   Reply With QuoteReply With Quote
Old 05-09-2022, 12:36 PM #17
Bobby12many's Avatar
Bobby12many Bobby12many is offline
Bobby12many will become famous soon enough
Yes - you would effectively have 4 tweeters in the front of the vehicle if you replaced the door speakers with coax and left the dash speakers stock. Whether this is a benefit or not will come down to your equipment, install and listening preferences. Some people like powerful and sharp "highs" (treble, vocals, etc) in their setups; but more often than not adding redundant high frequency drivers to a system creates nothing but issues.
Theoretically speaking, you would be better off adding a 4ohm 3-4" coaxial (2-way) in the dash and replacing the door speakers with a 2ohm mid-bass/woofer. This will keep the frequencies separated as designed from factory, while adding better response and output.
Bobby12many is offline   Reply With QuoteReply With Quote
Old 05-09-2022, 12:52 PM #18
PJSnow's Avatar
PJSnow's Avatar
Thanks for getting back to me!
After doing a little more research (and not hearing back on this thread), I decided to pull the trigger on the OEM Audio + speakers. I found a used set and got a good deal on them. Figured it was the easy solution that is plug and play. They sound better than stock and I think I'm content with the sound for now.
Old 05-09-2022, 01:07 PM #19
Great call there. OEM+ takes the guesswork out of it and ensures that the proper loads and frequencies are accounted for.
If you don't mind me asking - how much did you scoop the used speakers for? I am in the process of buying the equipment to add DSP/Amp + 3 way front components and Subwoofer, but want to leave the rear speakers running off the HU. I may keep on the lookout to go OEM+ with them if a deal comes around....
cheers
Old 05-09-2022, 03:54 PM #20
PJSnow's Avatar
PJSnow's Avatar
cheers
Thanks! I only went with the speaker upgrade because I don't want to loose any storage space in the rear (yes the subs are elegantly integrated but every square inch counts).
I'd say it will be hard to find a used set of OEM Audio + speakers because most will either enjoy them or not bother parting them out when they sell. I was lucky to find someone upgrading the entire audio system to a one-off custom setup and they decided to let go of their speakers.
cheap , entune , kickers , speakers , started
HTML code is Off
Pandora + Entune question (Skips) chris_1001 5th gen T4Rs 5 12-14-2017 11:26 AM
Question on Entune in 2016 T4R Limited Ixz72 5th gen T4Rs 2 08-14-2017 06:18 PM
Stock entune w/ nav non jbl question.... shawn474 5th gen T4Rs 6 06-08-2017 11:03 PM
Entune head unit question dsimonl 5th gen T4Rs 1 03-15-2017 08:18 AM
Question on Entune Nav - Nighttime Dimming? Ryan1975 5th gen T4Rs 6 06-13-2012 07:37 PM
