Old 06-23-2019, 11:41 AM #1
texasrimfirenut texasrimfirenut is offline
texasrimfirenut is on a distinguished road
Duh, I just dont understand tire size stuff
Guys, I am just not getting it.
I have a 2019 T4R Off Road Premium and I am having a three inch lift put on it this next week.
Currently it has 265-70-17's
I understand that a 285 is a wider tire but will it fit on my current rims?
I am researching and studying but still don't understand how large of a tire I can reasonable put under it and not worry about having to do any further mods than the lift kit nor worry about rubbing.
texasrimfirenut is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 12:44 PM #2
a 285 will easily fit on your stock rims. might want to post a new thread in the 5th gen section asking others what sizes they run with that lift & what mods are needed.
tire sizes are very simple... the first number is how wide the tire is in millimeters. the next number is the sidewall aspect ratio, meaning how tall the sidewall is. so for a 265/70/17, the tire is 265mm wide, the sidewall is 70% of the width, & obviously is 17" diameter.
a 285 is only 20mm wider than a 265 & the sidewall is slightly taller at 70% of 285mm.
hope that helps some.
Old 06-23-2019, 01:55 PM #3
Ok thanks and yes that helps me out a good bit. The word sidewall help it all make sense now.
I do appreciate it very much.
Thanks!
Old 06-23-2019, 06:59 PM #4
& here is a tire height chart i use a lot, helps seeing the sizes in inches to get a good idea of what those numbers mean in real life.
Tire Height Chart
Old 06-24-2019, 09:31 AM #5
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
That's a great chart, firebirdguy.
Thanks for posting it!
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
lift , put , tire , understand , worry
HTML code is Off
I dont understand Desert Fox General Discussions 45 07-29-2013 02:26 PM
I dont understand 04rnr Off Topic 11 10-11-2012 09:55 PM
Noise Coming From Brakes? Did brake job i dont understand help! johnathandm 3rd gen T4Rs 3 07-01-2011 09:59 PM
Drivers side front/rear speakers dont work. Obvious stuff checked denvertoyota 3rd gen T4Rs 6 10-09-2010 12:17 AM
I don't understand tire sizing...Can someone help? doctob Engines / Suspension / Wheels / Tires / Audio / Accessories 8 07-21-2006 11:31 AM
