Old 06-13-2019, 10:25 PM #31
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
Originally Posted by GAsr5 View Post
Need to clarify - subwoofer DOES work when we hooked one up. What didn’t work was the sub remote. It did not change the volume of the sub.
Everything sounded fine when we hooked up the sub(we just put one in to test, haven’t purchased one yet). However, alternator/engine wine still present and static noise when turning on the car
check to see if the plug is all the way in, its good to unplug and plug it back in. i think it just control the volume to the sub and not boost.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 06-14-2019, 10:02 PM #32
GAsr5 GAsr5 is offline
GAsr5 has a little shameless behaviour in the past
Should I just axe the EZQ all together? I just want the static to go away. When I get them to rewire it I may just take the ezq out if I don’t need it.
If I get this Rockford Fosgate Power T1000X5ad Compact 5-channel car amplifier — 100 watts RMS x 4 at 2 to 4 ohms + 600 watts RMS x 1 at 1 to 2 ohms at Crutchfield.com
Can I run just this and call it a day? Confused on what is required(besides an amp of course). I want only what I need to power door speakers and a sub. Nothing else. As little equipment as possible.
GAsr5 is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 06:37 AM #33
MikeyMTBs MikeyMTBs is offline
MikeyMTBs is on a distinguished road
Am I getting the run around - audio install
You don’t NEED the recurve, it just takes the muddy output from the stock head unit, conditions the music based on your inputs/changes and then sends it to the amp for amplification and then back out to the speakers.
If that is the cause of your noise, I might try bypassing it first to ensure that is the source of your noise.
Also, turn on noise, or turn on pop can be caused by the amp turning on before the processor. I’m not familiar with the recurve but I believe there should be a way to delay the signal from the recurve to the amp to give the recurve time to fire up.
I had the same issue with an AudioControl unit. I finally ditched it and put in a JL Audio Fix 86 and that worked perfectly.
Good luck man.
MikeyMTBs is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 03:51 PM #34
Good luck man.
Any issues with the 86? Are you using any type of EQ now? My tweeters are pretty bright. Too harsh in some instances.
Would you recommend me doing that? I don’t mind spending money and I know I’m going to have to. What I do have a problem with, is spending money for no reason to diagnose one problem and not have a real solution. I don’t want to just throw money around for no purpose.
I’d rather just do it once and do it right than trying a bunch of different things that my shop is going to charge me $110 per hour to look at and fix.
amp , ohm , output , subwoofer , watts
HTML code is Off
First audio install on 3rd gen bspurs Engines / Suspension / Wheels / Tires / Audio / Accessories 0 12-18-2013 02:47 PM
2011 Audio install ChipG 5th gen T4Rs 63 07-01-2012 12:01 AM
Non-glamorous Audio Install 01 sr5 Run4urLife Engines / Suspension / Wheels / Tires / Audio / Accessories 7 06-18-2008 05:37 PM
My audio install patau13 Engines / Suspension / Wheels / Tires / Audio / Accessories 16 05-17-2007 04:28 PM
My Audio Install 99LimitedKS Engines / Suspension / Wheels / Tires / Audio / Accessories 0 01-06-2007 10:16 PM
