Old 08-30-2019, 07:08 PM #1
DannyKhaKha DannyKhaKha is offline
Real Name: danny
DannyKhaKha is on a distinguished road
Real Name: danny
Suspension Install: Anti-Seize or Threadlocker
I'm going to be doing a dobinsons 3 inch lift to my 4th gen 4runner soon with JBA UCA and I wanna know if I should use anti-seize or threadlocker on certain bolts (All of them possibly?)? If possible and would be greatly appreciated if y'all could point out which bolt requires anti-seize or threadlocker.
DannyKhaKha is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 08:17 PM #2
Narat_524 Narat_524 is offline
Narat_524 will become famous soon enough
I would consider the following:
1) Does it have a locknut already? If yes, no threadlocker. If no, threadlocker.
2) Does it have to come apart frequently? If yes, probably anti-seize. If no, probably threadlocker.
3) exposed to high heat, anti-seize.
JBA (and really anything with a polyurethane bushing) says to loosen the bolts and nuts before greasing so the bushing doesn't explode. This means the UCA nut will be on and off, depending on the miles and driving conditions, you should probably be greasing the UCAs once per year at a minimum, and more if you have crappy winters, deep water/mud, etc.
It is not a locknut. So, I put threadlocker on the UCA bolts, and when I loosen to grease, I back the nut off to the point I can get a brush on the threads, clean up the threadlocker, then put a dab back on, grease, and re-torque to spec.
Summary: Don't come off, threadlocker. Comes off frequently and/or prone to rust, anti-seize.
And I'll add, if rust is a concern, spraying everything with fluid film and/or cosmoline spray can help even if you don't use anti-seize.
Narat
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
Narat_524 is offline   Reply With QuoteReply With Quote
Old 09-03-2019, 10:02 PM #3
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Now the question is blue or red.....
But I follow pretty much the above.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
anti-seize , bolts , possibly , suspension , threadlocker
HTML code is Off
Anti-Seize AE1M 4th Gen T4Rs 15 04-29-2020 09:02 PM
PSA: Anti-Seize Your Lower Shock Mounts JSparky 5th gen T4Rs 5 01-31-2019 01:12 PM
Anti-Seize... Worth it? hamburglar210 5th gen T4Rs 26 01-02-2019 06:49 PM
Loctite blue or anti-seize paste for skid bolts? Tallman 5th gen T4Rs 16 12-19-2018 04:47 PM
Used Dielectric Grease instead of Anti Seize...help! dilip4runner1 3rd gen T4Rs 4 05-26-2014 11:20 AM
