12-21-2009, 05:04 PM
Super Moderator
Super Moderator
255/75/17 installed! Pics:-)
Well after much contemplation I settled on some new tires. I say settled because I had my heart set on another but the under $800 OTD price (including alignment and road hazard) forced me to use my head. :-(
I now have 5 (yes, 5) Goodyear Wrangler Silent Armor’s in the 255/75/17 size. (Yes, the 255/75/17 spare fits and I have the stock resonator/tailpipe with a Hidden Hitch receiver.) I really wanted the same size Revo II but times are tight, it’s not 2007 anymore
As it turned out I couldn't be happier
1st thing- The size… 255/75/17 was a “home run” for me. The fitment is awesome! They just squeeze in with no rubbing, no trimming and it's a 32"+ tire. The next added bonus is that my optimistic MPG meter has settled on a higher value, of course the jury is ‘still out’. There are many variables, speedo corrections etc and 35 miles isn’t enough to definitively say anything. On the subject of speedo’s my GPS says 51mph while the speedo says 49mph, so 4%
Before I comment on noise, ride and handling understand I am coming off of the very civilized and smooth Michelin Cross-Terrains at 34psi cold with 3-4/32’s of tread left. Ride, for my short drive the ride seems good. It is a hair firmer but not at all harsh. This tire is a heavier than the OE by 3-4lbs each and that never helps plus the Michelin was designed with a smooth ride as a top goal. Right now the new tires are set at 40psi cold. I am going to let a little out. My suspicion is 37-38psi will be perfect Handling, Holy Crap! It is crazy good! I was fully anticipating steering response and sidewall roll would be greater with this tire compared with the Michelin, not so (by the seat of my pants). The steering response is phenomenal! Quick right-left transitions don’t exhibit any more tire slop than the Michelins did, in fact maybe less. there's less of a tendency to track minor grooves in the road too (that could be in part due to a fresh alignment).
2nd- The GYSA specifically: The first comment, IMHO, speaks mostly to the size rather than the GYSA specifically. The GYSAs noise levels are up a hair from the CTs (go figure ). To notice a difference you must turn the radio off and to my surprise on one type of pavement the GYSA’s were quieter than the CTs. Overall just a touch more noise. We’re getting some rain in a couple of days and I’ll report back as I learn more.
EDIT/Update: After a few hundred miles and some rain I can offer the following: a) The GYSA's, in my case, need to be a bit softer than I would've thought, 35PSI seems to be right. b) MPG meter is very close to 'dead-on', within a tenth! c) MPG seems to be up a little bit, just a couple of tenths but it's up not down. d) The noise is up a bit but not in a bad or intrusive way. e) The rain/wet/puddle-crashing performance of the GYSA is great!
Overall I'm thrilled with the ride/drive and looks. I would very enthusiastically recommend the 255/75/17 or 255/70/18 size. If you think the GYSA is a good candidate for your needs and wants then I say do it...
BTW, I have double and triple checked, no rubbing. It's like the 4th gen was designed for this tire and some bumper height requirement forced Toyota into the 30.5" tire category.
Edit/Update, Final: See my last post here and this: http://www.toyota-4runner.org/perfor...installed.html
The wheel is cut to show where the tire has the least clearance.
My helper…
Hambone, Paraordnance and anybody else feel free to add a pic of yours. It'll just help the next guy wanting to know about 255/75/17's or 255/70/18's
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
12-21-2009, 06:13 PM
Mine will be installed 8am tomorrow!
2007 V6 Sport Galactic Grey - Goodyear Duratracs 265/70/17, Toytec 3" lift, Light Racing UCA, Spidertrax, 35%tint, Husky mats
12-22-2009, 12:18 PM
hey, im happy to hear that so far, they're working for you. everybody has different tire likes & needs, but i thought these would work for you. goodluck oh yea, great helper!
12-22-2009, 12:25 PM
They are on! So far so good
12-22-2009, 01:30 PM
I'm waiting for a brown truck as we speak I'm going to load them in a back and take it to the trie shop as soon as UPS shows up. Will take some snow pictures as we got another 5" of white stuff last night. Funny but I come from Mich CT as well so it will be very similar experience for me
2004 4Runner Limited V8 4WD
Toytec Ultimate 3" (X-REAS & RAS - delete). LS460 + STi retrofit, Switchback Halos, LEDs in/out, Fog light mod.
CBI front bumper. 285/70/17 Duratracs.
JVC KW-V50BT with Hertz HCP4D & Hertz HCP1D, Hertz ESK-165 components and JL 10TW3 in custom stealth enclosure. Backup camera and steering wheel controls.
12-22-2009, 02:34 PM
Those look good guys.
The front looks CLOSE.
Check out my garage.
12-22-2009, 03:24 PM
Super Moderator
Super Moderator
Chaz, thanks for that last minute PM of reassurance that I needed. They are great for my needs and wants.
Looks good! I want to try mine in the snow Your truck looks too clean for the roads... How'd you do that
Very close but no hit It is all good. I even backed up fast, turned and hit the brake to see if I could induce a rub but no rub
Chris
12-22-2009, 04:40 PM
Moderator
Moderator
Congrats!! they look good.
Kevin's 2008 4x4 Build Thread
Perkins Performance | Shrockworks | Demello | BudBuilt | ICON | Warn | Overland Warehouse | Goodyear | Lightforce | Spidertrax | Powertank | Complete LED Conversion
12-22-2009, 09:15 PM
Haha did the shop a favor today and got a wash before having them touch the car
12-22-2009, 11:47 PM
Those are good lookin tires! How tall are they? 32"?
06 Sport, V6, Sway Away Coilovers front, Bilstiens w/Sway Away Coils rear, SpiderTrax, BFG A/T KOs, 275/65/17s.
12-23-2009, 11:03 AM
CJ3Flyr are you noticing any rubbing at all.. Not even talking full wheel turn.. i need to look closer but its been to cold and working too hard.
Otherwise these are great so far looks way better! Notice on highway that definitely taller tire.
12-23-2009, 12:39 PM
Super Moderator
Super Moderator
No rubbing at all. No Spidertax either. J.A.'s website has wonderful how-to for fenderliner adjustment at the bottom of the page for 'wheelspacers'. http://www.top4runners.com/ja/2007/wheelspacers.html
Chris
12-23-2009, 12:53 PM
Super Moderator
Super Moderator
Most of the brands list this size as 32.1”. They're about .4” taller than most 265/70/17's. What are your BFG's? They're 31.5"+ or right at 32 also, right?
Chris
12-23-2009, 01:59 PM
Looking good, Ive been thinking about picking up a set of tires to have on hand. You said you got 5 so I assume no probs fitting the spare with this size? They are pretty cheap on TR.
350Z--->T4R--->370Z--->T4R--->TDI--->T4R
2006 Titanium Silver V6 SE 4x4-Sold
2007 Titanium Silver V8 SE 4x4-Wrecked
2008 Galactic Grey V8 SE 4x4-Current
12-23-2009, 02:07 PM
Looks awesome Chris,
I just upgraded mine to the Hankook Dynapro ATMs in a 255/70/18.
I'll post pics after I do the CJ3Flyr lift
David Simpson
2006 4Runner Limited
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
HTML code is Off
