Old 07-21-2019, 05:03 PM #1
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
Has anything changed in the speaker department on the 2019 TRD OR?
I am reading a ton of threads of people wit older 4Runners are changing out their speakers and adding a amp. I don't want to add a amp at all I am looking to just swap out the speakers for something better. I found this thread and like the speakers but the rear say they won't fit when I go to the Crutchfield site on the link. I have a few questions, What size is in the front and rear doors, What did you use in the rear hatch, I don't want to use the components. I would like to stick with all the same brand also if possible and I would prefer some 2 way or 3 way speakers. Also does anyone know what the speaker output is for a 19 factory head unit. I find it hard to find a reason to swap out the head unit.
5th Gen 4Runner Audio Upgrades - The Complete Audio System Guide
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 07:50 PM #2
I am thinking of this set up and using the stock head unit.
Dash - Rockford Fosgate R1T-S Prime Series 1" Mylar balanced dome tweeters at Crutchfield
Front doors - Rockford Fosgate R165X3 Prime Series 6-1/2" 3-way car speakers at Crutchfield
Rear doors and hatch - Rockford Fosgate R1525X2 Prime Series 5-1/4" 2-way car speakers at Crutchfield
Anyone have experience with them? The seem really low priced, do you think they are better than the stock speakers?
The Build
Old 07-24-2019, 10:13 AM #3
Narat_524 Narat_524 is offline
Narat_524 will become famous soon enough
My '19 TRD ORP had the following:
3" "tweeter" in the dash (room for a 3.5" speaker with mods to the bracket)
6X9" woofer in front door (either replace with a 6X9 or get an adapter and install 6.5")
5.25" woofer in rear door (you could probably fit 6.5", but might need enlarge hole just a hair, and would to watch mounting depth)
6.5" rear hatch (you could probably fit 6.75", and again, watch the mounting depth)
I have upgraded to the following:
3.5" Infinity Ref 3022CFX dash
6X9 Infinity Ref 9620CX component frt door
5.25" Infinity 50.11CS component rear doors
6.5" Hertz HCX coaxial rear hatch
Kenwood KSC-SW11 8" powered sub under the passenger seat
2X Kicker Key 180.4 amps (one for frt 4 speakers, one for rear 4 speakers)
What's odd with the 4Runner is how they have wired the speakers;
The dash and front doors are wired in parallel, so they act like a component speaker set. A challenge you might note here swapping to a 1" tweeter in the dash position, the stock connector has a crossover capacitor soldered into it. You would probably need to replace that with one tuned for your tweeter vs. the existing 3" speaker/tweeter.
The rear door and rear hatch speakers are wired in series, and are noticeably quieter than the fronts (because they're splitting the same power between two speakers per L and R circuit).
If you don't mind running wires, you can split all these channels into separate circuits using your amp. It makes an enormous difference in the volume you can attain, and if your amp has the adjustment, you can tune each channel. It's a night and day difference, even with the stock head unit.
Narat
Narat_524 is offline   Reply With QuoteReply With Quote
Old 07-30-2019, 09:50 PM #4
CMTAZ CMTAZ is offline
CMTAZ will become famous soon enough
Cool PowerBass
I have an SR5 premium (w/Nav)
I used 2 pairs of:
PowerBass OE652-TY 6-1/2" 2-way car speakers for select Toyota, Lexus, and Scion vehicles at Crutchfield
and 1 pair of:
PowerBass OE69C-TY 6"x9" component speaker system for select Toyota, Lexus, and Scion vehicles at Crutchfield
purchases on ebay for 234$ total. They were a great improvement, but the 5 channel amp REALLY brought them to life.
The new speakers are in
2018 SR5 Premium - Eibach Pro Truck Lift Kit - TRD Wheels - Falken Wildpeak AT/3 - Tyger Armor Step Bars - Clear Bra - Kenwood DMX706s head unit - PowerBass 6.5" coaxial & 6x9" component speakers (tweeters replaced by JBL 3.5" coax) - Kenwood Excelon 5 Channel Amp - Pioneer 12" Shallow Mount Subwoofer - RAV4 Convex Mirrors - LED Headlights - Lexus LED Fog Lights (clones)
CMTAZ is offline   Reply With QuoteReply With Quote
Old 08-07-2020, 07:08 AM #5
Chubbypanda Chubbypanda is offline
Chubbypanda will become famous soon enough
Have you upgraded your system yet? Did you go with the rockford speakers?
Chubbypanda is offline   Reply With QuoteReply With Quote
Old 07-08-2022, 05:02 PM #6
osugsxr osugsxr is offline
I used 2 pairs of:
and 1 pair of:
How do you like the powerBass speakers? Considering these
head , rear , speakers , swap , unit
HTML code is Off
JBL system speaker mode (2019 TRD Pro) chips Engines / Suspension / Wheels / Tires / Audio / Accessories 1 05-26-2019 01:37 AM
Need a service department in Hattiesburg Ms Charlievee Dealers - Your Experience 0 11-02-2018 12:50 PM
Did the service department try to rip me off? blackrifle01 4th Gen T4Rs 20 12-17-2011 12:19 PM
