The GX stock suspension can handle a bunch of difficult trails and move at a very nice speed on the terrain you describe while being very comfy on road. I think the Fox 2.0 will end up being quite the downgrade, particularly for the described use.
Are you sure it is going out? Even if you do need new OE shocks, they can easily last 200k. In 200k, you will go through about 3 rebuilds on a "go fast suspension" without ever using it for that. And if you don't rebuild yourself, you will end up paying a lot more for a lot less. My 2c.
