Old 07-04-2019, 12:00 PM #1
Pilgrimtrucker's Avatar
Pilgrimtrucker Pilgrimtrucker is offline
Pilgrimtrucker is on a distinguished road
Old mixed gas cause check engine light?
2000 SR5 3.4 check engine light came on the other day.
I suspect it may be from dumping about 2 gallons of mixed gas from the outboard boat motor fuel tank into the Toyota tank last weekend. I've done it before with my old Dodge pickup without any negative results, but that had a 33 gallon tank. 2 gallons of mixed gas in a 18 gallon tank might not be enough to dilute it without problems?
It's throwing codes; P0171: System too lean bank 1, P1133: and P1130 both indicate an issue with the Oxygen sensor and P0125: Insufficient coolant temp for closed loop fuel control.
I'm going to clean the MAF sensor first to see if that clears things up. Just curious what others think about this issue.
Thanks,
Pilgrimtrucker
Pilgrimtrucker is offline   Reply With QuoteReply With Quote
Old 07-05-2019, 04:40 PM #2
metallitera metallitera is offline
Real Name: Red
metallitera will become famous soon enough
Real Name: Red
Was the gas also high octane?
I bet the 2-stroke oil caused the codes. I used to add 2-stroke oil (and lots of other types of oils) to the fuel tank of my diesel truck, but I would not recommend adding any oil to any gas engine's gas tank. Especially modern engines with MAFs and O2 sensors, etc.
-ReD
Firefighter/Licensed Paramedic
*SOLD* 2000 4Runner Limited 4x4
2020 Ford F-150 3.5L EB
Build Thread
metallitera is offline   Reply With QuoteReply With Quote
Old 07-05-2019, 08:02 PM #3
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Prolly stuff was already gunked up a bit and the 2 gallons just pushed it over so it threw codes. I'd just try to clean everything and give it a go.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 07-06-2019, 01:31 PM #4
Well, a bottle of seafoam (16 oz in a half tank) and a good cleaning of the MAF sensor has not eliminated the check engine light. Cleared the code after the MAF sensor cleaning but my hope was dashed after a short drive. Going to go have them checked again to see if any of the three have disappeared.
Will cleaning and time correct this or am I looking at replacing parts?
Old 07-07-2019, 10:27 AM #5
Real Name: Red
Real Name: Red
Are you having any drivability issues?
You may just have to run it until it is all gone or diluted enough to not make a noticeable difference anymore. To keep it as diluted as possible, I'd fill your tank back up every time it gets down to 3/4 for a few times then run it down to E and refill with clean gas and reset codes.....or drain the tank now and refill with clean gas. If they return still then I'd probably replace the fuel filter and try cleaning the MAF sensor and throttle body maybe?
-ReD
Build Thread
Old 07-16-2019, 01:47 PM #6
ToyotaBoogie ToyotaBoogie is offline
ToyotaBoogie is on a distinguished road
Out of curiosity, what did you use to clean your MAF sensor? And did P0125 come back?
ToyotaBoogie is offline   Reply With QuoteReply With Quote
gas , issue , mixed , sensor , tank
HTML code is Off
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
Check Engine Light, VSC OFF And Check VSC Lights just came on??? the_josh Maintenance/Detailing 5 07-15-2019 01:25 PM
Check engine light, vsc light, traction light all on after a short circuit mikeng 4th Gen T4Rs 3 01-01-2018 07:54 PM
Intermittent vehicle/engine shake and vibration with check engine light present lloydster 3rd gen T4Rs 26 09-26-2017 11:58 AM
Just washed engine bay- now check engine light appears BlackIceWAP 3rd gen T4Rs 9 07-09-2006 08:48 PM
