Old 06-21-2021, 05:46 PM #1
SoCoRuss's Avatar
SoCoRuss SoCoRuss is offline
SoCoRuss is on a distinguished road
SoCoRuss's Avatar
Intergraded Brake Controller Location
Got my new 21 Venture. Looking to put the IBC back in it from old 4R. I had it attached to front lower panel by my left knee. But it seemed to constantly hit my or wifes knees when getting in/out.
My question is has anyone put them in a different place? Suggestions/ideas and pics of other places to locate it?
SoCoRuss is offline   Reply With QuoteReply With Quote
Old 06-24-2021, 11:19 AM #2
spartacus's Avatar
spartacus's Avatar
I have mine velcroed in the same spot'as yours so it's only there when towing.
Old 07-11-2021, 05:43 PM #3
gordonp gordonp is offline
gordonp is on a distinguished road
OK! I'll give you suggestions, ideas and a couple of photos.
I had my dash apart for a bunch of projects (2021 TRD Off Road (Premium)), and I installed my Redarc Tow Pro Elite at the same time.
Summary:
I installed my controller on the brake-pedal bracket. I spliced together the Tekonsha 3401P harness and Redarc's pigtail-harness. I opted to mount the tiny gain-adjustment dial in the recessed switch area by the driver's right-knee.
Mounting Details:
  • Remove Battery (or at least disconnect it).
  • Remove lower dash. Mostly it pulls/un-snaps, but there are two 10mm bolts along the bottom.
  • I waited many days after battery-disconnect, then also removed the knee-airbag. There are 4x 10mm bolts; I left the wire connected and placed the 'bag + bracket carefully out of the way, while still attached.
  • I test-positioned the Redarc controller, then carefully drilled two holes in the pedal-mounting bracket. Make sure everything is clear!!! Spend a lot of quality-time on your back, with a flashlight, and feel around as you move the brake-pedal a bit.
  • For certainty of clearance, and ease of assembly, I inserted two 8-32 stainless bolts from the firewall-side of my drilled holes, then I could apply Loctite Blue, lockwasher and nut quite easily from the accessible-side.
  • I used double-sided 3M super-sticky-tape and a lower tie-wrap to keep the controller body secure.
Wiring Details:
  • I spliced the Tekonsha 3401P harness to the Redarc pigtail-harness. This goes nicely, because it's color-to-color.
  • Stagger/offset the four wire joints, to minimize the "dog knot" in your harness.
  • For each splice, I used a Western Union connection, soldered each splice, and slid heat-shrink tubing over each
  • I like the ground-lug that Tekonsha adds to the white (ground) wire, and so I re-included that. Just above my Redarc mounting location, there are a couple of factory M6 holes - I applied nickel-antiseize (to ensure a reliable, long-lasting connection) and used a stainless bolt to secure the ground wire.
  • I slid larger heat-shrink tubing over all the connections
  • I had pushed back/compressed the Tekonsha protective-braid during my splicing, and afterward I slid this all the way up and along my new, custom harness. Looks factory!
The Tekonsha harness + Redarc pigtail are generously long. I easily routed this custom harness, under-dash, toward the driver, well away from the parking-brake, then looped it back in to the controller.
My custom harness is shown in the second photo, looping up at the left, arcing across and over Toyota connectors, then turning down and tie-wrapped to existing harnesses before making it's way to the controller.
Likewise, the Redarc harness for the control-knob is generous, and can be safely routed away from everything.
My approach IS NOT for the impatient! But if you take pride in your work, and want your 4Runner to give you decades of troublefree service, then maybe you'll find something helpful in the way I did this.
Intergraded Brake Controller Location-redarc_tow-pro_controller_installation-jpg  Intergraded Brake Controller Location-redarc_tow-pro_custom_harness-jpg
gordonp is offline   Reply With QuoteReply With Quote
hit , intergraded , knees , put , wifes
HTML code is Off
2014 Brake Controller Harness location T4Rife 5th gen T4Rs 8 09-04-2014 07:20 PM
Trailer brake controller in 5th Gen.: best location Catchlight 5th gen T4Rs 6 10-13-2013 06:01 PM
Facotry Plug Location for Brake Controller 2008 SR5 Dougtoms01 4th Gen T4Rs 1 03-23-2012 03:06 PM
Brake Controller Location majmattmason 4th Gen T4Rs 2 05-02-2008 08:52 PM
Braker COntroller Location (05') Blabel4runner 4th Gen T4Rs 4 05-25-2007 10:25 AM
