Old 10-20-2019, 02:56 AM #1
96TrailSurfer 96TrailSurfer is offline
96TrailSurfer is on a distinguished road
Leaking Air Fitting (Viair)
I've been using a Viair 400P(A) for a few years, and finally decided to hard-mount for use as OBA with a 5 gallon tank. Just my luck, as soon as I decided to do that, it the fitting that connects the 150 psi pressure switch to the compressor manifold starting leaking at the swivel point (I am almost sure).
I've put a call in to Viair and hope they'll send me a new one.
If not, however, has anyone had similar issues? Is it possible that I am simply tightening it wrong? Is there anywhere other than Viair where I can get this fitting?
Leaking Air Fitting (Viair)-viair-400p-jpg  Leaking Air Fitting (Viair)-viair-400p-2-jpg  Leaking Air Fitting (Viair)-viair-400p-3-jpg
96 Hilux Surf - 1KZ-TE (EGR delete, turbo boost controller, catch can), 2.5" lift in the front (Tundra Bilstein 5100s, Eibach 620#, and SPC UCAs), 3.5" lift in teh rear (Fox racing 2.5 remote resi adjustable 3rd gen Taco shocks and LC 8.5 wrap coils), 1" body lift (4crawler), ARB bumper, with SmittyBilt XRC 9.5k Gen 2 winch, 33" KO2s, D2S projector retrofits
96TrailSurfer is offline   Reply With QuoteReply With Quote
Old 10-21-2019, 08:05 PM #2
Narat_524 Narat_524 is offline
Narat_524 will become famous soon enough
That looks pretty specific to the application. The Viair check valve option might not be cheapest by a few bucks, but the amount you'll save scraping the internet probably aren't worth it.
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
Narat_524 is offline   Reply With QuoteReply With Quote
decided , fitting , leaking , put , viair
HTML code is Off
Viair 88p...onboard or not? TheKorstjens 3rd gen T4Rs 21 10-19-2017 06:53 PM
Viair 85P for under hood? ktom3001 4th Gen T4Rs 3 08-20-2013 06:43 AM
Viair Setup for OBA jangoforhire 5th gen T4Rs 64 08-03-2012 12:35 AM
