Originally Posted by Dillusion
Guess I got couple questions for your question.
1. Where did you tap your original power from? I wouldn't just keep tapping off a tap.
2. What exactly do you need to power. Need to calculate current draw.
I currently only have a single accessory with an AOB switch (compressor). I used an add-a-fuse with a 3a fuse in a blank spot in the fuse box under the dash. A slot that gets power only when the vehicle is on. Everything works as it should with this switch.
I received a light bar, so while I am able to get everything wired under the hood with the supplied harness, when it comes to getting power to a second AOB switch is where I am struggling. I am just not sure on the best way to do this. I am in agreement that I do not think that just tapping again would be the most efficient way.
Thanks
