BOSLLA Bullet H11, review.
Jarheadoo7
BOSLLA H11 H8 H9 LED Headlight Bulbs Kit High Low Beam Fog Light Super Bright US | eBay
If you don’t know, these bulbs have 4 functions or settings all controlled with your factory on/off switch.
On-6500k (white)
off/on 4300k (white-ish)
Off/on 3000k (yellow)
Off/on 3000k flash
The color changes are helpful for rain or snow which I drive in plenty because I live in Ohio (where the seasons change by the hour these days) and thought it to be useful.
Install was as easy as a regular bulb install. The only tinkering was how to zip tie the dingle-berry box thing that comes with the BOSLLA bulbs. I drilled two small holes in the passenger fog wiring cover to zip tie secure all the wiring and the dingle-berry box thing under the cover. The driver side was easy, there was a hole in the inner fender that worked perfect to zip tie everything to.
Holy crap, they are bright but I am a lighting novice. This is the first set of driving bulbs I’ve installed that weren’t OEM replacement. Being used to the stock lighting I think they are bright.
The bulbs always start at 6500k. If you switch to a different mode to run then wait 5 seconds or longer, hit the fogs on/off they will go back to 6500k again. So essentially if you are running yellow and you flash someone the fogs will reset to white and you’ll have to scroll through to get back to yellow.
As i just mentioned, a downside or potential downside (I’ve only had them installed an hour and driven up and down the road to the Carwash and back) is if you do the high beam flash to tell people to go at an intersection or you switch between your low and high-beams often you will cycle through the color modes on the fogs, which can probably get annoying.
Aside from that I’m pretty happy with them for now. I can imagine I’ll get flashed from oncoming traffic that’s how bright i feel they are. I’ll keep this post updated.
Here is a link to the photos and a video, you can really see the color and brightness on the right side in the garage doors..
BOSLLA Bullet, H11 - Album on Imgur
AndiGarage
